So I have this item (Sonoff Mini) that was first automatically discovered by Alexa because I synced with the eWelink APP.
Maybe because of that, when I later deleted that item from Alexa and then tried to add it after having flashed the device with Tasmota, Alexa is now not being able to discover it.
I shall say that I have literally dozens of devices flashed with Tasmota, all synced without any problems with Alexa and I even synced new devices after this case happened.
So I can only assume that the problem here was that automatic sync with Alexa when I first discovered this Sonoff Mini with eWelink (before flashing).
Does Alexa store MAC Address of devices and since I deleted this (when it was yet in the APP), then it is not discovered now?
How can I overcome this problem? I’ve found some suggestions but it all points to the same direction: RESET! I mean, I just don’t want to lose all rotines I have…
I just wanted to make sure Can you share more information on how you configured the affected item including the item definition? Did you make any changes to its configuration from the time it was first discovered?
To answer your initial question, a deleted item on the Alexa side should reappear on the subsequent discovery request if configured properly on the OH side.
