After solving my initial problem ([SOLVED] "Plugin execution not covered by lifecycle configuration" errors after clean Eclipse install , thanks guys!), I have encountered another show stopper. I am trying to use the package org.msgpack.core for developing a binding, and I am having some difficulty adding a dependency. I added
<dependency>
<groupId>org.msgpack</groupId>
<artifactId>msgpack-core</artifactId>
<version>0.8.8</version>
<scope>provided</scope>
</dependency>
into my binding’s pom.xml, as well as
<bundle dependency="true">mvn:org.msgpack/msgpack-core/0.8.8</bundle>
into my feature.xml. Everything builds fine in the console (mvn clean install -pl :org.openhab.binding.michaelstest -DskipChecks -DskipTests), and Project->Clean succeeds in Eclipse. However, hitting “resolve” in app.bndrun, I get
Resolution failed. Capabilities satisfying the following requirements could not be found:
[<<INITIAL>>]
⇒ osgi.identity: (osgi.identity=org.openhab.binding.michaelstest)
⇒ [org.openhab.binding.michaelstest version=2.5.0.201909301824]
⇒ osgi.wiring.package: (&(osgi.wiring.package=org.msgpack.core))
I assume I must be doing something very basic wrong, but after hours of googling I am no closer to a solution than I was before. Any pointers?
By the way, while building from the console works with msgpack version 0.8.8, it errors out with version 0.8.18:
Unable to create resource for bundle mvn:org.msgpack/msgpack-core/0.8.18
Suspicious…
