Got it, get list of things from the bridge added to the top of the discovery method:
List<Thing> things = accountHandler.getThing().getThings();
Private Variable added:
private Boolean deviceAdded;
Then when i query the api:
for (int s = 0; s < structures.size(); s++) {
sId = structures.get(s).getGroupId();
sName = structures.get(s).getName();
logger.debug("Structure Id {} with name {} Found", sId,sName);
for (int d = 0; d < structures.get(s).getDevices().size(); d++) {
dType = structures.get(s).getDevices().get(d).getCat().toString();
dId = structures.get(s).getDevices().get(d).getDeviceId().toString();
array1 = dId.split("-");
sdId = array1[1].toString();
deviceAdded = false;
for (int i = 0; i < things.size(); i++) {
String Id = things.get(i).getConfiguration().get("sdId").toString();
if(Id.equals(sdId)) {
deviceAdded = true;
if (deviceAdded == false) {
\\add the thing here
This was all I needed to know (how to query the already added things):
Hopefully it will help anyone else diving in to the realms of development.
