[SOLVED] Dump first text rule
I’m on OH2, RaspberriPi (openhabian), Visual Studio Code.
Now I’m trying to create my first text rule. Just guessing the steps after few days researching the community’s posts.
My script do not execute the sendCommand:
rule “x”
Item A received command ON
B.sendCommand(ON)
The log:
2018-05-14 15:41:33.464 [ome.event.ItemCommandEvent] - Item ‘22_switch_binary’ received command ON
2018-05-14 15:41:33.478 [vent.ItemStateChangedEvent] - 22_switch_binary changed from OFF to ON
22_swich_binary is the A wallplug (A = name from HabAdmin).
In details: A = wallplug, B = wallplug (boths from Fibaro, synced with OH via Z-wave binding). I’m able to control the wallplugs via HabAdmin or PaperUI/Rules.
Any feedback for step by step tutorial for basic text rules in OH and Visual Studio Code?
Thanks,
T
First, please use the code fences when posting code:
rule “x”
    logInfo("TEST RULE","TEST RULE")
    B.sendCommand(ON)
The logInfo statement will show you if the rule is executed at all in the logs
I’ve included logInfo right now. The log shows when item A received command ON only, ’
LOG:
Two things there, either the item is not defined and never receives the command but as we saw in the log, it does so that’s not it.
Second, your rule has errors and is not parse into the engine.
What happens in openhab.log when you save the rule file?
2018-05-14 18:05:07.325 [INFO ] [el.core.internal.ModelRepositoryImpl] - Refreshing model ‘testus.rules’
2018-05-14 18:05:07.345 [WARN ] [el.core.internal.ModelRepositoryImpl] - Configuration model ‘testus.rules’ is either empty or cannot be parsed correctly!
2018-05-14 18:05:07.607 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model ‘testus.rules’
There are errors!!
Can you post the whole file, please?
This is the all content of the file:
rule “t”
//Thread::sleep(3000)
logInfo(“TEST RULE”,“TEST RULE”)
B.sendCommand(ON)
Delete the file
Create another one and TYPE in the following
Don’t copy and paste (2 reasons - copying and pasting from a browser can introduce and or change character) - typing code helps learning it)
Do you actually have an item A and and item B
rule "t"
    B.sendCommand(ON)
I have these 2 wall plugs, named A and B into HabAdmin.
I’ve followed your instructions: create a new file, type the code… then again error into the log:
2018-05-14 18:16:34.747 [WARN ] [el.core.internal.ModelRepositoryImpl] - Configuration model ‘testus2.rules’ is either empty or cannot be parsed correctly!
2018-05-14 18:16:35.003 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model ‘testus2.rules’
2018-05-14 18:18:49.901 [ome.event.ItemCommandEvent] - Item ‘22_switch_binary’ received command ON
2018-05-14 18:18:49.911 [vent.ItemStateChangedEvent] - 22_switch_binary changed from OFF to ON
Your item is named 22_switch_binary
Replace B by the name of the other item
rule "t"
    Item 22_switch_binary received command ON
    B.sendCommand(ON)
Update the script:
rule “t”
logInfo(“TEST RULE”, “TEST RULE”)
wall_plug_node11_switch_binary.sendCommand(ON)
The log shows errors again:
2018-05-14 18:26:47.167 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model ‘testus2.rules’
2018-05-14 18:26:47.186 [WARN ] [el.core.internal.ModelRepositoryImpl] - Configuration model ‘testus2.rules’ is either empty or cannot be parsed correctly!
2018-05-14 18:26:47.288 [WARN ] [el.core.internal.ModelRepositoryImpl] - Configuration model ‘testus2.rules’ has errors, therefore ignoring it: [3,5]: no viable alternative at input ‘22_’
I was afraid of that
OH doesn’t like item names starting with numbers
Rename your items
22_switch_binary to switch_binary_22
and the other one
Change them in the rule and it should work
Going to work now. Good luck
Thanks, V. I’ll try to change the names…
Changed the names of the items (without numbers first) but the same errors are displayed in the log:
'rule “t”
Item switch_22_bathroom received command ON
switch_11_ac.sendCommand(ON)
LOG:
'2018-05-14 18:50:43.079 [INFO ] [el.core.internal.ModelRepositoryImpl] - Refreshing model ‘testus2.rules’
2018-05-14 18:50:43.099 [WARN ] [el.core.internal.ModelRepositoryImpl] - Configuration model ‘testus2.rules’ is either empty or cannot be parsed correctly!
2018-05-14 18:50:43.351 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model ‘testus2.rules’
Restarted the RaspberryPi / OH2.
No ideea where to go from here. :frowning:
Your rule file load. You can ignore the first error message. It should work now.
Still not working.
Show me the logs when you switch 22 on
It’s working now, V! Thanks a lot, man.
So, the OH2 doesn’t like items with start with number - that’s the conclusion.
Please like and mark the thread as solved
Items starting with a number will work but you can’t use them in the rules…
