[SOLVED] [Freebox] Opening session failed
Hey guys,
I looked across multiple topics but I was not able to solve my issue…
I’m using OpenHab on a Raspberry with several Xiaomi devices. I also wanted to add my Freebox device, because why not.
I manage to add the Freebox as a Thing in OpenHab. I tried using both Discovery and .thing file.
I successfully recovered the token and accepted the activation request on the device:
2019-05-09 17:08:03.138 [INFO ] [ebox.internal.handler.FreeboxHandler] - ####################################################################
2019-05-09 17:08:03.140 [INFO ] [ebox.internal.handler.FreeboxHandler] - # Please accept activation request directly on your freebox #
2019-05-09 17:08:03.142 [INFO ] [ebox.internal.handler.FreeboxHandler] - # Once done, record Apptoken in the Freebox Item configuration #
2019-05-09 17:08:03.144 [INFO ] [ebox.internal.handler.FreeboxHandler] - # xxxxxxxxxxxxxxxxxxxxxx #
2019-05-09 17:08:03.145 [INFO ] [ebox.internal.handler.FreeboxHandler] - ####################################################################
But I keep having this message: (As shown below, I tried using both HTTP and HTTPS)
‘freebox:server:fb’ changed from OFFLINE to OFFLINE (CONFIGURATION_ERROR): Check your app token in the thing configuration; opening session with blby1w1r.fbxos.fr:51777 using HTTPS API version 6.0 failed
‘freebox:server:fb’ changed from OFFLINE (CONFIGURATION_ERROR): Check your app token in the thing configuration; opening session with 192.168.0.254:80 using HTTP API version 6.0 failed to OFFLINE
On the Freebox interface, I see the OpenHAB binding and I gave it full access. HTTP port is 80 and HTTPS is 51777, as expected.
Am I missing Something? Do I have to do something more ?
I started using OpenHAB recently but I managed to do everything properly so far.
Thanks a lot!!! :slight_smile:
Hey guys,
Up on this message. Any idea or hint?
Thanks!
API version 6.0: Looks like a new version.
What kind of Freebox do you get ?
I have a Freebox Revolution, the same for 6 years now.
This is the JSON response I get from http://mafreebox.freebox.fr/api_version :
“box_model_name”: “Freebox Server (r1)”,
“api_base_url”: “/api/”,
“https_port”: 51777,
“device_name”: “Freebox Server”,
“https_available”: true,
“box_model”: “fbxgw-r1/full”,
“api_domain”: “blby1w1r.fbxos.fr”,
“uid”: “7d07449bf3eb2f553eee31905797d100”,
“api_version”: “6.0”,
“device_type”: “FreeboxServer1,1”
I tried to request this one (just to see if I have something) https://blby1w1r.fbxos.fr:51777/api/v6/login and I get a response.
From what I read online, the official documentation is not up-to-date as it only references version 4.0.
Ok, I have Freebox Revolution too and API v6.0. No problem so it looks like a problem in your binding setup. Did you follow the instructions and in particular set the app token in the thing configuration ?
You should have finally something like that:
Bridge freebox:server:fb “Freebox Revolution” [ appToken=“xxxxxxxx” ] {
Of course, don"t include the appToken setting the first time.
This is my binding:
Bridge freebox:server:fb “Freebox Revolution” [ fqdn=“192.168.0.254:80”, appToken=“6RsDvDEMzWJnkue7TRhHkOAe/9vaDvLvzYWeDwDns1NBRUNzemcPwB4Cl62jz/0/”, refreshInterval=20, useOnlyHttp=true, discoverPhone=false, discoverNetDevice=false, discoverNetInterface=false, discoverAirPlayReceiver=false ] {
I will try it again later today from scratch and let you know. For what I remember, I first included the Freebox via PaperUI in order to retrieve the token and then, remove it and manually add a thing with the token.
EDIT: Just tried, same behavior.
When I add the Thing, I receive the message in logs containing the Token. I go on the Freebox and accept the OpenHAB binding. But then I have the same error message : Check your app token in the thing configuration; opening session with blby1w1r.fbxos.fr:51777 using HTTPS API version 6.0 failed.
I tried with both thing generated automatically (and just add the Token) or manually in my file.
That is the good way to first use Paper UI to retrieve the token.
But why are you setting the fqdn parameter. Try to remove it.
PS: replace your real app token by a fake in your previous message.
I removed everything to have the same declaration than you, same problem.
I also tried to put a false token (or a blank one). Same problem too.
It’s like the token is not recognized. But I got it from the logs.
Bridge freebox:server:fb “Freebox Revolution” [ appToken=“5iJ8hLTsdN4cTsiZMXU2HibiZ2P47hIBaQ5jdR8JOmP4u+SK8I08/GM7ZeirGOn8” ] {
2019-06-23 11:22:02.435 [INFO ] [ebox.internal.handler.FreeboxHandler] - # 5iJ8hLTsdN4cTsiZMXU2HibiZ2P47hIBaQ5jdR8JOmP4u+SK8I08/GM7ZeirGOn8 #
2019-06-23 11:22:02.437 [INFO ] [ebox.internal.handler.FreeboxHandler] - ####################################################################
Apparently, the opening of a session is failing for you but I can’t understand what could be wrong.
What version of OH and binding are you running ?
You must use the new binding which is included with 2.5. I don’t remember now if OH 2.4 is with the old or the new binding.
Please enable the DEBUG logs for the binding: log:set DEBUG org.openhab.binding.freebox
So, I am using version 2.4.0 of OpenHAB. Regarding the binding, I actually have no idea. I use the binding “Freebox Binding” on PaperUI but I don’t see a version anywhere.
Also, can you guide me a little bit for the logs? I’m not used to this for the moment… I use putty to connect on my Raspberry (with openhabian user) and I don’t know where to use the log command.
Thanks!
Connect to the openHAB server console and then run this command: bundle:list | grep Freebox
The result should look like this, you have the version and the date and hour the binding was compiled:
230 x Active x  80 x 2.5.0.201906222150    x openHAB Add-ons :: Bundles :: Freebox Binding
My refactoring of the binding was merged end of December 2018. So if you get a version with date 2019, that is a good starting point. If you have a version 2.4 dated in 2018, this is probably the old version of the binding and it is probably the reason why you have problems.
You can download the current version of the binding here: https://ci.openhab.org/job/openHAB2-Bundles/ws/openhab2-addons/bundles/org.openhab.binding.freebox/target/org.openhab.binding.freebox-2.5.0-SNAPSHOT.jar
Uninstall the binding provided with the distribution and then put the jar file in your folder named addons
Sorry for the delay, I had to catch up with the Karaf console and I never used it before.
This is what I got from the command:
204 x Active x 80 x 2.4.0 x Freebox Binding
I don’t have the date but apparently I don’t have the latest version.
I will try tomorrow to get the latest one. I just have to put it inside the addons directory and the addon will be available on PaperUI?
Sorry, long message incoming. I updated the logs as you suggested.
This is what I have when I update the Thing. The Token is valid but there is an issue when connecting to the API. Certificate issue?
2019-06-23 21:48:15.025 [DEBUG] [ebox.internal.handler.FreeboxHandler] - Authorize job…
2019-06-23 21:48:15.154 [DEBUG] [ebox.internal.handler.FreeboxHandler] - Can’t connect to mafreebox.freebox.fr with HTTPS
java.io.IOException: java.util.concurrent.ExecutionException: javax.net.ssl.SSLHandshakeException: General SSLEngine problem
at org.eclipse.smarthome.io.net.http.HttpUtil.executeUrlAndGetReponse(HttpUtil.java:259) ~[?:?]
at org.eclipse.smarthome.io.net.http.HttpUtil.executeUrl(HttpUtil.java:156) ~[?:?]
at org.eclipse.smarthome.io.net.http.HttpUtil.executeUrl(HttpUtil.java:131) ~[?:?]
at org.eclipse.smarthome.io.net.http.HttpUtil.executeUrl(HttpUtil.java:109) ~[?:?]
at org.eclipse.smarthome.io.net.http.HttpUtil.executeUrl(HttpUtil.java:90) ~[?:?]
at org.openhab.binding.freebox.internal.handler.FreeboxHandler.lambda$1(FreeboxHandler.java:287) ~[?:?]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.access$201(ScheduledThreadPoolExecutor.java:180) [?:?]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:293) [?:?]
Caused by: java.util.concurrent.ExecutionException: javax.net.ssl.SSLHandshakeException: General SSLEngine problem
at org.eclipse.jetty.client.util.FutureResponseListener.getResult(FutureResponseListener.java:118) ~[?:?]
at org.eclipse.jetty.client.util.FutureResponseListener.get(FutureResponseListener.java:101) ~[?:?]
at org.eclipse.jetty.client.HttpRequest.send(HttpRequest.java:684) ~[?:?]
at org.eclipse.smarthome.io.net.http.HttpUtil.executeUrlAndGetReponse(HttpUtil.java:250) ~[?:?]
... 12 more
Caused by: javax.net.ssl.SSLHandshakeException: General SSLEngine problem
at sun.security.ssl.Handshaker.checkThrown(Handshaker.java:1521) ~[?:?]
at sun.security.ssl.SSLEngineImpl.checkTaskThrown(SSLEngineImpl.java:528) ~[?:?]
at sun.security.ssl.SSLEngineImpl.readNetRecord(SSLEngineImpl.java:802) ~[?:?]
at sun.security.ssl.SSLEngineImpl.unwrap(SSLEngineImpl.java:766) ~[?:?]
at javax.net.ssl.SSLEngine.unwrap(SSLEngine.java:624) ~[?:?]
at org.eclipse.jetty.io.ssl.SslConnection$DecryptedEndPoint.fill(SslConnection.java:681) ~[?:?]
at org.eclipse.jetty.client.http.HttpReceiverOverHTTP.process(HttpReceiverOverHTTP.java:128) ~[?:?]
at org.eclipse.jetty.client.http.HttpReceiverOverHTTP.receive(HttpReceiverOverHTTP.java:73) ~[?:?]
at org.eclipse.jetty.client.http.HttpChannelOverHTTP.receive(HttpChannelOverHTTP.java:133) ~[?:?]
at org.eclipse.jetty.client.http.HttpConnectionOverHTTP.onFillable(HttpConnectionOverHTTP.java:155) ~[?:?]
at org.eclipse.jetty.io.AbstractConnection$ReadCallback.succeeded(AbstractConnection.java:281) ~[?:?]
at org.eclipse.jetty.io.FillInterest.fillable(FillInterest.java:102) ~[?:?]
at org.eclipse.jetty.io.ssl.SslConnection.onFillable(SslConnection.java:291) ~[?:?]
at org.eclipse.jetty.io.ssl.SslConnection$3.succeeded(SslConnection.java:151) ~[?:?]
at org.eclipse.jetty.io.ChannelEndPoint$2.run(ChannelEndPoint.java:118) ~[?:?]
at org.eclipse.jetty.util.thread.QueuedThreadPool.runJob(QueuedThreadPool.java:762) ~[?:?]
at org.eclipse.jetty.util.thread.QueuedThreadPool$2.run(QueuedThreadPool.java:680) ~[?:?]
... 1 more
at sun.security.ssl.Alerts.getSSLException(Alerts.java:192) ~[?:?]
at sun.security.ssl.SSLEngineImpl.fatal(SSLEngineImpl.java:1709) ~[?:?]
at sun.security.ssl.Handshaker.fatalSE(Handshaker.java:318) ~[?:?]
at sun.security.ssl.Handshaker.fatalSE(Handshaker.java:310) ~[?:?]
at sun.security.ssl.ClientHandshaker.serverCertificate(ClientHandshaker.java:1654) ~[?:?]
at sun.security.ssl.ClientHandshaker.processMessage(ClientHandshaker.java:233) ~[?:?]
at sun.security.ssl.Handshaker.processLoop(Handshaker.java:1037) ~[?:?]
at sun.security.ssl.Handshaker$1.run(Handshaker.java:970) ~[?:?]
at sun.security.ssl.Handshaker$1.run(Handshaker.java:967) ~[?:?]
at java.security.AccessController.doPrivileged(Native Method) ~[?:?]
at sun.security.ssl.Handshaker$DelegatedTask.run(Handshaker.java:1459) ~[?:?]
at org.eclipse.jetty.io.ssl.SslConnection$DecryptedEndPoint.fill(SslConnection.java:775) ~[?:?]
... 1 more
Caused by: sun.security.validator.ValidatorException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target
at sun.security.validator.PKIXValidator.doBuild(PKIXValidator.java:397) ~[?:?]
at sun.security.validator.PKIXValidator.engineValidate(PKIXValidator.java:302) ~[?:?]
at sun.security.validator.Validator.validate(Validator.java:262) ~[?:?]
at sun.security.ssl.X509TrustManagerImpl.validate(X509TrustManagerImpl.java:324) ~[?:?]
at sun.security.ssl.X509TrustManagerImpl.checkTrusted(X509TrustManagerImpl.java:281) ~[?:?]
at sun.security.ssl.X509TrustManagerImpl.checkServerTrusted(X509TrustManagerImpl.java:136) ~[?:?]
at org.eclipse.smarthome.io.net.http.internal.ExtensibleTrustManager.checkServerTrusted(ExtensibleTrustManager.java:118) ~[?:?]
at sun.security.ssl.ClientHandshaker.serverCertificate(ClientHandshaker.java:1636) ~[?:?]
... 1 more
Caused by: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target
at sun.security.provider.certpath.SunCertPathBuilder.build(SunCertPathBuilder.java:141) ~[?:?]
at sun.security.provider.certpath.SunCertPathBuilder.engineBuild(SunCertPathBuilder.java:126) ~[?:?]
at java.security.cert.CertPathBuilder.build(CertPathBuilder.java:280) ~[?:?]
at sun.security.validator.PKIXValidator.doBuild(PKIXValidator.java:392) ~[?:?]
... 1 more
2019-06-23 21:48:15.452 [DEBUG] [ebox.internal.handler.FreeboxHandler] - Apptoken valide : [Dwhaad22N7Meu4sNPJbFO/8LwQhzhGy0AzM3CoisfoDIp6SundRztOUpCtUmzA0u]
2019-06-23 21:48:15.546 [DEBUG] [ebox.internal.handler.FreeboxHandler] - Thing freebox:server:fb: error while opening a session
org.matmaul.freeboxos.FreeboxException: javax.net.ssl.SSLHandshakeException: sun.security.validator.ValidatorException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target
at org.matmaul.freeboxos.internal.RestManager.execute(RestManager.java:158) ~[?:?]
at org.matmaul.freeboxos.internal.RestManager.execute(RestManager.java:165) ~[?:?]
at org.matmaul.freeboxos.internal.RestManager.get(RestManager.java:112) ~[?:?]
at org.matmaul.freeboxos.login.LoginManager.login(LoginManager.java:85) ~[?:?]
at org.matmaul.freeboxos.login.LoginManager.openSession(LoginManager.java:94) ~[?:?]
at org.openhab.binding.freebox.internal.handler.FreeboxHandler.authorize(FreeboxHandler.java:192) ~[?:?]
at org.openhab.binding.freebox.internal.handler.FreeboxHandler.lambda$1(FreeboxHandler.java:340) ~[?:?]
Caused by: javax.net.ssl.SSLHandshakeException: sun.security.validator.ValidatorException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target
at sun.security.ssl.SSLSocketImpl.fatal(SSLSocketImpl.java:1946) ~[?:?]
at sun.security.ssl.Handshaker.fatalSE(Handshaker.java:316) ~[?:?]
at sun.security.ssl.Handshaker.process_record(Handshaker.java:965) ~[?:?]
at sun.security.ssl.SSLSocketImpl.readRecord(SSLSocketImpl.java:1064) ~[?:?]
at sun.security.ssl.SSLSocketImpl.performInitialHandshake(SSLSocketImpl.java:1367) ~[?:?]
at sun.security.ssl.SSLSocketImpl.startHandshake(SSLSocketImpl.java:1395) ~[?:?]
at sun.security.ssl.SSLSocketImpl.startHandshake(SSLSocketImpl.java:1379) ~[?:?]
at org.apache.http.conn.ssl.SSLConnectionSocketFactory.connectSocket(SSLConnectionSocketFactory.java:261) ~[?:?]
at org.apache.http.impl.conn.HttpClientConnectionOperator.connect(HttpClientConnectionOperator.java:118) ~[?:?]
at org.apache.http.impl.conn.PoolingHttpClientConnectionManager.connect(PoolingHttpClientConnectionManager.java:314) ~[?:?]
at org.apache.http.impl.execchain.MainClientExec.establishRoute(MainClientExec.java:357) ~[?:?]
at org.apache.http.impl.execchain.MainClientExec.execute(MainClientExec.java:218) ~[?:?]
at org.apache.http.impl.execchain.ProtocolExec.execute(ProtocolExec.java:194) ~[?:?]
at org.apache.http.impl.execchain.RetryExec.execute(RetryExec.java:85) ~[?:?]
at org.apache.http.impl.execchain.RedirectExec.execute(RedirectExec.java:108) ~[?:?]
at org.apache.http.impl.client.InternalHttpClient.doExecute(InternalHttpClient.java:186) ~[?:?]
at org.apache.http.impl.client.CloseableHttpClient.execute(CloseableHttpClient.java:82) ~[?:?]
at org.apache.http.impl.client.CloseableHttpClient.execute(CloseableHttpClient.java:106) ~[?:?]
at org.apache.http.impl.client.CloseableHttpClient.execute(CloseableHttpClient.java:57) ~[?:?]
at org.matmaul.freeboxos.internal.RestManager.execute(RestManager.java:155) ~[?:?]
... 13 more
at sun.security.ssl.X509TrustManagerImpl.checkTrusted(X509TrustManagerImpl.java:229) ~[?:?]
at sun.security.ssl.X509TrustManagerImpl.checkServerTrusted(X509TrustManagerImpl.java:124) ~[?:?]
at sun.security.ssl.ClientHandshaker.serverCertificate(ClientHandshaker.java:1631) ~[?:?]
... 13 more
... 13 more
2019-06-23 21:48:15.636 [DEBUG] [ebox.internal.handler.FreeboxHandler] - Thing freebox:server:fb: Check your app token in the thing configuration; opening session with blby1w1r.fbxos.fr:51777 using HTTPS API version 6.0 failed
2019-06-23 21:48:15.658 [hingStatusInfoChangedEvent] - ‘freebox:server:fb’ changed from OFFLINE to OFFLINE (CONFIGURATION_ERROR): Check your app token in the thing configuration; opening session with blby1w1r.fbxos.fr:51777 using HTTPS API version 6.0 failed
2019-06-23 21:48:15.664 [me.event.ThingUpdatedEvent] - Thing ‘freebox:server:fb’ has been updated.
And this is the error message I have when I try to force the HTTP Api (useOnlyHttp=true):
2019-06-23 21:50:54.000 [DEBUG] [ebox.internal.handler.FreeboxHandler] - Authorize job…
2019-06-23 21:50:54.069 [DEBUG] [ebox.internal.handler.FreeboxHandler] - Apptoken valide : [Dwhaad22N7Meu4sNPJbFO/8LwQhzhGy0AzM3CoisfoDIp6SundRztOUpCtUmzA0u]
2019-06-23 21:50:56.015 [DEBUG] [ebox.internal.handler.FreeboxHandler] - Thing freebox:server:fb: error while opening a session
org.matmaul.freeboxos.FreeboxException: org.codehaus.jackson.map.exc.UnrecognizedPropertyException: Unrecognized field “password_set” (Class org.matmaul.freeboxos.login.Session), not marked as ignorable
at [Source: java.util.zip.GZIPInputStream@1a17941; line: 1, column: 387] (through reference chain: org.matmaul.freeboxos.login.SessionResponse[“result”]->org.matmaul.freeboxos.login.Session[“password_set”])
at org.matmaul.freeboxos.internal.RestManager.execute(RestManager.java:173) ~[?:?]
at org.matmaul.freeboxos.internal.RestManager.post(RestManager.java:144) ~[?:?]
at org.matmaul.freeboxos.login.LoginManager.openSession(LoginManager.java:102) ~[?:?]
Caused by: org.codehaus.jackson.map.exc.UnrecognizedPropertyException: Unrecognized field “password_set” (Class org.matmaul.freeboxos.login.Session), not marked as ignorable
at org.codehaus.jackson.map.exc.UnrecognizedPropertyException.from(UnrecognizedPropertyException.java:53) ~[?:?]
at org.codehaus.jackson.map.deser.StdDeserializationContext.unknownFieldException(StdDeserializationContext.java:267) ~[?:?]
at org.codehaus.jackson.map.deser.std.StdDeserializer.reportUnknownProperty(StdDeserializer.java:673) ~[?:?]
at org.codehaus.jackson.map.deser.std.StdDeserializer.handleUnknownProperty(StdDeserializer.java:659) ~[?:?]
at org.codehaus.jackson.map.deser.BeanDeserializer.handleUnknownProperty(BeanDeserializer.java:1365) ~[?:?]
at org.codehaus.jackson.map.deser.BeanDeserializer._handleUnknown(BeanDeserializer.java:725) ~[?:?]
at org.codehaus.jackson.map.deser.BeanDeserializer.deserializeFromObject(BeanDeserializer.java:703) ~[?:?]
at org.codehaus.jackson.map.deser.BeanDeserializer.deserialize(BeanDeserializer.java:580) ~[?:?]
at org.codehaus.jackson.map.deser.SettableBeanProperty.deserialize(SettableBeanProperty.java:299) ~[?:?]
at org.codehaus.jackson.map.deser.SettableBeanProperty$FieldProperty.deserializeAndSet(SettableBeanProperty.java:579) ~[?:?]
at org.codehaus.jackson.map.deser.BeanDeserializer.deserializeFromObject(BeanDeserializer.java:697) ~[?:?]
at org.codehaus.jackson.map.ObjectMapper._readMapAndClose(ObjectMapper.java:2732) ~[?:?]
at org.codehaus.jackson.map.ObjectMapper.readValue(ObjectMapper.java:1909) ~[?:?]
at org.matmaul.freeboxos.internal.RestManager.readValue(RestManager.java:122) ~[?:?]
... 11 more
2019-06-23 21:50:56.094 [DEBUG] [ebox.internal.handler.FreeboxHandler] - Thing freebox:server:fb: Check your app token in the thing configuration; opening session with mafreebox.freebox.fr using HTTP API version 6.0 failed
2019-06-23 21:50:56.100 [hingStatusInfoChangedEvent] - ‘freebox:server:fb’ changed from OFFLINE to OFFLINE (CONFIGURATION_ERROR): Check your app token in the thing configuration; opening session with mafreebox.freebox.fr using HTTP API version 6.0 failed
2019-06-23 21:50:56.126 [me.event.ThingUpdatedEvent] - Thing ‘freebox:server:fb’ has been updated.
I can see with your logs that you are running the old version of the binding that required an additional step for the certificate.
I can’t help more with this old version but of course I advice the new version which is working well.
So, as requested, I uninstalled my version of the binding and I put the 2.5.0 in the addons directory. Then, I rebooted.
These are the messages I saw in the logs :
2019-06-24 18:52:24.723 [ERROR] [org.openhab.binding.freebox ] - FrameworkEvent ERROR - org.openhab.binding.freebox
org.osgi.framework.BundleException: Could not resolve module: org.openhab.binding.freebox [209]
Unresolved requirement: Import-Package: com.google.gson; version=“[2.8.0,3.0.0)”
at org.eclipse.osgi.container.Module.start(Module.java:444) ~[?:?]
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.incStartLevel(ModuleContainer.java:1634) ~[?:?]
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.incStartLevel(ModuleContainer.java:1614) ~[?:?]
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.doContainerStartLevel(ModuleContainer.java:1585) ~[?:?]
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.dispatchEvent(ModuleContainer.java:1528) ~[?:?]
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.dispatchEvent(ModuleContainer.java:1) ~[?:?]
at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:230) [?:?]
at org.eclipse.osgi.framework.eventmgr.EventManager$EventThread.run(EventManager.java:340) [?:?]
2019-06-24 18:52:27.354 [WARN ] [org.apache.felix.fileinstall ] - Error while starting bundle: file:/usr/share/openhab2/addons/org.openhab.binding.freebox-2.5.0-SNAPSHOT.jar
at org.eclipse.osgi.internal.framework.EquinoxBundle.start(EquinoxBundle.java:383) ~[?:?]
at org.apache.felix.fileinstall.internal.DirectoryWatcher.startBundle(DirectoryWatcher.java:1260) [10:org.apache.felix.fileinstall:3.6.4]
at org.apache.felix.fileinstall.internal.DirectoryWatcher.startBundles(DirectoryWatcher.java:1233) [10:org.apache.felix.fileinstall:3.6.4]
at org.apache.felix.fileinstall.internal.DirectoryWatcher.startAllBundles(DirectoryWatcher.java:1221) [10:org.apache.felix.fileinstall:3.6.4]
at org.apache.felix.fileinstall.internal.DirectoryWatcher.doProcess(DirectoryWatcher.java:515) [10:org.apache.felix.fileinstall:3.6.4]
at org.apache.felix.fileinstall.internal.DirectoryWatcher.process(DirectoryWatcher.java:365) [10:org.apache.felix.fileinstall:3.6.4]
at org.apache.felix.fileinstall.internal.DirectoryWatcher.run(DirectoryWatcher.java:316) [10:org.apache.felix.fileinstall:3.6.4]
In this case, install a 2.5 snapshot or wait for an official 2.5 version.
Okay, I will wait then.
Thanks for your help.
