I think since snapshot #1522 the Feed Binding
isn’t working properly anymore.
The thing status remains at:
Status: OFFLINE - CONFIGURATION_ERROR Invalid XML: Error on line 1: DOCTYPE ist nicht zulässig, wenn das Feature "http://apache.org/xml/features/disallow-doctype-decl" auf "true" gesetzt ist.
Any ideas how to fix it?
Warning in the logs:
2019-02-21 21:26:48.054 [WARN ] [ng.feed.internal.handler.FeedHandler] - Feed content is not valid: http://www.lebensmittelwarnung.de/bvl-lmw-de/app/feed/hessen.rss
com.rometools.rome.io.ParsingFeedException: Invalid XML: Error on line 1: DOCTYPE ist nicht zulässig, wenn das Feature "http://apache.org/xml/features/disallow-doctype-decl" auf "true" gesetzt ist.
at com.rometools.rome.io.WireFeedInput.build(WireFeedInput.java:236) ~[?:?]
at com.rometools.rome.io.SyndFeedInput.build(SyndFeedInput.java:150) ~[?:?]
at org.openhab.binding.feed.internal.handler.FeedHandler.fetchFeedData(FeedHandler.java:228) ~[?:?]
at org.openhab.binding.feed.internal.handler.FeedHandler.refreshFeedState(FeedHandler.java:111) ~[?:?]
at java.util.concurrent.FutureTask.runAndReset(FutureTask.java:308) [?:?]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.access$301(ScheduledThreadPoolExecutor.java:180) [?:?]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:294) [?:?]
Caused by: org.jdom2.input.JDOMParseException: Error on line 1: DOCTYPE ist nicht zulässig, wenn das Feature "http://apache.org/xml/features/disallow-doctype-decl" auf "true" gesetzt ist.
at org.jdom2.input.sax.SAXBuilderEngine.build(SAXBuilderEngine.java:232) ~[?:?]
at org.jdom2.input.sax.SAXBuilderEngine.build(SAXBuilderEngine.java:303) ~[?:?]
at org.jdom2.input.SAXBuilder.build(SAXBuilder.java:1196) ~[?:?]
at com.rometools.rome.io.WireFeedInput.build(WireFeedInput.java:233) ~[?:?]
... 10 more
Caused by: org.xml.sax.SAXParseException: DOCTYPE ist nicht zulässig, wenn das Feature "http://apache.org/xml/features/disallow-doctype-decl" auf "true" gesetzt ist.
at com.sun.org.apache.xerces.internal.util.ErrorHandlerWrapper.createSAXParseException(ErrorHandlerWrapper.java:203) ~[?:?]
at com.sun.org.apache.xerces.internal.util.ErrorHandlerWrapper.fatalError(ErrorHandlerWrapper.java:177) ~[?:?]
at com.sun.org.apache.xerces.internal.impl.XMLErrorReporter.reportError(XMLErrorReporter.java:400) ~[?:?]
at com.sun.org.apache.xerces.internal.impl.XMLErrorReporter.reportError(XMLErrorReporter.java:327) ~[?:?]
at com.sun.org.apache.xerces.internal.impl.XMLScanner.reportFatalError(XMLScanner.java:1472) ~[?:?]
at com.sun.org.apache.xerces.internal.impl.XMLDocumentScannerImpl$PrologDriver.next(XMLDocumentScannerImpl.java:914) ~[?:?]
at com.sun.org.apache.xerces.internal.impl.XMLDocumentScannerImpl.next(XMLDocumentScannerImpl.java:602) ~[?:?]
at com.sun.org.apache.xerces.internal.impl.XMLNSDocumentScannerImpl.next(XMLNSDocumentScannerImpl.java:112) ~[?:?]
at com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentScannerImpl.scanDocument(XMLDocumentFragmentScannerImpl.java:505) ~[?:?]
at com.sun.org.apache.xerces.internal.parsers.XML11Configuration.parse(XML11Configuration.java:841) ~[?:?]
at com.sun.org.apache.xerces.internal.parsers.XML11Configuration.parse(XML11Configuration.java:770) ~[?:?]
at com.sun.org.apache.xerces.internal.parsers.XMLParser.parse(XMLParser.java:141) ~[?:?]
at com.sun.org.apache.xerces.internal.parsers.AbstractSAXParser.parse(AbstractSAXParser.java:1213) ~[?:?]
at com.sun.org.apache.xerces.internal.jaxp.SAXParserImpl$JAXPSAXParser.parse(SAXParserImpl.java:643) ~[?:?]
at org.jdom2.input.sax.SAXBuilderEngine.build(SAXBuilderEngine.java:217) ~[?:?]
... 10 more
