I’ve seen a couple of posts on this but not really sure how to go about fixing it. I have some rules based off the Tutorials on Time Based Rules, and have this below in one of them.
val long morning_start = (SunmorningNight_Time.state as DateTimeType).calendar.timeInMillis
val long day_start = (Sunrise_Time.state as DateTimeType).calendar.timeInMillis
val long afternoon_start = (Sunnoon_Time.state as DateTimeType).calendar.timeInMillis
val long evening_start = (SuneveningNight_Time.state as DateTimeType).calendar.timeInMillis
val long night_start = (SuneveningNight_Time.state as DateTimeType).calendar.timeInMillis
But that is showing this in the log
2017-12-14 10:33:58.692 [INFO ] [el.core.internal.ModelRepositoryImpl] - Validation issues found in configuration model 'timeofday.rules', using it anyway:
The method getCalendar() from the type DateTimeType is deprecated
Since zonedDateTime is also deprecated, you will still get the rule validation warning unless you use .getZonedDateTime.toInstant.toEpochMilli. Also, no need for empty () in the DSL.
[EDIT: oops… I was wrong. My test included .calendar.timeInMillis for comparision, which is why I was getting the validation warning. There’s no validation warning with .zoneDateTime and in looking at the code, is the better choice! ]
You left out the zonedDateTime method, so like this…
if ((now.millis/1000 - (screen_bureau_time.state as DateTimeType).zonedDateTime.toEpochSecond) > screen_bureau_runtime)
I’ve been having fun lately with using Intervals to do time comparisons (the Duration could just be 86400000, but then I end up recalculating in my head how many days that is when reading back through the rule)…
val Boolean totalSolarEclipseThisWeek = new Interval(new Duration(java.util.concurrent.TimeUnit.DAYS.toMillis(7)),new DateTime((Sun_Eclipse_Total.state as DateTimeType).zonedDateTime.toInstant.toEpochMilli)).contains(now)
Probably not helpful for you, but your line could be written to use an Interval like this…
if (new Interval(new Duration(screen_bureau_runtime * 1000),new DateTime((screen_bureau_time.state as DateTimeType).zonedDateTime.toInstant.toEpochMilli)).contains(now))
I could not get that to work. My rule just fails silently when it gets to that line. I tried replacing the . with :: for the proper way to access static methods and values. This is probably one of those cases where I’m willing to give up some CPU efficiency to gain some easier to read and understand the code:
MyDateTimeItem.postUpdate(now.toString)
I’m sure with a little work I could figure out what the error is, but for now I wouldn’t recommend that approach for converting from Joda to DateTimeType when the toString works so well, at least in the case where we are posting the update or sending a command.
I also experienced the “deprecated-notification” today and wanted to code according to the new standards.
I however didn’t find how to convert the milliseconds back to a DateTimeType, as the wiki is also deprecated.
I want to post an update to a DateTime item.
How to do this?
My goal is to store the time when the wasing mashine starts and update another item when it finishes with the washing duration (starttime - now). Maybe you got a better idea of how to do this, if so, please let me know
rule "test time difference"
Time cron "*/10 * * * * ?"
val calendar = java.util.Calendar::getInstance
calendar.timeInMillis = now.millis - (Waschkueche_Waschmaschine_startZeit.state as DateTimeType).zonedDateTime.toInstant.toEpochMilli
Waschkueche_Waschmaschine_letzteZykluszeit.postUpdate(new DateTimeType(calendar))
This works but I want to solve it according to the new standard.
Thanks for your help
Maybe it is unusual to store time differences in a DateTime item.
I should maybe better use a Number item.
Can anyone show me how to format the Number item from milliseconds to hours and minutes in the sitemap?
I’m also having trouble with the deprecation of DateTime in the latest build using JSR223,
Can you give me a hint what the new coding standards would be?
Wouldn’t it be a good idea to update the documentation’s sample code? The sample code on the Rules page of the documentation is itself now deprecated… hardly a good start for those trying to fight their way through the absurd DateTimeType vs Joda DateTime wrangle for the first time.
