[SOLVED] Error in logfile
unfortunately I get some errors in my log and I have no idea what them cause. I hope you can support me with my logfile:
    2019-12-30 17:28:25.452 [ERROR] [org.quartz.core.JobRunShell         ] - Job DEFAULT.2019-12-30T17:28:25.442+01:00: Proxy for org.eclipse.xtext.xbase.lib.Procedures$Procedure0: [ | {
  org.eclipse.xtext.xbase.impl.XIfExpressionImpl@148ac36
} ] threw an unhandled Exception:
java.lang.reflect.UndeclaredThrowableException: null
	at com.sun.proxy.$Proxy177.apply(Unknown Source) ~[?:?]
	at org.eclipse.smarthome.model.script.internal.actions.TimerExecutionJob.execute(TimerExecutionJob.java:49) ~[?:?]
	at org.quartz.core.JobRunShell.run(JobRunShell.java:202) [107:org.eclipse.smarthome.core.scheduler:0.10.0.oh240]
	at org.quartz.simpl.SimpleThreadPool$WorkerThread.run(SimpleThreadPool.java:573) [107:org.eclipse.smarthome.core.scheduler:0.10.0.oh240]
Caused by: org.eclipse.smarthome.model.script.engine.ScriptExecutionException: The name 'SunsetTime' cannot be resolved to an item or type; line 6, column 26, length 10
	at org.eclipse.smarthome.model.script.interpreter.ScriptInterpreter.invokeFeature(ScriptInterpreter.java:141) ~[?:?]
	at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._doEvaluate(XbaseInterpreter.java:902) ~[?:?]
	at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._doEvaluate(XbaseInterpreter.java:865) ~[?:?]
	at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.doEvaluate(XbaseInterpreter.java:224) ~[?:?]
	at org.eclipse.smarthome.model.script.interpreter.ScriptInterpreter.doEvaluate(ScriptInterpreter.java:226) ~[?:?]
	at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.internalEvaluate(XbaseInterpreter.java:204) ~[?:?]
	at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._doEvaluate(XbaseInterpreter.java:768) ~[?:?]
	at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.doEvaluate(XbaseInterpreter.java:220) ~[?:?]
	at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._doEvaluate(XbaseInterpreter.java:500) ~[?:?]
	at org.eclipse.smarthome.model.script.interpreter.ScriptInterpreter._doEvaluate(ScriptInterpreter.java:243) ~[?:?]
	at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.doEvaluate(XbaseInterpreter.java:234) ~[?:?]
	at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.evaluateArgumentExpressions(XbaseInterpreter.java:1116) ~[?:?]
	at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._invokeFeature(XbaseInterpreter.java:1046) ~[?:?]
	at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.invokeFeature(XbaseInterpreter.java:992) ~[?:?]
	at org.eclipse.smarthome.model.script.interpreter.ScriptInterpreter.invokeFeature(ScriptInterpreter.java:151) ~[?:?]
	at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._doEvaluate(XbaseInterpreter.java:772) ~[?:?]
	at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._doEvaluate(XbaseInterpreter.java:872) ~[?:?]
	at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.doEvaluate(XbaseInterpreter.java:226) ~[?:?]
	at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._doEvaluate(XbaseInterpreter.java:458) ~[?:?]
	at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.doEvaluate(XbaseInterpreter.java:244) ~[?:?]
	at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._doEvaluate(XbaseInterpreter.java:447) ~[?:?]
	at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.doEvaluate(XbaseInterpreter.java:228) ~[?:?]
	at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.evaluate(XbaseInterpreter.java:190) ~[?:?]
	at org.eclipse.xtext.xbase.interpreter.impl.ClosureInvocationHandler.doInvoke(ClosureInvocationHandler.java:46) ~[?:?]
	at org.eclipse.xtext.xbase.interpreter.impl.AbstractClosureInvocationHandler.invoke(AbstractClosureInvocationHandler.java:29) ~[?:?]
	... 4 more
2019-12-30 17:28:25.644 [ERROR] [org.quartz.core.ErrorLogger         ] - Job (DEFAULT.2019-12-30T17:28:25.442+01:00: Proxy for org.eclipse.xtext.xbase.lib.Procedures$Procedure0: [ | {
} ] threw an exception.
org.quartz.SchedulerException: Job threw an unhandled exception.
	at org.quartz.core.JobRunShell.run(JobRunShell.java:213) [107:org.eclipse.smarthome.core.scheduler:0.10.0.oh240]
Caused by: java.lang.reflect.UndeclaredThrowableException
	at org.quartz.core.JobRunShell.run(JobRunShell.java:202) ~[?:?]
	... 1 more
	... 1 more
Please use code fences! in This case, as there are some lines with 4 or more spaces at the beginning, the whole log is distorted (and yes, you should have seen this when posting it :wink: )
Please use three backticks before and after the code (or in this case the log):
your code here
This will result in a much cleaner view: (I cut out the as well)
Caused by: org.eclipse.smarthome.model.script.engine.ScriptExecutionException: The name ā€˜SunsetTime’ cannot be resolved to an item or type; line 6, column 26, length 10
... 4 more
... 1 more
... 1 more
There is a line (no 9) which sais
Which may lead to the solution…
thanks for your reply and yes, I saw that the formatting was bad but I didnĀ“t know how to fix it… So thx for your advice, I already fixed it in my first post.
Anway, I have no idea what“s wrong with this SunsetTime-item. I have 3 items which belong to the astro binding:
SunsetTime1
SunsetTime2
SunsetTime3
I don“t see what is wrong here!?
You have SunsetTime1, SunsetTime2, SunsetTime3 but no SunsetTime. Every character matters. You are trying to use SunsetTime in a Rule and there is no Item by that name.
Thanks for the ā€œruleā€ hint, there I found my mistake! Fixed it and all is fine now!!
Thank you!
But no Item SunSetTime
Please tick the solution box under the post that solved you problem, thanks
