icons named secur_my-open.png, and secur_my-closed.png and secur_my.png for fail / no state
on any state here the secur_my.png is shown, not changing for open or closed states … the visibility works fine, just not the icons, btw, i tried to just for testing remove the whole mapping stuff in case something goes wrong here, didnt help. also with the windows the maps and icons are working
nope, i didnt restart, but now i checked and it works … sometimes its smarter to let it go, just wait a few hours and then check again …
was looking for an error for almost an hour and now it works without a change … whatever it was, at least now it works as intended and i can confirm, i am not too dumb
I am actually having the same issue on OH2.4 and I’m afraid it still not working for me, even after a full reboot of OH (running openhabian on an RPi 3B+).
Using custom icon set for a leak sensor. I have 3 files seven under the icons/classic folder:
All 3 worked just fine for me with OH 2.3 with the same items.
Anyone…!?
Just as an update, I did that if I go to Configure on: PaperUI -> Configuration -> Services -> UI -> Basic UI, and change the “Icon format” from “vector” to “bitmap”, it will show the icons in the browser. However, no such luck with the iOS app UI. The icons will still not show up there.
Bug…!?
I have to say, I honestly believed your suggestion would BS… but it seems like the iOS app takes it’s configuration from the classic UI…!
I did not have classic UI installed, so, installed it and changed the icon format to bitmap as well from vector and lo and behold… iOS icons now appear as well…!!!
I am interested though, why this change all of a sudden to manually configure something that worked without any issues up to 2.3. Devs!?
I’m surprised too
but I did wonder if IoS app was using some method to get icons dating from OH1
Didn’t think about having to install ClassicUI , that’s a big drawback really. Maybe there’s textfile that can be edited to look like Classic=bitmap to avoid the install.
I’m guessing you already found the github issues list, and should make the point that this part of IoS needs modernizing.
@Moshe_Dahan, @rossko57 I can’t remember where I read it, but it’s been mentioned that iOS only works with bitmap. No mention about needing to have ClassicUI installed but good find none the less.
@Schelli thanks for editing the title to start with [Solved]. Also, if you would, please click the square box on the post that provided the solution.
