Short summary: Dashboard and Paper UI show HTTP code 403, “Forbidden” on a fresh install on Raspberry Pi 3.
I just downloaded and started a fresh OH2 with the build number 565, offline package ( https://openhab.ci.cloudbees.com/job/openHAB-Distribution/565/ ).
Then I configured “packaging = demo” and started the server. After some time installing bundles, the console shows:
2016-11-02 22:32:33.920 [INFO ] [assic.internal.servlet.WebAppServlet] - Started Classic UI at /classicui/app
2016-11-02 22:32:34.986 [INFO ] [.dashboard.internal.DashboardService] - Started dashboard at /start
2016-11-02 22:32:36.802 [INFO ] [arthome.ui.paper.internal.PaperUIApp] - Started Paper UI at /ui
2016-11-02 22:32:37.773 [INFO ] [basic.internal.servlet.WebAppServlet] - Started Basic UI at /basicui/app
so all UIs should be available but if I access http://myserver:8080/start , I get a “Forbidden” page from Jetty, with HTTP code 403. The same with the paper UI. Basic and classic work fine, though.
Where should I search for additional information? If I set “log:set DEBUG”, I simply drown in output but have no real idea what to look for.
Regards,
Hakan
