Hello
I just migrated to openhab2 recently. So far so good.
I used to schedule events with conditions from google calendar in openhab 1.x.
For example having the following in the event description would just work fine to control my irrigation.
start {
> if (Irrigation_MainSwitch.state == ON) sendCommand(Irrigation_Pump, ON)
> if (Irrigation_MainSwitch.state == ON) sendCommand(Irrigation_Garden, ON)
end {
send Irrigation_Pump OFF
send Irrigation_Garden OFF
But using the same old event definitions in openhab2 causes openhab to complain about the script initiating ‘>’:
2017-04-18 11:15:59.558 [DEBUG] [io.gcal.internal.GCalEventDownloader] - found 1 calendar events to process
2017-04-18 11:15:59.587 [DEBUG] [io.gcal.internal.GCalEventDownloader] - created new startJob ‘Front Yard Small’ with details 'SchedulerJob [jobKey=5k1pifcllneqpqgp07dd71g6io@google.com_start, jobGroup=gcal, 1 triggers=[Tue Apr 18 11:16:00 SAST 2017], content=start {
if (Irrigation_MainSwitch.state == ON) sendCommand(Irrigation_FYSmall , ON)
end {
send Irrigation_FYSmall OFF
2017-04-18 11:15:59.590 [DEBUG] [io.gcal.internal.GCalEventDownloader] - created new endJob ‘Front Yard Small’ with details ‘SchedulerJob [jobKey=5k1pifcllneqpqgp07dd71g6io@google.com_end, jobGroup=gcal, 1 triggers=[Tue Apr 18 11:20:00 SAST 2017], content=start {
end {
2017-04-18 11:16:00.002 [TRACE] [gcal.internal.util.ExecuteCommandJob] - going to parse command ‘> if (Irrigation_MainSwitch.state == ON) sendCommand(Irrigation_Pump, ON)’
2017-04-18 11:16:00.004 [WARN ] [gcal.internal.util.ExecuteCommandJob] - Command > not supported
2017-04-18 11:16:00.009 [TRACE] [gcal.internal.util.ExecuteCommandJob] - going to parse command ‘> if (Irrigation_MainSwitch.state == ON) sendCommand(Irrigation_FYSmall , ON)’
2017-04-18 11:16:00.010 [WARN ] [gcal.internal.util.ExecuteCommandJob] - Command > not supported
2017-04-18 11:16:59.592 [DEBUG] [openhab.io.gcal.auth.GCalGoogleOAuth] - Got calendar OpenHab CalendarID:
i removed the ‘>’ but without success.
Does anybody know what is happening here? is the script mode not supported anymore?
Any other ideas of how to implement conditional commands from gcal scheduler? Or must I rather look into creating rules to achieve my requirements?
thanks in advance for your input!
