I would guess it’s actually working as it should. Some bindings - zwave is the one that springs to mind - now supply default mappings for Items.
When you use the Group widget in a sitemap, it is supposed to show the default display of each Item.
You could confirm that is what is going by putting one of your Items in its own sitemap line for a test.
What I found with my motion sensor switch is that appears to be the default rendering if the channel name has the word alarm in it. I do not have the Triggered / Untriggered icons here.
Just for information, the documentation may help you here as it should describe this. I don’t know what devices you are referring to, but as an example I pick the Aeon 4 in 1 motion sensor.
The channels list shows the states -:
This information is consolidated into the documentation from the binding configuration files, and the device database, so it should be correct.
Understood - I was just commenting as there was discussion about what channels these states were applicable to and I just wanted to point out that there is a way to find this out without guessing or assuming (for example) that channels starting with alarm have mapping and others don’t…
Is there any easy way to override the default? In my case the motion sensor was envisioned for security purposes so the channel defaults to Alarm. I am using it just as a sensor to detect motion, so Alarm makes little sense in my situation.
