[SOLVED] Eclipse IDE Show A bunch of errors on newly setup environment
I followed all the steps in Eclipse IDE | openHAB until step 6 of “Debugging an Add-on”, and I get a bunch of errors (note this I chose Openhab Development only during setup) when run Debug OSGi without any bundles/or add on. Hopefully someone can share your similar experience and how to resolve it as Im coming from 2.4 IDE (more straight forward). Thanks.
! could not resolve the bundles:
! org.osgi.framework.FrameworkEvent[source=org.eclipse.xtext.xbase_2.19.0.v20190902-0952 [110]]
org.osgi.framework.BundleException: Could not resolve module: org.eclipse.xtext.xbase [110]
Unresolved requirement: Import-Package: com.ibm.icu.text; version=“4.0.0”; resolution:=“optional”
Unresolved requirement: Import-Package: javax.annotation
→ Export-Package: javax.annotation; bundle-symbolic-name=“com.eclipsesource.jaxrs.jersey-all”; bundle-version=“2.22.2”; version=“1.2.0”
com.eclipsesource.jaxrs.jersey-all [3]
Unresolved requirement: Import-Package: javax.activation
at org.eclipse.osgi.container.Module.start(Module.java:447)
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.incStartLevel(ModuleContainer.java:1685)
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.incStartLevel(ModuleContainer.java:1664)
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.doContainerStartLevel(ModuleContainer.java:1627)
at org.eclipse.osgi.container.SystemModule.startWorker(SystemModule.java:267)
at org.eclipse.osgi.container.Module.doStart(Module.java:584)
at org.eclipse.osgi.container.Module.start(Module.java:452)
at org.eclipse.osgi.container.SystemModule.start(SystemModule.java:191)
at org.eclipse.osgi.internal.framework.EquinoxBundle.start(EquinoxBundle.java:431)
at org.eclipse.osgi.internal.framework.EquinoxBundle.start(EquinoxBundle.java:450)
at org.eclipse.osgi.launch.Equinox.start(Equinox.java:118)
at aQute.launcher.Launcher.activate(Launcher.java:463)
at aQute.launcher.Launcher.launch(Launcher.java:334)
at aQute.launcher.Launcher.run(Launcher.java:143)
at aQute.launcher.Launcher.main(Launcher.java:121)
at aQute.launcher.pre.EmbeddedLauncher.executeWithRunPath(EmbeddedLauncher.java:154)
at aQute.launcher.pre.EmbeddedLauncher.findAndExecute(EmbeddedLauncher.java:119)
at aQute.launcher.pre.EmbeddedLauncher.main(EmbeddedLauncher.java:51)
! org.osgi.framework.FrameworkEvent[source=com.eclipsesource.jaxrs.jersey-all_2.22.2 [3]]
org.osgi.framework.BundleException: Could not resolve module: com.eclipsesource.jaxrs.jersey-all [3]
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.incStartLevel(ModuleContainer.java:1665)
! org.osgi.framework.FrameworkEvent[source=com.eclipsesource.jaxrs.publisher_5.3.1.201602281253 [4]]
org.osgi.framework.BundleException: Could not resolve module: com.eclipsesource.jaxrs.publisher [4]
Unresolved requirement: Import-Package: javax.ws.rs.core; version=“[2.0.0,3.0.0)”
→ Export-Package: javax.ws.rs.core; bundle-symbolic-name=“com.eclipsesource.jaxrs.jersey-all”; bundle-version=“2.22.2”; version=“2.0.0”; uses:=“javax.ws.rs.ext,javax.ws.rs,javax.xml.bind.annotation.adapters,javax.xml.namespace,javax.xml.bind.annotation”
Unresolved requirement: Import-Package: javax.ws.rs; version=“[2.0.0,3.0.0)”
→ Export-Package: javax.ws.rs; bundle-symbolic-name=“com.eclipsesource.jaxrs.jersey-all”; bundle-version=“2.22.2”; version=“2.0.0”; uses:=“javax.ws.rs.core,javax.ws.rs.ext”
! org.osgi.framework.FrameworkEvent[source=jollyday_0.5.8 [9]]
org.osgi.framework.BundleException: Could not resolve module: jollyday [9]
Unresolved requirement: Import-Package: javax.xml.bind
Welcome to Apache Felix Gogo
My bad.. I ignored the requirement that it must be run in Java JDK 1.8, instead I execute the package on Java JRE 11.
