[SOLVED] Docker Help - Error creating mount source
Just trying to install a clean version of openhab (in docker) on a new server I am building.
I have installed Ubuntu 18.04.1 server. Installed the docker snap (during ubuntu’s installation).
I have created the openhab user and group with is 9001 and then created the necessary folders
/opt/openhab/(conf, userdata, addons) all owned and writable bt the openhab (9001) user.
Then tried to install openhab with;
sudo docker run
–name openhab
–net=host
–tty
-v /etc/localtime:/etc/localtime:ro
-v /etc/timezone:/etc/timezone:ro
-v /opt/openhab/conf:/openhab/conf
-v /opt/openhab/userdata:/openhab/userdata
-v /opt/openhab/addons:/openhab/addons
-d
–restart=always
openhab/openhab:2.4.0
and I get;
docker: Error response from daemon: error while creating mount source path ‘/opt/openhab/conf’: mkdir /opt/openhab: read-only file system.
Has anyone seen this before.
Thanks for any help
James
It looks like it was docker-snap.. Switching out to docker-ce solved this..
James
Apologies for the ignorance, but how can I determine what Docker version I’m using and how do I uninstall Docker Snap and re-install the official version of Docker.
Is it possible that both version can be installed side-by-side for some reason?
Update
Found the solution:
Here’s how:
  1. Run sudo snap list to see verify that Docker is installed with snap. If you see it on the list, it is.
  2. Then run: snap remove docker
  3. Reboot.
