Now i have flashed the ESP, but now I get the following Serial Monitor-Output every 25ms:
rst:0x10 (RTCWDT_RTC_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT)
configsip: 0, SPIWP:0x10
clk_drv:0x00,q_drv:0x01,d_drv:0x00,cs0_drv:0x02,hd_drv:0x00,wp_drv:0x04
mode:DIO, clock div:2
load:0x09a40c01,len:20563313
ets Jun 8 2016 00:22:57
And if I try to erase it again and flash it, I get the following output:
C:\WINDOWS\system32>esptool.py --port COM3 erase_flash
esptool.py v2.5.1
Serial port COM3
Traceback (most recent call last):
File "C:\Program Files (x86)\Python36-32\Scripts\esptool.py-script.py", line 11, in <module>
load_entry_point('esptool==2.5.1', 'console_scripts', 'esptool.py')()
File "c:\program files (x86)\python36-32\lib\site-packages\esptool.py", line 2846, in _main
main()
File "c:\program files (x86)\python36-32\lib\site-packages\esptool.py", line 2547, in main
esp = ESPLoader.detect_chip(each_port, initial_baud, args.before, args.trace)
File "c:\program files (x86)\python36-32\lib\site-packages\esptool.py", line 244, in detect_chip
detect_port = ESPLoader(port, baud, trace_enabled=trace_enabled)
File "c:\program files (x86)\python36-32\lib\site-packages\esptool.py", line 213, in __init__
self._port = serial.serial_for_url(port)
File "c:\program files (x86)\python36-32\lib\site-packages\serial\__init__.py", line 88, in serial_for_url
instance.open()
File "c:\program files (x86)\python36-32\lib\site-packages\serial\serialwin32.py", line 62, in open
raise SerialException("could not open port {!r}: {!r}".format(self.portstr, ctypes.WinError()))
serial.serialutil.SerialException: could not open port 'COM3': PermissionError(13, 'Zugriff verweigert', None, 5)
Sorry for all those messages, but I am very confused
Thanks for your reply!
