[SOLVED] Extend rule to determine if
Hi all,
I started to implement a rule, sending me a Telegram message when e.g. a window is open for more than 15 minutes.
This works fine so far, however, I need a hand in extending the rule to stop the timer, when it’s closed again.
rule "Notify if window in guest toilet is open for too long"
    Item fenster_gaestewc changed to OPEN
    if (stopAlarmTimer === null)
        stopAlarmTimer = createTimer(now.plusSeconds(900)) [|
            stopAlarmTimer.cancel()
            stopAlarmTimer = null
            sendTelegram("bot2", "Das Fenster im Gäste-WC ist seit 15 Minuten offen!")
rule "Notify if frontdoor  is open for too long"
    Item hausflur_haustuer changed to OPEN
            sendTelegram("bot2", "Die Haustür ist seit 15 Minuten offen!")
I altered the rule as follows, but that results in no notification being sent at all, also LogInfo isn’t working:
var Timer gaestewc_Timer = null
var Timer haustuer_Timer = null
    if (fenster_gaestewc===CLOSED)
                        (gaestewc_Timer !==null)
                                logInfo("timer","[Timer] Fenster Gäste-WC geschlossen. Timer wird abgebrochen...")
                                gaestewc_Timer.cancel
                                gaestewc_Timer=null
        else if (fenster_gaestewc===OPEN)
                if (gaestewc_Timer===null)
                        gaestewc_Timer=createTimer(now.plusMinutes(15))
                                logInfo("timer","[Timer] Fenster Gäste-WC über 15 Minuten offen. Sende Notification...")
    if (hausflur_haustuer===CLOSED)
                        (haustuer_Timer !==null)
                                logInfo("timer","[Timer] Haustür geschlossen. Timer wird abgebrochen...")
                                haustuer_Timer.cancel
                                haustuer_Timer=null
        else if (hausflur_haustuer===OPEN)
                if (haustuer_Timer===null)
                        loginfo("timer","[Timer] Haustür geöffnet. Starte Timer...")
                        haustuer_Timer=createTimer(now.plusMinutes(15))
                                logInfo("timer","[Timer] Haustür über 15 Minuten offen. Sende Notification...")
What would need to be added to not send a notification in case it gets closed in the timeframe of 15 minutes?
Cheers,
Ben
You mustn’t check for ===CLOSED or OPEN, use === only ever if testing against null use == instead.
Thanks a bunch for your reply, could you elaborate? I went for === due to messages complaining in log, now completely lost how it would be correct.
=== null
but
== CLOSED
and
== NULL
Altered it as follows:
    if (fenster_gaestewc==CLOSED)
                                gaestewc_Timer=null
        else if (fenster_gaestewc==OPEN)
                if (gaestewc_Timer==NULL)
    if (hausflur_haustuer==CLOSED)
                                haustuer_Timer=null
        else if (hausflur_haustuer==OPEN)
                if (haustuer_Timer==NULL)
Resulting in:
2019-03-26 09:36:30.165 [INFO ] [el.core.internal.ModelRepositoryImpl] - Validation issues found in configuration model 'doors_windows_open.rules', using it anyway:
This expression is not allowed in this context, since it doesn't cause any side effects.
2019-03-26 09:36:30.167 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'doors_windows_open.rules'
2019-03-26 09:36:31.337 [INFO ] [el.core.internal.ModelRepositoryImpl] - Validation issues found in configuration model 'doors_windows_open.rules', using it anyway:
2019-03-26 09:36:31.345 [INFO ] [el.core.internal.ModelRepositoryImpl] - Refreshing model 'doors_windows_open.rules'
You mustn’t check the timer variable against NULL but against null, that was correct in your 1st version.
See also [SOLVED] Unexpected results with Val math operators - #5 by rlkoshak and [SOLVED] NULL | UNDEF | null | uninitialized - #4 by rlkoshak
                                gaestewc_Timer=null
                if (gaestewc_Timer==null)
                                haustuer_Timer=null
                if (haustuer_Timer==null)
results in:
2019-03-26 10:07:08.899 [INFO ] [el.core.internal.ModelRepositoryImpl] - Validation issues found in configuration model ‘doors_windows_open.rules’, using it anyway:
This expression is not allowed in this context, since it doesn’t cause any side effects.
The operator ‘==’ should be replaced by ‘===’ when null is one of the arguments.
2019-03-26 10:07:08.900 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model ‘doors_windows_open.rules’
2019-03-26 10:07:10.137 [INFO ] [el.core.internal.ModelRepositoryImpl] - Validation issues found in configuration model ‘doors_windows_open.rules’, using it anyway:
2019-03-26 10:07:10.162 [INFO ] [el.core.internal.ModelRepositoryImpl] - Refreshing model ‘doors_windows_open.rules’
because again you tested ==null which I told you you mustn’t.
Come on it’s not that difficult.
Sorry Markus to be such a pain in the back but I don’t get my head around it.
Above you said to not check against NULL but against null, that’s why I did it like that.
I seem lost…
Correct.
But I also said that to test against null you need to use === (not ==)
OK, altered it like that:
                                gaestewc_Timer=null
                                haustuer_Timer=null
(hope I got you right this time).
Resulting in:
2019-03-26 10:21:28.482 [INFO ] [el.core.internal.ModelRepositoryImpl] - Validation issues found in configuration model ‘doors_windows_open.rules’, using it anyway:
2019-03-26 10:21:28.484 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model ‘doors_windows_open.rules’
2019-03-26 10:21:29.647 [INFO ] [el.core.internal.ModelRepositoryImpl] - Validation issues found in configuration model ‘doors_windows_open.rules’, using it anyway:
2019-03-26 10:21:29.659 [INFO ] [el.core.internal.ModelRepositoryImpl] - Refreshing model ‘doors_windows_open.rules’
Also logInfo is not kicking in
You are missing the “if” in front of “(gaestewc_Timer !==null)”
Thanks. That removed the messages in logfile. However, loginfo isn’t logging anything so not sure if that solved everything.
The part
and
should use the state of the item and not the item itself…
so just add “.state” to fenster_gaestewc
Andreas
PS: The same for the door…
That brought me further, thank you Andreas.
I now at least saw 1 LogInfo when haustuer changes to open and when it changes to close and none for fenster_gaestewc, neither for OPEN nor for CLOSED.
Currentl rule:
    if (fenster_gaestewc.state==CLOSED)
                        if (gaestewc_Timer !==null)
                                gaestewc_Timer=null
        else if (fenster_gaestewc.state==OPEN)
    if (hausflur_haustuer.state==CLOSED)
                        if (haustuer_Timer !==null)
                                haustuer_Timer=null
        else if (hausflur_haustuer.state==OPEN)
                        logInfo("timer","[Timer] Haustür geöffnet. Starte Timer...")
Add logging (almost every other line if necessary) so you can tell what is being executed and what states your Items are in.
It would help us read the code as well if you used consistent indentation. Usually one indent should be one tab or four spaces.
If fenster_gaestewc closes and there is not Timer you will not get a log statement.
If fenster_gaestewc opens and there is a Timer you will not get a log statement
I tried to achieve logging by way of LogInfo.
In each state it now seems to work but not when fenster_gaestewc opens (no LogInfo executed)
You need to log out for ALL possible states so you can figure out what states your Items are and what parts of your code are executing. You currently only log out when the code works as you expect which tells you nothing when the code doesn’t work as you expect. You need to understand what your code is doing and for that you need MORE logging.
I didn’t dear asking but I’ll do it now:
I’d know how to do it in bash, powershell but not how I would do it in OpenHab (rules). Therefore I only used logInfo as this was the only thing I could think of
Yes. Use logInfo. You need MORE logInfo statement. You already know how to do it. You already have two log statements in that Rule already. You need a lot more.
