- Platform information:
- Hardware: _RPI 3B+
- OS: _Rasbian / Buster
- Java Runtime Environment: _which is installed with buster
- openHAB version: 2.5.0-1
- Issue of the topic:
When I enter the following item expression in to the sitemap file:
Dimmer item=LB1_Brightness label=“Lamp bed rechts” {channel=hue:0220:00212E04F655:1:brightness}
The following error occures when processing the sitemap:
2020-01-05 13:59:08.317 [WARN ] [el.core.internal.ModelRepositoryImpl] - Configuration model ‘default.sitemap’ has errors, therefore ignoring it: [25,13]: required (…)+ loop did not match anything at input ‘Dimmer’
[27,3]: missing EOF at ‘Group’
When i leave this out there no problems with the sitemap file and it works all fine.
I got LB1_Brightness from the item bame in the paper-UI , i got hue:0220:00212E04F655:1:brightness from the channel definition in the paper-ui
I am a beginner and possibly I do something wrong , could naybody give me advice ?
Many thanks,
Frank
