I was using the previous development binding, and I seemed to have forgotten about that key along the way - Thanks for reminding me. I copied it before I deleted all Things, put it back and low & behold, I didn’t have to re-include. Stupid me…
So I have put the latest development binding ‘in service’ so-to-speak, but I’m afraid to report that my setpoint issue persists - I’m completely baffled. The same thing appears in the log:
2018-08-23 22:12:46.048 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 40: Command received zwave:device:512:node40:thermostat_setpoint_cooling --> 72
2018-08-23 22:12:46.056 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 40: Command for unknown channel zwave:device:512:node40:thermostat_setpoint_cooling with DecimalType
The only other questionable things I see in the log are below:
2018-08-23 21:47:38.242 [INFO ] [el.core.internal.ModelRepositoryImpl] - Refreshing model 'home.sitemap'
2018-08-23 21:47:46.758 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item 'entry_lights' for widget org.eclipse.smarthome.model.sitemap.Switch
2018-08-23 21:47:46.762 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item 'entry_lights' for widget org.eclipse.smarthome.model.sitemap.Switch
2018-08-23 21:47:46.765 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item for widget org.eclipse.smarthome.model.sitemap.Switch
2018-08-23 21:48:06.121 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item 'entry_lights' for widget org.eclipse.smarthome.model.sitemap.Switch
2018-08-23 21:48:06.127 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item 'entry_lights' for widget org.eclipse.smarthome.model.sitemap.Switch
2018-08-23 21:48:06.133 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item for widget org.eclipse.smarthome.model.sitemap.Switch
2018-08-23 21:48:07.584 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item 'entry_lights' for widget org.eclipse.smarthome.model.sitemap.Switch
2018-08-23 21:48:07.591 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item 'entry_lights' for widget org.eclipse.smarthome.model.sitemap.Switch
2018-08-23 21:48:07.597 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item for widget org.eclipse.smarthome.model.sitemap.Switch
2018-08-23 21:48:10.241 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item 'entry_lights' for widget org.eclipse.smarthome.model.sitemap.Switch
2018-08-23 21:48:10.247 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item 'entry_lights' for widget org.eclipse.smarthome.model.sitemap.Switch
2018-08-23 21:48:10.256 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item for widget org.eclipse.smarthome.model.sitemap.Switch
2018-08-23 21:48:18.932 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item 'entry_lights' for widget org.eclipse.smarthome.model.sitemap.Switch
2018-08-23 21:48:18.937 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item 'entry_lights' for widget org.eclipse.smarthome.model.sitemap.Switch
2018-08-23 21:48:18.942 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item for widget org.eclipse.smarthome.model.sitemap.Switch
2018-08-23 21:48:20.319 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item 'entry_lights' for widget org.eclipse.smarthome.model.sitemap.Switch
2018-08-23 21:48:20.324 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item 'entry_lights' for widget org.eclipse.smarthome.model.sitemap.Switch
2018-08-23 21:48:20.328 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item for widget org.eclipse.smarthome.model.sitemap.Switch
2018-08-23 21:48:22.635 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item 'entry_lights' for widget org.eclipse.smarthome.model.sitemap.Switch
2018-08-23 21:48:22.641 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item 'entry_lights' for widget org.eclipse.smarthome.model.sitemap.Switch
2018-08-23 21:48:22.646 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item for widget org.eclipse.smarthome.model.sitemap.Switch
2018-08-23 21:48:24.329 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item 'entry_lights' for widget org.eclipse.smarthome.model.sitemap.Switch
2018-08-23 21:48:24.334 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item 'entry_lights' for widget org.eclipse.smarthome.model.sitemap.Switch
2018-08-23 21:48:24.339 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item for widget org.eclipse.smarthome.model.sitemap.Switch
2018-08-23 21:48:25.698 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item 'entry_lights' for widget org.eclipse.smarthome.model.sitemap.Switch
2018-08-23 21:48:25.705 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item 'entry_lights' for widget org.eclipse.smarthome.model.sitemap.Switch
2018-08-23 21:48:25.711 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item for widget org.eclipse.smarthome.model.sitemap.Switch
2018-08-23 21:48:50.302 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item 'entry_lights' for widget org.eclipse.smarthome.model.sitemap.Switch
2018-08-23 21:48:50.308 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item 'entry_lights' for widget org.eclipse.smarthome.model.sitemap.Switch
2018-08-23 21:48:50.320 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item for widget org.eclipse.smarthome.model.sitemap.Switch
2018-08-23 21:48:55.052 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item 'entry_lights' for widget org.eclipse.smarthome.model.sitemap.Switch
2018-08-23 21:48:55.060 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item 'entry_lights' for widget org.eclipse.smarthome.model.sitemap.Switch
2018-08-23 21:48:55.067 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item for widget org.eclipse.smarthome.model.sitemap.Switch
2018-08-23 21:48:57.977 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item 'entry_lights' for widget org.eclipse.smarthome.model.sitemap.Switch
2018-08-23 21:48:57.984 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item 'entry_lights' for widget org.eclipse.smarthome.model.sitemap.Switch
2018-08-23 21:48:57.989 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item for widget org.eclipse.smarthome.model.sitemap.Switch
2018-08-23 21:49:21.361 [ERROR] [e.internal.WriterInterceptorExecutor] - MessageBodyWriter not found for media type=text/plain, type=class java.util.Collections$UnmodifiableCollection, genericType=class java.util.Collections$UnmodifiableCollection.
2018-08-23 21:49:28.494 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item 'entry_lights' for widget org.eclipse.smarthome.model.sitemap.Switch
2018-08-23 21:49:28.500 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item 'entry_lights' for widget org.eclipse.smarthome.model.sitemap.Switch
2018-08-23 21:49:28.506 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item for widget org.eclipse.smarthome.model.sitemap.Switch
2018-08-23 21:49:59.014 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item 'entry_lights' for widget org.eclipse.smarthome.model.sitemap.Switch
2018-08-23 21:49:59.021 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item 'entry_lights' for widget org.eclipse.smarthome.model.sitemap.Switch
2018-08-23 21:49:59.028 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item for widget org.eclipse.smarthome.model.sitemap.Switch
2018-08-23 21:50:31.035 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item 'entry_lights' for widget org.eclipse.smarthome.model.sitemap.Switch
2018-08-23 21:50:31.042 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item 'entry_lights' for widget org.eclipse.smarthome.model.sitemap.Switch
2018-08-23 21:50:31.048 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item for widget org.eclipse.smarthome.model.sitemap.Switch
2018-08-23 21:51:01.593 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item 'entry_lights' for widget org.eclipse.smarthome.model.sitemap.Switch
2018-08-23 21:51:01.600 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item 'entry_lights' for widget org.eclipse.smarthome.model.sitemap.Switch
2018-08-23 21:51:01.605 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item for widget org.eclipse.smarthome.model.sitemap.Switch
2018-08-23 21:51:32.208 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item 'entry_lights' for widget org.eclipse.smarthome.model.sitemap.Switch
2018-08-23 21:51:32.215 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item 'entry_lights' for widget org.eclipse.smarthome.model.sitemap.Switch
2018-08-23 21:51:32.220 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item for widget org.eclipse.smarthome.model.sitemap.Switch
2018-08-23 21:52:47.180 [INFO ] [el.core.internal.ModelRepositoryImpl] - Refreshing model 'home.items'
2018-08-23 21:52:47.251 [WARN ] [mon.registry.AbstractManagedProvider] - Could not update element with key _tags:upstairs_temp in ManagedMetadataProviderImpl, because it does not exists.
2018-08-23 21:52:47.265 [WARN ] [mon.registry.AbstractManagedProvider] - Could not update element with key _tags:downstairs_temp in ManagedMetadataProviderImpl, because it does not exists.
2018-08-23 21:52:47.271 [WARN ] [mon.registry.AbstractManagedProvider] - Could not update element with key _tags:downstairs_setcool in ManagedMetadataProviderImpl, because it does not exists.
2018-08-23 21:52:47.278 [WARN ] [mon.registry.AbstractManagedProvider] - Could not update element with key _tags:downstairs_setheat in ManagedMetadataProviderImpl, because it does not exists.
2018-08-23 21:52:47.286 [WARN ] [mon.registry.AbstractManagedProvider] - Could not update element with key _tags:living_room_fan in ManagedMetadataProviderImpl, because it does not exists.
2018-08-23 21:52:47.298 [WARN ] [mon.registry.AbstractManagedProvider] - Could not update element with key _tags:master_bedroom_fan in ManagedMetadataProviderImpl, because it does not exists.
2018-08-23 21:52:47.306 [WARN ] [mon.registry.AbstractManagedProvider] - Could not update element with key _tags:front_door_lock in ManagedMetadataProviderImpl, because it does not exists.
2018-08-23 21:52:47.313 [WARN ] [mon.registry.AbstractManagedProvider] - Could not update element with key _tags:back_door_lock in ManagedMetadataProviderImpl, because it does not exists.
2018-08-23 21:52:47.321 [WARN ] [mon.registry.AbstractManagedProvider] - Could not update element with key _tags:door_announcements in ManagedMetadataProviderImpl, because it does not exists.
2018-08-23 21:52:47.327 [WARN ] [mon.registry.AbstractManagedProvider] - Could not update element with key _tags:kitchen_light in ManagedMetadataProviderImpl, because it does not exists.
2018-08-23 21:52:47.343 [WARN ] [mon.registry.AbstractManagedProvider] - Could not update element with key _tags:entry_table_outlet in ManagedMetadataProviderImpl, because it does not exists.
2018-08-23 21:52:47.350 [WARN ] [mon.registry.AbstractManagedProvider] - Could not update element with key _tags:dining_light in ManagedMetadataProviderImpl, because it does not exists.
2018-08-23 21:52:47.356 [WARN ] [mon.registry.AbstractManagedProvider] - Could not update element with key _tags:dining_room_light in ManagedMetadataProviderImpl, because it does not exists.
2018-08-23 21:52:47.363 [WARN ] [mon.registry.AbstractManagedProvider] - Could not update element with key _tags:living_room_light in ManagedMetadataProviderImpl, because it does not exists.
2018-08-23 21:52:47.369 [WARN ] [mon.registry.AbstractManagedProvider] - Could not update element with key _tags:living_room_lamp in ManagedMetadataProviderImpl, because it does not exists.
2018-08-23 21:52:47.377 [WARN ] [mon.registry.AbstractManagedProvider] - Could not update element with key _tags:fire_place_light in ManagedMetadataProviderImpl, because it does not exists.
2018-08-23 21:52:47.384 [WARN ] [mon.registry.AbstractManagedProvider] - Could not update element with key _tags:fire_place_light_color in ManagedMetadataProviderImpl, because it does not exists.
2018-08-23 21:52:47.393 [WARN ] [mon.registry.AbstractManagedProvider] - Could not update element with key _tags:master_bedroom_light in ManagedMetadataProviderImpl, because it does not exists.
2018-08-23 21:58:02.879 [ERROR] [e.internal.WriterInterceptorExecutor] - MessageBodyWriter not found for media type=text/plain, type=class java.util.Collections$UnmodifiableCollection, genericType=class java.util.Collections$UnmodifiableCollection.
2018-08-23 21:58:34.776 [ERROR] [e.internal.WriterInterceptorExecutor] - MessageBodyWriter not found for media type=text/plain, type=class java.util.Collections$UnmodifiableCollection, genericType=class java.util.Collections$UnmodifiableCollection.
2018-08-23 21:59:02.531 [ERROR] [e.internal.WriterInterceptorExecutor] - MessageBodyWriter not found for media type=text/plain, type=class java.util.Collections$UnmodifiableCollection, genericType=class java.util.Collections$UnmodifiableCollection.
2018-08-23 21:59:37.835 [ERROR] [e.internal.WriterInterceptorExecutor] - MessageBodyWriter not found for media type=text/plain, type=class java.util.Collections$UnmodifiableCollection, genericType=class java.util.Collections$UnmodifiableCollection.
2018-08-23 22:00:23.680 [ERROR] [e.internal.WriterInterceptorExecutor] - MessageBodyWriter not found for media type=text/plain, type=class java.util.Collections$UnmodifiableCollection, genericType=class java.util.Collections$UnmodifiableCollection.
2018-08-23 22:00:26.593 [ERROR] [e.internal.WriterInterceptorExecutor] - MessageBodyWriter not found for media type=text/plain, type=class java.util.Collections$UnmodifiableCollection, genericType=class java.util.Collections$UnmodifiableCollection.
2018-08-23 22:04:57.613 [ERROR] [e.internal.WriterInterceptorExecutor] - MessageBodyWriter not found for media type=text/plain, type=class java.util.Collections$UnmodifiableCollection, genericType=class java.util.Collections$UnmodifiableCollection.
2018-08-23 22:06:08.422 [ERROR] [e.internal.WriterInterceptorExecutor] - MessageBodyWriter not found for media type=text/plain, type=class java.util.Collections$UnmodifiableCollection, genericType=class java.util.Collections$UnmodifiableCollection.
2018-08-23 22:06:18.805 [ERROR] [e.internal.WriterInterceptorExecutor] - MessageBodyWriter not found for media type=text/plain, type=class java.util.Collections$EmptySet, genericType=class java.util.Collections$EmptySet.
2018-08-23 22:06:24.642 [ERROR] [e.internal.WriterInterceptorExecutor] - MessageBodyWriter not found for media type=text/plain, type=class java.util.Collections$UnmodifiableCollection, genericType=class java.util.Collections$UnmodifiableCollection.
2018-08-23 22:06:53.911 [ERROR] [e.internal.WriterInterceptorExecutor] - MessageBodyWriter not found for media type=text/plain, type=class java.util.Collections$UnmodifiableCollection, genericType=class java.util.Collections$UnmodifiableCollection.
2018-08-23 22:06:56.766 [ERROR] [e.internal.WriterInterceptorExecutor] - MessageBodyWriter not found for media type=text/plain, type=class java.util.Collections$UnmodifiableCollection, genericType=class java.util.Collections$UnmodifiableCollection.
2018-08-23 22:07:16.944 [ERROR] [e.internal.WriterInterceptorExecutor] - MessageBodyWriter not found for media type=text/plain, type=class java.util.Collections$UnmodifiableCollection, genericType=class java.util.Collections$UnmodifiableCollection.
2018-08-23 22:07:32.003 [ERROR] [e.internal.WriterInterceptorExecutor] - MessageBodyWriter not found for media type=text/plain, type=class java.util.Collections$UnmodifiableCollection, genericType=class java.util.Collections$UnmodifiableCollection.
2018-08-23 22:09:49.927 [ERROR] [e.internal.WriterInterceptorExecutor] - MessageBodyWriter not found for media type=text/plain, type=class java.util.Collections$UnmodifiableCollection, genericType=class java.util.Collections$UnmodifiableCollection.
2018-08-23 22:10:21.348 [ERROR] [e.internal.WriterInterceptorExecutor] - MessageBodyWriter not found for media type=text/plain, type=class java.util.Collections$UnmodifiableCollection, genericType=class java.util.Collections$UnmodifiableCollection.
