I’m having some trouble with the EchoFlex Enocean single rocker switch. I’ve also got a couple of Enocean temperature sensors and they are working fine, so I believe that I’ve got the binding configured properly. I can see the rocker switch packets being received in the openhab.log and in the events.log I can see the corresponding ON and OFF commands. However; the openhab.app fails to update the Stairs Switch icon. Any idea on what I’m missing here?
Thanks,
Dave
Setup
Hardware:
Raspberry Pi 2
Razberry Z-Wave Daughter Card
Enocean USB300U
EchoFlex PTM265U Rocker Switch
Enocean STM310U Temperature Sensor
Enocean STM320U Magnetic Contact Transmitter Module
Below is my default.items
Group All
Group gThirdFloor "3rd Floor" <firstfloor> (All)
Group TF_Landing "Landing" (gThirdFloor)
Switch TF_Landing_Switch "Landing Switch" <switch> (TF_Landing) { zwave="2:0:command=SWITCH_BINARY" }
Group gSecondFloor "2nd Floor" <firstfloor> (All)
Group SF_Landing "Landing" (gSecondFloor)
Switch SF_TF_Stairs_Switch "Third Floor Switch" (SF_Landing) {enocean="{id=00:89:84:CC, eep=F6:02:01}"}
Group SF_Emmetts_Room "Emmett's Room" <bedroom> (gSecondFloor)
Number Emmetts_Room_Temp "Temperature [%.1f °C]" <temperature> (SF_Emmetts_Room) { enocean="id=01:80:E4:BD, eep=A5:02:05, parameter=TEMPERATURE" }
Number TF_Temperature "Temperature [%.1f °C]" <temperature> (gThirdFloor) { enocean="id=01:81:11:99, eep=A5:02:05, parameter=TEMPERATURE" }
Default.sitemap
sitemap default label="Main Menu"
Frame label="3rd Floor" {
Switch item=TF_Landing_Switch label="Landing Switch"
Text item=TF_Temperature icon="temperature"
Frame label="2nd Floor" {
Switch item=SF_TF_Stairs_Switch label="Stairs Switch"
Frame label="Emmett's Room" {
Text item=Emmetts_Room_Temp icon="temperature"
Here’s an example of the packets being received from the openhab.log
2015-09-11 00:12:35.073 [DEBUG] [.e.internal.bus.EnoceanBinding] - Packet received: RadioPacketRPS[header=[Header: dataLength=00, optionalDataLength=07, packetType=01, crc8h=6C], payload=Payload: data=[], optionaldata=[01, FF, FF, FF, FF, 42, 00], crc8d=-62], raw=[55, 00, 00, 07, 01, 6C, 01, FF, FF, FF, FF, 42, 00, C2], [sender=00:2B:26:39, repeaterCount=0]
2015-09-11 00:12:35.380 [DEBUG] [.e.internal.bus.EnoceanBinding] - Packet received: RadioPacketRPS[header=[Header: dataLength=00, optionalDataLength=07, packetType=01, crc8h=6C], payload=Payload: data=[], optionaldata=[01, FF, FF, FF, FF, 45, 00], crc8d=-87], raw=[55, 00, 00, 07, 01, 6C, 01, FF, FF, FF, FF, 45, 00, A9], [sender=00:2B:26:39, repeaterCount=0]
2015-09-11 00:12:38.085 [DEBUG] [.e.internal.bus.EnoceanBinding] - Packet received: RadioPacketRPS[header=[Header: dataLength=00, optionalDataLength=07, packetType=01, crc8h=6C], payload=Payload: data=[], optionaldata=[01, FF, FF, FF, FF, 40, 00], crc8d=-24], raw=[55, 00, 00, 07, 01, 6C, 01, FF, FF, FF, FF, 40, 00, E8], [sender=00:2B:26:39, repeaterCount=0]
2015-09-11 00:12:38.303 [DEBUG] [.e.internal.bus.EnoceanBinding] - Packet received: RadioPacketRPS[header=[Header: dataLength=00, optionalDataLength=07, packetType=01, crc8h=6C], payload=Payload: data=[], optionaldata=[01, FF, FF, FF, FF, 45, 00], crc8d=-87], raw=[55, 00, 00, 07, 01, 6C, 01, FF, FF, FF, FF, 45, 00, A9], [sender=00:2B:26:39, repeaterCount=0]
2015-09-11 00:12:39.116 [DEBUG] [.e.internal.bus.EnoceanBinding] - Packet received: RadioPacketRPS[header=[Header: dataLength=00, optionalDataLength=07, packetType=01, crc8h=6C], payload=Payload: data=[], optionaldata=[01, FF, FF, FF, FF, 48, 00], crc8d=64], raw=[55, 00, 00, 07, 01, 6C, 01, FF, FF, FF, FF, 48, 00, 40], [sender=00:2B:26:39, repeaterCount=0]
2015-09-11 00:12:39.324 [DEBUG] [.e.internal.bus.EnoceanBinding] - Packet received: RadioPacketRPS[header=[Header: dataLength=00, optionalDataLength=07, packetType=01, crc8h=6C], payload=Payload: data=[], optionaldata=[01, FF, FF, FF, FF, 48, 00], crc8d=64], raw=[55, 00, 00, 07, 01, 6C, 01, FF, FF, FF, FF, 48, 00, 40], [sender=00:2B:26:39, repeaterCount=0]
2015-09-11 00:12:39.866 [DEBUG] [.e.internal.bus.EnoceanBinding] - Packet received: RadioPacketRPS[header=[Header: dataLength=00, optionalDataLength=07, packetType=01, crc8h=6C], payload=Payload: data=[], optionaldata=[01, FF, FF, FF, FF, 3F, 00], crc8d=-119], raw=[55, 00, 00, 07, 01, 6C, 01, FF, FF, FF, FF, 3F, 00, 89], [sender=00:2B:26:39, repeaterCount=0]
Events.log
2015-09-11 00:12:39 - TF_Landing_Switch received command ON
2015-09-11 00:12:39 - TF_Landing_Switch received command OFF
2015-09-11 00:12:42 - TF_Temperature state updated to 24
