I’ve just upgraded from 2.3 to running openHAB 2.4.0 Release Build via OpenHabian on a RPi3, and since the upgrade completed I’m having some problems with my Z-Wave lightbulb (DTA19 Smart LED Light).
The item is defined as:
Dimmer Light_Landing "Dining Room Light" <light> (gDashboard) [Lighting] {autoupdate="false", channel="zwave:device:f5fcc3ad:node4:switch_dimmer"}
Although it’s a dimmer, I usually have it set to either OFF or 100%, and I control this with a simple Switch in the sitemap:
Switch item=Light_Landing label="Dining Room"
Before upgrading - this was working perfectly but now it’s giving some strange behaviour. Trying to turn the light off no longer sets the dimming to zero, but to 49%. From the logs:
2019-11-24 17:17:38.612 [ome.event.ItemCommandEvent] - Item 'Light_Landing' received command OFF
2019-11-24 17:17:40.188 [vent.ItemStateChangedEvent] - Light_Landing changed from 100 to 49
This immediately turns the Switch item back to On - although the light is dimmed. Turning the switch off a second time does turn the light off:
2019-11-24 17:20:31.363 [vent.ItemStateChangedEvent] - Light_Landing changed from 49 to 0
I’ve been through my rules multiple times and don’t see anything that accounts for this behaviour - has something changed with how Dimmer objects work in 2.4?
