Hi friends,
i have setup telegram addon for sending notificaton on my mobile.
bots=bot1
bot1.chatId=xxxxxxxxxx
bot1.token=xxxxxxxxxxxxxxxxxxxxxxxxxxxx
i have setup rule for notificaton generation.
Rules file is as below.
rule "Send telegram with Fixed Message"
Item Socket1 changed
sendTelegram("bot1","item Socket1 changed to %s", Socket1.state.toString)
Whenever Socket1 status changed then telegram notification generated. i setup telegram bot as mentioned in openhab document
URL of documentation :- Openhab telegram addon action
i recieved notification on telegram but some time notification not recieed(once every 20-25 time).
i noticied below mentioned error log during rule triggaring.
2019-08-08 22:31:52.959 [WARN ] [ab.action.telegram.internal.Telegram] - Transport error: {}
java.net.SocketTimeoutException: Read timed out
at java.net.SocketInputStream.socketRead0(Native Method) ~[?:?]
at java.net.SocketInputStream.socketRead(SocketInputStream.java:116) ~[?:?]
at java.net.SocketInputStream.read(SocketInputStream.java:171) ~[?:?]
at java.net.SocketInputStream.read(SocketInputStream.java:141) ~[?:?]
at sun.security.ssl.InputRecord.readFully(InputRecord.java:465) ~[?:?]
at sun.security.ssl.InputRecord.read(InputRecord.java:503) ~[?:?]
at sun.security.ssl.SSLSocketImpl.readRecord(SSLSocketImpl.java:983) ~[?:?]
at sun.security.ssl.SSLSocketImpl.performInitialHandshake(SSLSocketImpl.java:1385) ~[?:?]
at sun.security.ssl.SSLSocketImpl.writeRecord(SSLSocketImpl.java:757) ~[?:?]
at sun.security.ssl.AppOutputStream.write(AppOutputStream.java:123) ~[?:?]
at java.io.BufferedOutputStream.flushBuffer(BufferedOutputStream.java:82) ~[?:?]
at java.io.BufferedOutputStream.flush(BufferedOutputStream.java:140) ~[?:?]
at org.apache.commons.httpclient.methods.EntityEnclosingMethod.writeRequestBody(EntityEnclosingMethod.java:506) ~[?:?]
at org.apache.commons.httpclient.HttpMethodBase.writeRequest(HttpMethodBase.java:2114) ~[?:?]
at org.apache.commons.httpclient.HttpMethodBase.execute(HttpMethodBase.java:1096) ~[?:?]
at org.apache.commons.httpclient.HttpMethodDirector.executeWithRetry(HttpMethodDirector.java:398) ~[?:?]
at org.apache.commons.httpclient.HttpMethodDirector.executeMethod(HttpMethodDirector.java:171) ~[?:?]
at org.apache.commons.httpclient.HttpClient.executeMethod(HttpClient.java:397) ~[?:?]
at org.apache.commons.httpclient.HttpClient.executeMethod(HttpClient.java:323) ~[?:?]
at org.openhab.action.telegram.internal.Telegram.sendTelegram(Telegram.java:100) ~[?:?]
at org.openhab.action.telegram.internal.Telegram.sendTelegram(Telegram.java:146) ~[?:?]
at sun.reflect.GeneratedMethodAccessor164.invoke(Unknown Source) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.invokeOperation(XbaseInterpreter.java:1086) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.invokeOperation(XbaseInterpreter.java:1061) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._invokeFeature(XbaseInterpreter.java:1047) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.invokeFeature(XbaseInterpreter.java:992) ~[?:?]
at org.eclipse.smarthome.model.script.interpreter.ScriptInterpreter.invokeFeature(ScriptInterpreter.java:151) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._doEvaluate(XbaseInterpreter.java:902) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._doEvaluate(XbaseInterpreter.java:865) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.doEvaluate(XbaseInterpreter.java:224) ~[?:?]
at org.eclipse.smarthome.model.script.interpreter.ScriptInterpreter.doEvaluate(ScriptInterpreter.java:226) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.internalEvaluate(XbaseInterpreter.java:204) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._doEvaluate(XbaseInterpreter.java:447) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.doEvaluate(XbaseInterpreter.java:228) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.evaluate(XbaseInterpreter.java:190) ~[?:?]
at org.eclipse.smarthome.model.script.runtime.internal.engine.ScriptImpl.execute(ScriptImpl.java:82) ~[?:?]
at org.eclipse.smarthome.model.rule.runtime.internal.engine.RuleEngineImpl.lambda$2(RuleEngineImpl.java:341) ~[?:?]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.access$201(ScheduledThreadPoolExecutor.java:180) [?:?]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:293) [?:?]
how can i resolve this error???
