I need help to get my Fibaro motion sensor to work. I have just purchased the sensor and I am trying to get it to work on my Mac via a Aeotec Z-stick gen5. when adding the sensor via paper UI/Things i get an “unidentified” message. Hovever I can see the sensor is online in PaperUI but I get no values from the sensor. All I get is NULL. Any ideas ? Same when I check in Habmin.
Hi Heiko,
Thank you for the reply. I realized that my impatience was the only thing wrong here. As you said, all I had to do was to wake up the sensor a few times and then it worked.
