how can I track down the origin of the problem?
Thank you!
2019-12-22 00:11:10.005 [ERROR] [org.apache.felix.scr ] - bundle org.apache.felix.scr:2.1.16 (43)Error while loading components of bundle org.openhab.io.homekit:2.5.0 (263)
java.lang.ClassCastException: java.lang.String cannot be cast to java.lang.Long
at org.apache.felix.cm.impl.ConfigurationImpl.configure(ConfigurationImpl.java:659) ~[?:?]
at org.apache.felix.cm.impl.ConfigurationImpl.configureFromPersistence(ConfigurationImpl.java:619) ~[?:?]
at org.apache.felix.cm.impl.ConfigurationImpl.(ConfigurationImpl.java:194) ~[?:?]
at org.apache.felix.cm.impl.ConfigurationManager.listConfigurations(ConfigurationManager.java:552) ~[?:?]
at org.apache.felix.cm.impl.ConfigurationAdminImpl.listConfigurations(ConfigurationAdminImpl.java:190) ~[?:?]
at org.apache.felix.scr.impl.manager.RegionConfigurationSupport.findConfigurations(RegionConfigurationSupport.java:655) ~[?:?]
at org.apache.felix.scr.impl.manager.RegionConfigurationSupport.findSingletonConfiguration(RegionConfigurationSupport.java:554) ~[?:?]
at org.apache.felix.scr.impl.manager.RegionConfigurationSupport.configureComponentHolder(RegionConfigurationSupport.java:199) ~[?:?]
at org.apache.felix.scr.impl.BundleComponentActivator.setRegionConfigurationSupport(BundleComponentActivator.java:763) ~[?:?]
at org.apache.felix.scr.impl.helper.ConfigAdminTracker$1.addingService(ConfigAdminTracker.java:69) ~[?:?]
at org.apache.felix.scr.impl.helper.ConfigAdminTracker$1.addingService(ConfigAdminTracker.java:41) ~[?:?]
at org.osgi.util.tracker.ServiceTracker$Tracked.customizerAdding(ServiceTracker.java:941) ~[osgi.core-6.0.0.jar:?]
at org.osgi.util.tracker.ServiceTracker$Tracked.customizerAdding(ServiceTracker.java:870) ~[osgi.core-6.0.0.jar:?]
at org.osgi.util.tracker.AbstractTracked.trackAdding(AbstractTracked.java:256) ~[osgi.core-6.0.0.jar:?]
at org.osgi.util.tracker.AbstractTracked.trackInitial(AbstractTracked.java:183) ~[osgi.core-6.0.0.jar:?]
at org.osgi.util.tracker.ServiceTracker.open(ServiceTracker.java:318) ~[osgi.core-6.0.0.jar:?]
at org.osgi.util.tracker.ServiceTracker.open(ServiceTracker.java:261) ~[osgi.core-6.0.0.jar:?]
at org.apache.felix.scr.impl.helper.ConfigAdminTracker.(ConfigAdminTracker.java:86) ~[?:?]
at org.apache.felix.scr.impl.BundleComponentActivator.(BundleComponentActivator.java:275) ~[?:?]
at org.apache.felix.scr.impl.Activator.loadComponents(Activator.java:380) ~[?:?]
at org.apache.felix.scr.impl.Activator.access$200(Activator.java:49) ~[?:?]
at org.apache.felix.scr.impl.Activator$ScrExtension.start(Activator.java:264) ~[?:?]
at org.apache.felix.scr.impl.AbstractExtender.createExtension(AbstractExtender.java:196) ~[?:?]
at org.apache.felix.scr.impl.AbstractExtender.modifiedBundle(AbstractExtender.java:169) ~[?:?]
at org.apache.felix.scr.impl.AbstractExtender.modifiedBundle(AbstractExtender.java:49) ~[?:?]
at org.osgi.util.tracker.BundleTracker$Tracked.customizerModified(BundleTracker.java:482) ~[osgi.core-6.0.0.jar:?]
at org.osgi.util.tracker.BundleTracker$Tracked.customizerModified(BundleTracker.java:415) ~[osgi.core-6.0.0.jar:?]
at org.osgi.util.tracker.AbstractTracked.track(AbstractTracked.java:232) ~[osgi.core-6.0.0.jar:?]
at org.osgi.util.tracker.BundleTracker$Tracked.bundleChanged(BundleTracker.java:444) ~[osgi.core-6.0.0.jar:?]
at org.eclipse.osgi.internal.framework.BundleContextImpl.dispatchEvent(BundleContextImpl.java:908) ~[org.eclipse.osgi-3.12.100.jar:?]
at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:230) ~[org.eclipse.osgi-3.12.100.jar:?]
at org.eclipse.osgi.framework.eventmgr.ListenerQueue.dispatchEventSynchronous(ListenerQueue.java:148) ~[org.eclipse.osgi-3.12.100.jar:?]
at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEventPrivileged(EquinoxEventPublisher.java:213) ~[org.eclipse.osgi-3.12.100.jar:?]
at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEvent(EquinoxEventPublisher.java:120) ~[org.eclipse.osgi-3.12.100.jar:?]
at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEvent(EquinoxEventPublisher.java:112) ~[org.eclipse.osgi-3.12.100.jar:?]
at org.eclipse.osgi.internal.framework.EquinoxContainerAdaptor.publishModuleEvent(EquinoxContainerAdaptor.java:168) ~[org.eclipse.osgi-3.12.100.jar:?]
at org.eclipse.osgi.container.Module.publishEvent(Module.java:476) ~[org.eclipse.osgi-3.12.100.jar:?]
at org.eclipse.osgi.container.Module.start(Module.java:467) ~[org.eclipse.osgi-3.12.100.jar:?]
at org.eclipse.osgi.internal.framework.EquinoxBundle.start(EquinoxBundle.java:383) ~[org.eclipse.osgi-3.12.100.jar:?]
at org.eclipse.osgi.internal.framework.EquinoxBundle.start(EquinoxBundle.java:402) ~[org.eclipse.osgi-3.12.100.jar:?]
at org.apache.karaf.features.internal.service.BundleInstallSupportImpl.startBundle(BundleInstallSupportImpl.java:165) ~[?:?]
at org.apache.karaf.features.internal.service.FeaturesServiceImpl.startBundle(FeaturesServiceImpl.java:1153) ~[?:?]
at org.apache.karaf.features.internal.service.Deployer.deploy(Deployer.java:1036) ~[?:?]
at org.apache.karaf.features.internal.service.FeaturesServiceImpl.doProvision(FeaturesServiceImpl.java:1062) ~[?:?]
at org.apache.karaf.features.internal.service.FeaturesServiceImpl.lambda$doProvisionInThread$13(FeaturesServiceImpl.java:998) ~[?:?]
at java.util.concurrent.FutureTask.run(FutureTask.java:266) [?:1.8.0_222]
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1149) [?:1.8.0_222]
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:624) [?:1.8.0_222]
at java.lang.Thread.run(Thread.java:748) [?:1.8.0_222]
