I have this very odd problem.
I installed my Zigbee dongle a coupple of hours ago on my OH3.2 (running openhabian on Rpi4). Its a EM357s-USB-LR dongle.
When I first installed it, it worked just fine. When online, and for some reason it found 3 unknown devices, which I´m not aware of. I couldnt really figure why these devices were unknown, so insted I tried to add another device which I know what is… When scanning it didnt find the device. Then I tried yet another device. But still it didn´t find anything.
I then thought, that maybe there was something with the cordinator and the devices, which used to run OH 2.5 some months ago. So I guess I would try to reinitialise the controller.
That seem like a very bad idea, cause after I Reinitialsed the controller, it will no longer turn to online. I get the:
Fail to start Zigbee transport layer
I have tried everything to bring it back online. Even removed everything and reinstalled the binding. But I end up with the same. Cleared cache etc, rebooted and even powered everything down. Nothing seems to get me past the faliure.
This is a debug logging of whats happning:
2022-02-25 01:24:40.672 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - ZigBee network starting
2022-02-25 01:24:40.673 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - Initialising ZigBee coordinator
2022-02-25 01:24:40.677 [DEBUG] [nding.zigbee.serial.ZigBeeSerialPort] - Connecting to serial port [/dev/ttyUSB0] at 115200 baud, flow control FLOWCONTROL_OUT_RTSCTS.
2022-02-25 01:24:40.677 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - null: networkStateUpdated called with state=INITIALISING
2022-02-25 01:24:40.744 [DEBUG] [nding.zigbee.serial.ZigBeeSerialPort] - Serial port [/dev/ttyUSB0] is initialized.
2022-02-25 01:24:45.288 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - Mesh Update Period 86400
2022-02-25 01:24:45.299 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - ZigBee Initialise: Previous device configuration was: channel=CHANNEL_11, PanID=20498, EPanId=688E4409B074A562
2022-02-25 01:24:45.300 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - Link key initialise 5A6967426565416C6C69616E63653039
2022-02-25 01:24:45.301 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - Network key initialise 1C842590C02AE89785E43F401D40C8EF
2022-02-25 01:24:45.302 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - Config: zigbee_trustcentremode=TC_JOIN_SECURE
2022-02-25 01:24:46.370 [WARN ] [.internal.EmberNetworkInitialisation] - Energy scan found all channels violate CCA threshold!
2022-02-25 01:24:46.373 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - null: networkStateUpdated called with state=OFFLINE
2022-02-25 01:24:46.376 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'zigbee:coordinator_ember:6a59deb05b' changed from UNKNOWN to OFFLINE: Failed to startup ZigBee transport layer
2022-02-25 01:24:46.378 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'zigbee:coordinator_ember:6a59deb05b' changed from OFFLINE: Failed to startup ZigBee transport layer to OFFLINE (COMMUNICATION_ERROR)
2022-02-25 01:24:51.376 [INFO ] [bee.handler.ZigBeeCoordinatorHandler] - ZigBee dongle inactivity timer. Reinitializing ZigBee
2022-02-25 01:24:51.381 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - null: networkStateUpdated called with state=SHUTDOWN
2022-02-25 01:24:51.463 [DEBUG] [nding.zigbee.serial.ZigBeeSerialPort] - Serial port '/dev/ttyUSB0' closed.
2022-02-25 01:24:51.465 [DEBUG] [ng.zigbee.ember.handler.EmberHandler] - Initializing ZigBee Ember serial bridge handler.
2022-02-25 01:24:51.467 [DEBUG] [ng.zigbee.ember.handler.EmberHandler] - ZigBee Ember Coordinator opening Port:'/dev/ttyUSB0' PAN:fa01, EPAN:CC6F548A07897CBB, Channel:11
2022-02-25 01:24:51.468 [DEBUG] [ng.zigbee.ember.handler.EmberHandler] - Ember end device poll timeout set to (169 * 2^9) = 86528 seconds
2022-02-25 01:24:51.471 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - Scheduling ZigBee start
2022-02-25 01:24:51.473 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'zigbee:coordinator_ember:6a59deb05b' changed from OFFLINE (COMMUNICATION_ERROR) to UNKNOWN
2022-02-25 01:24:52.473 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - ZigBee network starting
2022-02-25 01:24:52.475 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - Initialising ZigBee coordinator
2022-02-25 01:24:52.478 [DEBUG] [nding.zigbee.serial.ZigBeeSerialPort] - Connecting to serial port [/dev/ttyUSB0] at 115200 baud, flow control FLOWCONTROL_OUT_RTSCTS.
2022-02-25 01:24:52.478 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - null: networkStateUpdated called with state=INITIALISING
2022-02-25 01:24:52.551 [DEBUG] [nding.zigbee.serial.ZigBeeSerialPort] - Serial port [/dev/ttyUSB0] is initialized.
2022-02-25 01:24:57.262 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - Mesh Update Period 86400
2022-02-25 01:24:57.275 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - ZigBee Initialise: Previous device configuration was: channel=CHANNEL_11, PanID=20498, EPanId=688E4409B074A562
2022-02-25 01:24:57.276 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - Link key initialise 5A6967426565416C6C69616E63653039
2022-02-25 01:24:57.277 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - Network key initialise 1C842590C02AE89785E43F401D40C8EF
2022-02-25 01:24:57.278 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - Config: zigbee_trustcentremode=TC_JOIN_SECURE
2022-02-25 01:24:58.326 [WARN ] [.internal.EmberNetworkInitialisation] - Energy scan found all channels violate CCA threshold!
2022-02-25 01:24:58.329 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - null: networkStateUpdated called with state=OFFLINE
2022-02-25 01:24:58.330 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'zigbee:coordinator_ember:6a59deb05b' changed from UNKNOWN to OFFLINE: Failed to startup ZigBee transport layer
2022-02-25 01:24:58.333 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'zigbee:coordinator_ember:6a59deb05b' changed from OFFLINE: Failed to startup ZigBee transport layer to OFFLINE (COMMUNICATION_ERROR)
I really wonder how come this happed after I activated the Reinitialise controller. But it looks like something got stuck somewhere. And I have no idea how to get it to work again?
Maybe @chris ?
