- Platform information:
- Hardware: Raspberry Pi 3 Model B Rev 1.2_
- System: Host: rpi3ohv2 Kernel: 5.4.51-v7+ armv7l bits: 32 Console: tty 2
- Distro: Raspbian GNU/Linux 10 (buster)
- OpenJDK Runtime Environment (Zulu 8.31.1.122-linux_aarch32hf) (build 1.8.0_181-b122)
- Version: 2.5.10 (Build) (apt-get), text-based config
- binding = astro,exec,logreader,network,ntp,systeminfo,fritzboxtr0641,expire1,mqtt1,weather1
- ui = paper,basic,classic,restdocs
- persistence = rrd4j,mapdb
- action = mail,mqtt
- transformation = map,javascript,xslt,scale,jsonpath
openhab-binding-fritzboxtr0641 │ 1.14.0 │ x │ Started │ openhab-addons-2.5.10 │ Fritzbox TR064 Binding
I have observed that the binding does not pick up a caller ID, while the DECT phone does. I can’t tell, whether this is a new thing, as I never paid much attention to it.
Do others experience the same issue?
I use that binding for many years, and recently reviewed, whether my rule and item syntax corresponds to the documentation… which it does.
The openhab.log will show an entry with the local and calling number pair, when a call comes in. But, as I observed, I have quite a few calls (maybe 40%) where the calling number is empty… while the landline phone (and even FritzPhone on the iPhone) show a caller ID.
Here some log files, also showing the discrepancy between event and openhab log files:
2020-11-25 12:52:44.723 [vent.ItemStateChangedEvent] - fbox_IncomingCallResolved changed from , to 0754246535,Joe Milao - Mays (Work)
2020-11-25 12:52:44.726 [vent.ItemStateChangedEvent] - fbox_IncomingCall changed from , to 0754246535,0733433044
2020-11-25 12:52:44.706 [INFO ] [.smarthome.model.script.Fritzbox.1.0] - Call coming in...
2020-11-25 12:52:44.717 [INFO ] [.smarthome.model.script.Fritzbox.1.1] - tmpIncomingCall...............: ,
2020-11-25 12:52:44.723 [INFO ] [.smarthome.model.script.Fritzbox.1.2] - tmpLastCallerNumber...........:
2020-11-25 12:52:44.730 [INFO ] [.smarthome.model.script.Fritzbox.1.x] - No caller ID provided means...: nothing to process; over and out.
Items and rules
Switch fbox_Ringing "Phone ringing in [%s]" <phone> (gFritzBox) { fritzboxtr064="callmonitor_ringing" }
Call fbox_IncomingCall "Call [%1$s to %2$s]" <phone> (gFritzBox) { fritzboxtr064="callmonitor_ringing" }
Call fbox_IncomingCallResolved "Call (resolved) [%1$s to %2$s]" <phone> (gFritzBox) { fritzboxtr064="callmonitor_ringing:resolveName" }
String fBox_LastCallerNumber "Last caller's number [%s]" <phone> (gFritzBox)
String fBox_LastCallerName "Last caller's name [%s]" <phone> (gFritzBox)
rule "Fritzbox: Incoming call, get number and resolve name from phonebook"
Item fbox_Ringing changed from OFF to ON
logInfo(logPrefix + "1.0", "Call coming in...")
val tmpIncomingCall = fbox_IncomingCall.state as StringListType
val String tmpLastCallerNumber = tmpIncomingCall.getValue(1)
val String tmpLastCallerNumber0 = tmpIncomingCall.getValue(0)
logInfo(logPrefix + "1.1", "tmpIncomingCall...............: {}", tmpIncomingCall)
logInfo(logPrefix + "1.2", "tmpLastCallerNumber...........: {}", tmpLastCallerNumber)
var tmpLastCallResolved = fbox_IncomingCallResolved.state as StringListType
logInfo(logPrefix + "1.3", "tmpLastCallResolved...........: {}", tmpLastCallResolved)
var tmpLastCallerName = tmpLastCallResolved.getValue(1)
logInfo(logPrefix + "1.4", "tmpCallerName.................: {}", tmpLastCallerName)
val stringCallerNumber = transform("JS", "fb_phoneNumber.js", tmpLastCallerNumber)
logInfo(logPrefix + "1.5", "stringCallerNumber............: {}", stringCallerNumber)
// remove the called (own) number from caller string
tmpLastCallerName = tmpLastCallerName.removeStart("0754246535##")
if (tmpLastCallerName.startsWith("Name not found for"))
tmpLastCallerName = "Unknown"
logInfo(logPrefix + "1.6", "stringCallerNumber............: {}", stringCallerNumber)
logInfo(logPrefix + "1.7", "tmpName.......................: {}", tmpLastCallerName)
