I’m trying to modify an existing binding to access a device via https://. It is accessed via a local ip address, i.e. https://192.168.x.x/xxxx
I tried using HttpUtil.executeUrl() from org.eclipse.smarthome.io.net.http.HttpUtil. However, this resulted in an error, presumably because of common name mismatch. Furthermore I don’t think the CA is also verifiable through the standard CA.
How can I achieve the equivalent of curl --insecure using either HttpUtil.ExecuteUrl or is there another example of doing this using jetty?
Not an answer, but suggestion. I am not sure (ATM) which HTTP client library is used under the hood, but with most of them you have an option to ignore or override certificate verification policy.
My advice - check util sources and then check how to change (or give) hostname verifier/sal socket factory/trust resolver to “accept all”.
Yep. Already done that. Jetty is the recommended library to use. I’m just wondering if there’s already a straight forward, simple example. Right now I’m trying to decipher Jetty’s documentation and writing the code.
11:18:22.072 [TRACE] [p.internal.ExtensibleTrustManagerImpl] - Did NOT find trustManager by sslEngine peer/host: redacted:443
11:18:22.072 [TRACE] [p.internal.ExtensibleTrustManagerImpl] - Searching trustManager by Subject Alternative Names: [[2, redacted]]
11:18:22.073 [TRACE] [p.internal.ExtensibleTrustManagerImpl] - No specific trust manager found, falling back to default
After further digging, I found that the custom TlsTrustManagerProvider class needs to return either the common name or host:port in the getHostName() that would match. Since neither the common name nor the host is going to be predictable / constant, I cannot use this method.
So I am resorting to @rossgb’s suggestion with creating HttpClient(new SslContextFactory(true)). Thank you!
