I have a simple rule that is supposed to subtract “100” from an item value, and write it to a new item.
rule "Smooth Watts3"
Item Watts3 changed
var Number Watts30 = Watts3.state as DecimalType
var Number Watts31 = Watts30 - 100;
if(Watts3.state > 100 || Watts3.state < 200)
Watts31.postUpdate(Watts31)
rule errors out with:
[ERROR] [untime.internal.engine.RuleEngineImpl] - Rule 'Smooth Watts3': 'postUpdate' is not a member of 'java.lang.Number'; line 78, column 5, length 27
where is the mistake?
the value of Watts3 is in format: “123.123”
