The timeout of 2 second for an DOUBLE_PRESSED event is to high.
The following is happening:
1st press -> you get BUTTON -> SHORT_PRESSED event fired
2nd press within 2sec BUTTON-> DOUBLE_PRESSED event fired
In a scenario where I press once to switch a on a lamp and want switch it within 2 secs off, the click is ignored.
The DOUBLE_PRESSED is useless because it is alway accompanied with a SINGLE_PRESSED.
In a scenario where I would be interested to use DOUBLE_PRESSED, e.g. to toggle through light color/temperture scenes, I cannot, because the SINGLE_PRESSED spoils the game.
Expected behavior:
DOUBLE_PRESSED should have a waiting time of e.g. 0.3-0.5s, short enough to be waited on (SINGLE_PRESSED delayed) in order to get just the DOUBLE_PRESSED only and used it as such.
