Does anyone know if i can emulate a 433 temp sensor, fex Oregon, with openhab and rfxtrx?
I would be great to redistribute temp information that openhab have control over.
Kim
Kim
You want to send temperature message from openHAB via RFXtrx? If yes, RFXtrx doesn’t support that, therefore not supported by the openHAB either.
Thanks.
Do you know if it is possible with any other device?
you could possibly use a raspberry pi or arduino with the necessary radio hardware and software to send a suitable message to either RFXcom or Oregon reciever
Found this
https://www.hackster.io/sfrwmaker/make-your-own-remote-temperature-humidity-sensor-464f63
