Since I am using venetian blinds I need lamella support and therefore parameter 3 and 10 are set accordingly.
@Atsz: Since you are not using lamella support, there is no need to set parameter 3 to Blind position with Fibar Command, try changing 3 to Blind position with Z-Wave command. (the xml you provided states:
setting parameter 3 to Blind position with Fibar Command the fibar proprietary reports you are observing are triggered.
to collect full logs please in karaf run
log:set DEBUG org.openhab.binding.zwave
and upload the openhab.log to Z-Wave log viewer while using the HW switches.
The log viewer significantly improves readability and helps troubleshooting.
after collecting logs:
Ok, so it’s been a while but I finally could try starting from scratch (delete all Z-Wave things, install new binding, add things again) using the latest version of Z-Wave binding (2.4) and now all my Fibaro Rollershutters report manual interactions. Thanks for your help!
