Hi - The main issue is my events aren’t being persisted into InfluxDB.
I have read the threads on this and pretty certain I have checked it all but clearly I’m missing something and wondering if someone can help with an extra pair of eyes to spot my mistake in config.
All services are running as docker containers. I don’t believe that setup should have any impact, it just seems that OpenHab isn’t populating to influx. And even with debug level on the binding it’s not showing any issues. Can I debug any other item to check??
I can connect to Influx, Grafana and OpenHab all fine.
The PaperUI Configuration > System has InfluxDB set for persistence.
influxdb.conf
[http]
# Determines whether HTTP endpoint is enabled.
enabled = true
# Determines whether the Flux query endpoint is enabled.
# flux-enabled = false
# Determines whether the Flux query logging is enabled.
# flux-log-enabled = false
# The bind address used by the HTTP service.
bind-address = ":8086"
# Determines whether user authentication is enabled over HTTP/HTTPS.
auth-enabled = false
indent preformatted text by 4 spaces
influxdb.cfg
# The database URL, e.g. http://127.0.0.1:8086 or https://127.0.0.1:8084 .
# Defaults to: http://127.0.0.1:8086
url=http://172.16.44.11:8086
# The name of the database user, e.g. openhab.
# Defaults to: openhab
user=openhab
# The password of the database user.
password=xxxxxxx
# The name of the database, e.g. openhab.
db=openhab_db
# The retention policy to be used, needs to configured in InfluxDB
# Till v0.13: 'default', since v1.0: 'autogen'
retentionPolicy=autogen
if I execute
openhab> bundle:restart org.openhab.persistence.influxdb
the debug output looks like
15:19:56.992 [DEBUG] [b.internal.InfluxDBPersistenceService] - influxdb persistence service deactivated
15:19:57.000 [DEBUG] [l.InfluxDBPersistenceServiceActivator] - InfluxDB persistence bundle has been stopped.
15:19:57.004 [DEBUG] [l.InfluxDBPersistenceServiceActivator] - InfluxDB persistence bundle has been started.
15:19:57.029 [DEBUG] [b.internal.InfluxDBPersistenceService] - influxdb persistence service activated
15:19:57.033 [DEBUG] [b.internal.InfluxDBPersistenceService] - database status is OK, version is 1.7.8
a sample of the events are here
15:20:59.744 [INFO ] [smarthome.event.ItemStateChangedEvent] - SHT_1_Temperature_Degrees changed from 19.15 to 19.17
15:20:59.919 [INFO ] [smarthome.event.ItemStateChangedEvent] - GenericMQTTThing_Sht_1_humidity changed from 46.73 to 46.86
15:20:59.922 [INFO ] [smarthome.event.ItemStateChangedEvent] - SHT_1_Humidity_Humidity changed from 46.73 to 46.86
15:20:59.923 [INFO ] [smarthome.event.ItemStateChangedEvent] - SHT_1_Dewpoint_Dewpoint changed from 7.48 to 7.54
15:20:59.924 [INFO ] [smarthome.event.ItemStateChangedEvent] - SHT_1_Humidex_Humidex changed from 19.35 to 19.40
15:21:02.664 [INFO ] [smarthome.event.ItemStateChangedEvent] - Thermocouples_TC2 changed from 2.5 °C to 13.75 °C
15:21:05.775 [INFO ] [smarthome.event.ItemStateChangedEvent] - GenericMQTTThing_Sht_1_temp changed from 19.17 to 19.16
15:21:05.777 [INFO ] [smarthome.event.ItemStateChangedEvent] - GenericMQTTThing_sht_1_temp changed from 19.17 to 19.16
15:21:05.781 [INFO ] [smarthome.event.ItemStateChangedEvent] - SHT_1_Temperature_Degrees changed from 19.17 to 19.16
15:21:05.953 [INFO ] [smarthome.event.ItemStateChangedEvent] - GenericMQTTThing_Sht_1_humidity changed from 46.86 to 46.79
15:21:05.958 [INFO ] [smarthome.event.ItemStateChangedEvent] - SHT_1_Humidity_Humidity changed from 46.86 to 46.79
15:21:05.961 [INFO ] [smarthome.event.ItemStateChangedEvent] - SHT_1_Dewpoint_Dewpoint changed from 7.54 to 7.51
15:21:05.962 [INFO ] [smarthome.event.ItemStateChangedEvent] - SHT_1_Humidex_Humidex changed from 19.40 to 19.37
15:21:11.809 [INFO ] [smarthome.event.ItemStateChangedEvent] - GenericMQTTThing_Sht_1_temp changed from 19.16 to 19.14
15:21:11.811 [INFO ] [smarthome.event.ItemStateChangedEvent] - GenericMQTTThing_sht_1_temp changed from 19.16 to 19.14
15:21:11.812 [INFO ] [smarthome.event.ItemStateChangedEvent] - SHT_1_Temperature_Degrees changed from 19.16 to 19.14
15:21:11.996 [INFO ] [smarthome.event.ItemStateChangedEvent] - SHT_1_Dewpoint_Dewpoint changed from 7.51 to 7.49
15:21:11.999 [INFO ] [smarthome.event.ItemStateChangedEvent] - SHT_1_Humidex_Humidex changed from 19.37 to 19.35
15:21:17.085 [INFO ] [smarthome.event.ItemStateChangedEvent] - Thermocouples_TC2 changed from 13.75 °C to 9.25 °C
15:21:18.026 [INFO ] [smarthome.event.ItemStateChangedEvent] - GenericMQTTThing_Sht_1_humidity changed from 46.79 to 46.82
15:21:18.028 [INFO ] [smarthome.event.ItemStateChangedEvent] - SHT_1_Humidity_Humidity changed from 46.79 to 46.82
15:21:18.029 [INFO ] [smarthome.event.ItemStateChangedEvent] - SHT_1_Dewpoint_Dewpoint changed from 7.49 to 7.50
15:21:23.882 [INFO ] [smarthome.event.ItemStateChangedEvent] - GenericMQTTThing_Sht_1_temp changed from 19.14 to 19.11
15:21:23.884 [INFO ] [smarthome.event.ItemStateChangedEvent] - GenericMQTTThing_sht_1_temp changed from 19.14 to 19.11
and my persistence rules are:
Strategies {
everyMinute : "0 * * * * ?"
everyHour : "0 0 * * * ?"
everyDay : "0 0 0 * * ?"
default = everyChange
Items {
Thermocouples_TC0: strategy = everyMinute, restoreOnStartup
Thermocouples_TC1: strategy = everyMinute, restoreOnStartup
Thermocouples_TC2: strategy = everyMinute, restoreOnStartup
Thermocouples_TC4: strategy = everyMinute, restoreOnStartup
Thermocouples_TC8: strategy = everyMinute, restoreOnStartup
Thermocouples_TC9: strategy = everyMinute, restoreOnStartup
* : strategy = everyChange // persist every item
if I look at influx
Visit https://enterprise.influxdata.com to register for updates, InfluxDB server management, and monitoring.
Connected to http://localhost:8086 version 1.7.8
InfluxDB shell version: 1.1.1
> USE openhab_db
Using database openhab_db
> show GRANTS for openhab
database privilege
openhab_db ALL PRIVILEGES
test ALL PRIVILEGES
> SHOW users
user admin
admin true
openhab false
grafana false
> SHOW series
I have followed the InfluxDB+Grafana Persistance and graphing tutorial and Grafana successfully plots the sine wave.
Any help, troubleshooting ideas would be very welcome - thanks!
