Buster (Latest Version - updated 20 Jan 2020 - next update 1 Feb 2020)
openHAB version: 2.5.1-2 (Release Build)
Z-Wave Controller: Aeotec Gen 5 Z-Wave Stick
Issue of the topic: As a Beginner / Novice, I have been very detailed in following this initial tutorial(s):
through to
on setting up my system.
It is at having successfully completed through this point: www.openhab.org_docs_tutorial_rules.html, that I found a problem.
When I turn off my cell phone, the âPaper UIâ (on refreshing the page, will reflect my cell phone is off. âMy first sitemapâ does not. When I turn on my cell phone, the âPaper UIâ will change and reflect my cell phone is on. âMyfirst sitemapâ again makes no change.
The âPaper UIâ changes occur very quickly (within about 3 to 4 seconds - which is really good.)
Now in my own troubleshooting, I have discovered that in the âPaper UI, Configuration, Things, Office Window Wall Outletâ (Thing), when I click the âSwitch Channelâ button, I receive: âerror 404 - not foundâ. The center of the button is white - hence it is supposed to already be linked. (Configuration, System, Item Linking, Simple Mode is selected.)
I can select the one other channel: âScene Numberâ and link or unlink it - without error.
Additionally, when in 'Paper UI, Control" or in âMy first sitemapâ, I can successfully control the outlet by moving the slider button.
But can not control the outlet via the rules process based on the cellphone in/out of the network.
PaperUI is for config only and not for control. Use something like BasicUI for this and please post your sitemap file and we can look for syntax errors. Also the name of the file and the sitemap must be the same.
404 error generally means that you have defined the thing in a text file and not through the UI and it must, therefore, be edited in the text file, and not the UI.
If you have simple mode on (not recommended) and your creating the item manually then you will have duplicates that will cause issues. If this is the case let me know and I can help with removing the duplicates.
Please post your rule and items for review.
EDIT: The error number mentioned is for 409 not 404.
Rules - file name: default.rules
rule âWallplug_OF_WindowWall ONâ
Item Presence_Mobile_Dave changed from OFF to ON
Wallplug_OF_WindowWall.sendCommand(ON)
rule âWallplug_OF_WindowWall OFFâ
Item Presence_Mobile_Dave changed from ON to OFF
Wallplug_OF_WindowWall.sendCommand(OFF)
So - Item Linking: âsimple modeâ is not recommended. Ouch. So - how best to update the tutorial located at https://www.openhab.org/docs/tutorial/configuration.html?
I do not see any duplicates in Paper UI: Configuration_Things, nor in Paper UI Control.
If I understand correctly, my Basic UI has been changed to âMy first sitemapâ, again in following the tutorial. And in looking at âMy first sitemapâ there are no duplicates.
Should I disable Item Linking selection: simple mode?
Simple mode works but can cause issues later if you want to do more with config and it also links the channels for you. You mentioned linking and unlinking manually so you may want to turn simple mode off for now. No duplicates is good.
From PaperUI do you see a âshow moreâ icon to click on? If so please click and see if additional channels show up.
For the rule do you see anything in the logs when the rule runs?
Sorry - confused: âshow moreââŠin what screen?
Logs� There are no log files in the /etc/openhab2 directory. Director contains: html, items, rules, services, sounds, transform, icons, persistence, scripts, sitemaps and things.
Dave
PaperUI things channels, you may not have this but itâs something to look for when you do not see an expected channel on a binding.
Frontail log, you can access it from the home page where you select PaperUI, BasiceUI, etc⊠if you have it installed. If not installed then simply install it from openhabian-config tool.
Did you install OH via the openhabian image? If so you can add frontail log and watch from the browser. To install use sudo openhabian-config from command line then look thru the options and find add frontail log.
EDIT: Frontail log in openhabian-config is option 21 under âOptional Componentsâ
2020-01-28 13:20:40.948 [vent.ItemStateChangedEvent] - network_pingdevice_192_168_0_17_latency changed from 841.0 ms to 574.0 ms
2020-01-28 13:20:41.712 [vent.ItemStateChangedEvent] - network_pingdevice_192_168_0_17_lastseen changed from 2020-01-28T13:19:40.348-0800 to 2020-01-28T13:20:41.688-0800
2020-01-28 13:21:42.714 [vent.ItemStateChangedEvent] - network_pingdevice_192_168_0_17_latency changed from 574.0 ms to 997.0 ms
2020-01-28 13:21:43.148 [vent.ItemStateChangedEvent] - network_pingdevice_192_168_0_17_lastseen changed from 2020-01-28T13:20:41.688-0800 to 2020-01-28T13:21:43.128-0800
2020-01-28 13:22:43.198 [vent.ItemStateChangedEvent] - network_pingdevice_192_168_0_17_latency changed from 997.0 ms to 42.0 ms
2020-01-28 13:22:43.567 [vent.ItemStateChangedEvent] - network_pingdevice_192_168_0_17_lastseen changed from 2020-01-28T13:21:43.128-0800 to 2020-01-28T13:22:43.548-0800
2020-01-28 13:23:43.659 [vent.ItemStateChangedEvent] - network_pingdevice_192_168_0_17_latency changed from 42.0 ms to 86.0 ms
2020-01-28 13:23:44.025 [vent.ItemStateChangedEvent] - network_pingdevice_192_168_0_17_lastseen changed from 2020-01-28T13:22:43.548-0800 to 2020-01-28T13:23:43.998-0800
2020-01-28 13:24:49.127 [vent.ItemStateChangedEvent] - network_pingdevice_192_168_0_17_online changed from ON to OFF
2020-01-28 13:24:49.130 [vent.ItemStateChangedEvent] - network_pingdevice_192_168_0_17_latency changed from 86.0 ms to UNDEF
2020-01-28 13:25:10.972 [ome.event.ItemCommandEvent] - Item âPresence_Mobile_Daveâ received command ON
2020-01-28 13:25:10.982 [vent.ItemStateChangedEvent] - Presence_Mobile_Dave changed from NULL to ON
2020-01-28 13:25:18.705 [ome.event.ItemCommandEvent] - Item âWallplug_OF_WindowWallâ received command ON
2020-01-28 13:25:18.732 [nt.ItemStatePredictedEvent] - Wallplug_OF_WindowWall predicted to become ON
2020-01-28 13:25:18.777 [vent.ItemStateChangedEvent] - Wallplug_OF_WindowWall changed from NULL to ON
2020-01-28 13:25:18.783 [vent.ItemStateChangedEvent] - zwave_serial_zstick_a3b690b0_serial_ack changed from 202 to 203
2020-01-28 13:25:18.786 [vent.ItemStateChangedEvent] - zwave_serial_zstick_a3b690b0_serial_sof changed from 425 to 426
2020-01-28 13:25:18.790 [vent.ItemStateChangedEvent] - zwave_serial_zstick_a3b690b0_serial_sof changed from 426 to 427
2020-01-28 13:25:20.273 [vent.ItemStateChangedEvent] - zwave_serial_zstick_a3b690b0_serial_ack changed from 203 to 204
2020-01-28 13:25:20.279 [vent.ItemStateChangedEvent] - zwave_serial_zstick_a3b690b0_serial_sof changed from 427 to 428
2020-01-28 13:25:20.296 [vent.ItemStateChangedEvent] - zwave_serial_zstick_a3b690b0_serial_sof changed from 428 to 429
2020-01-28 13:25:20.308 [vent.ItemStateChangedEvent] - zwave_serial_zstick_a3b690b0_serial_sof changed from 429 to 430
2020-01-28 13:25:20.316 [vent.ItemStateChangedEvent] - zwave_device_a3b690b0_node7_switch_binary changed from NULL to ON
2020-01-28 13:25:22.156 [ome.event.ItemCommandEvent] - Item âPresence_Mobile_Daveâ received command OFF
2020-01-28 13:25:22.170 [vent.ItemStateChangedEvent] - Presence_Mobile_Dave changed from ON to OFF
2020-01-28 13:25:22.342 [ome.event.ItemCommandEvent] - Item âWallplug_OF_WindowWallâ received command OFF
2020-01-28 13:25:22.350 [nt.ItemStatePredictedEvent] - Wallplug_OF_WindowWall predicted to become OFF
2020-01-28 13:25:22.367 [vent.ItemStateChangedEvent] - Wallplug_OF_WindowWall changed from ON to OFF
2020-01-28 13:25:22.370 [vent.ItemStateChangedEvent] - zwave_serial_zstick_a3b690b0_serial_ack changed from 204 to 205
2020-01-28 13:25:22.375 [vent.ItemStateChangedEvent] - zwave_serial_zstick_a3b690b0_serial_sof changed from 430 to 431
2020-01-28 13:25:22.391 [vent.ItemStateChangedEvent] - zwave_serial_zstick_a3b690b0_serial_sof changed from 431 to 432
2020-01-28 13:25:23.873 [vent.ItemStateChangedEvent] - zwave_serial_zstick_a3b690b0_serial_ack changed from 205 to 206
2020-01-28 13:25:23.880 [vent.ItemStateChangedEvent] - zwave_serial_zstick_a3b690b0_serial_sof changed from 432 to 433
2020-01-28 13:25:23.895 [vent.ItemStateChangedEvent] - zwave_serial_zstick_a3b690b0_serial_sof changed from 433 to 434
2020-01-28 13:25:23.907 [vent.ItemStateChangedEvent] - zwave_serial_zstick_a3b690b0_serial_sof changed from 434 to 435
2020-01-28 13:25:23.916 [vent.ItemStateChangedEvent] - zwave_device_a3b690b0_node7_switch_binary changed from ON to OFF
2020-01-28 13:25:26.554 [ome.event.ItemCommandEvent] - Item âPresence_Mobile_Daveâ received command ON
2020-01-28 13:25:26.565 [vent.ItemStateChangedEvent] - Presence_Mobile_Dave changed from OFF to ON
2020-01-28 13:25:26.571 [ome.event.ItemCommandEvent] - Item âWallplug_OF_WindowWallâ received command ON
2020-01-28 13:25:26.609 [nt.ItemStatePredictedEvent] - Wallplug_OF_WindowWall predicted to become ON
2020-01-28 13:25:26.641 [vent.ItemStateChangedEvent] - Wallplug_OF_WindowWall changed from OFF to ON
2020-01-28 13:25:26.648 [vent.ItemStateChangedEvent] - zwave_serial_zstick_a3b690b0_serial_ack changed from 206 to 207
2020-01-28 13:25:26.651 [vent.ItemStateChangedEvent] - zwave_serial_zstick_a3b690b0_serial_sof changed from 435 to 436
2020-01-28 13:25:26.653 [vent.ItemStateChangedEvent] - zwave_serial_zstick_a3b690b0_serial_sof changed from 436 to 437
2020-01-28 13:25:28.121 [vent.ItemStateChangedEvent] - zwave_serial_zstick_a3b690b0_serial_ack changed from 207 to 208
2020-01-28 13:25:28.127 [vent.ItemStateChangedEvent] - zwave_serial_zstick_a3b690b0_serial_sof changed from 437 to 438
2020-01-28 13:25:28.143 [vent.ItemStateChangedEvent] - zwave_serial_zstick_a3b690b0_serial_sof changed from 438 to 439
2020-01-28 13:25:28.155 [vent.ItemStateChangedEvent] - zwave_serial_zstick_a3b690b0_serial_sof changed from 439 to 440
2020-01-28 13:25:28.163 [vent.ItemStateChangedEvent] - zwave_device_a3b690b0_node7_switch_binary changed from OFF to ON
2020-01-28 13:25:49.166 [vent.ItemStateChangedEvent] - network_pingdevice_192_168_0_17_online changed from OFF to ON
2020-01-28 13:25:49.177 [vent.ItemStateChangedEvent] - network_pingdevice_192_168_0_17_latency changed from UNDEF to 38.0 ms
2020-01-28 13:25:50.546 [vent.ItemStateChangedEvent] - network_pingdevice_192_168_0_17_lastseen changed from 2020-01-28T13:23:43.998-0800 to 2020-01-28T13:25:50.528-0800
2020-01-28 13:26:55.653 [vent.ItemStateChangedEvent] - network_pingdevice_192_168_0_17_online changed from ON to OFF
2020-01-28 13:26:55.655 [vent.ItemStateChangedEvent] - network_pingdevice_192_168_0_17_latency changed from 38.0 ms to UNDEF
2020-01-28 13:29:34.586 [home.event.InboxAddedEvent] - Discovery Result with UID ânetwork:pingdevice:192_168_0_1â has been added.
2020-01-28 13:29:35.193 [home.event.InboxAddedEvent] - Discovery Result with UID ânetwork:pingdevice:192_168_0_10â has been added.
2020-01-28 13:29:35.214 [home.event.InboxAddedEvent] - Discovery Result with UID ânetwork:pingdevice:192_168_0_11â has been added.
2020-01-28 13:29:35.235 [home.event.InboxAddedEvent] - Discovery Result with UID ânetwork:pingdevice:192_168_0_12â has been added.
2020-01-28 13:29:35.251 [home.event.InboxAddedEvent] - Discovery Result with UID ânetwork:servicedevice:192_168_0_14_80â has been added.
2020-01-28 13:29:35.264 [home.event.InboxAddedEvent] - Discovery Result with UID ânetwork:pingdevice:192_168_0_13â has been added.
2020-01-28 13:29:35.269 [home.event.InboxAddedEvent] - Discovery Result with UID ânetwork:pingdevice:192_168_0_14â has been added.
2020-01-28 13:29:35.289 [home.event.InboxAddedEvent] - Discovery Result with UID ânetwork:pingdevice:192_168_0_16â has been added.
2020-01-28 13:29:35.686 [home.event.InboxAddedEvent] - Discovery Result with UID ânetwork:pingdevice:192_168_0_19â has been added.
2020-01-28 13:29:35.741 [home.event.InboxAddedEvent] - Discovery Result with UID ânetwork:pingdevice:192_168_0_22â has been added.
2020-01-28 13:29:35.747 [home.event.InboxAddedEvent] - Discovery Result with UID ânetwork:pingdevice:192_168_0_23â has been added.
2020-01-28 13:29:35.884 [home.event.InboxAddedEvent] - Discovery Result with UID ânetwork:pingdevice:192_168_0_24â has been added.
2020-01-28 13:29:36.092 [home.event.InboxAddedEvent] - Discovery Result with UID ânetwork:pingdevice:192_168_0_25â has been added.
2020-01-28 13:29:36.150 [home.event.InboxAddedEvent] - Discovery Result with UID ânetwork:pingdevice:192_168_0_26â has been added.
2020-01-28 13:29:36.251 [home.event.InboxAddedEvent] - Discovery Result with UID ânetwork:pingdevice:192_168_0_28â has been added.
2020-01-28 13:29:36.277 [home.event.InboxAddedEvent] - Discovery Result with UID ânetwork:pingdevice:192_168_0_30â has been added.
2020-01-28 13:29:36.302 [home.event.InboxAddedEvent] - Discovery Result with UID ânetwork:pingdevice:192_168_0_31â has been added.
2020-01-28 13:29:36.332 [home.event.InboxAddedEvent] - Discovery Result with UID ânetwork:pingdevice:192_168_0_32â has been added.
2020-01-28 13:29:36.559 [home.event.InboxAddedEvent] - Discovery Result with UID ânetwork:pingdevice:192_168_0_34â has been added.
2020-01-28 13:29:37.101 [home.event.InboxAddedEvent] - Discovery Result with UID ânetwork:servicedevice:192_168_0_42_80â has been added.
2020-01-28 13:29:37.111 [home.event.InboxAddedEvent] - Discovery Result with UID ânetwork:pingdevice:192_168_0_42â has been added.
2020-01-28 13:29:37.306 [home.event.InboxAddedEvent] - Discovery Result with UID ânetwork:pingdevice:192_168_0_44â has been added.
2020-01-28 13:29:53.082 [home.event.InboxAddedEvent] - Discovery Result with UID ânetwork:pingdevice:192_168_0_254â has been added.
2020-01-28 13:30:28.819 [me.event.InboxRemovedEvent] - Discovery Result with UID ânetwork:pingdevice:192_168_0_16â has been removed.
2020-01-28 13:30:28.827 [me.event.InboxRemovedEvent] - Discovery Result with UID ânetwork:pingdevice:192_168_0_13â has been removed.
2020-01-28 13:30:28.835 [me.event.InboxRemovedEvent] - Discovery Result with UID ânetwork:pingdevice:192_168_0_14â has been removed.
2020-01-28 13:30:28.842 [me.event.InboxRemovedEvent] - Discovery Result with UID ânetwork:pingdevice:192_168_0_19â has been removed.
2020-01-28 13:30:28.850 [me.event.InboxRemovedEvent] - Discovery Result with UID ânetwork:pingdevice:192_168_0_30â has been removed.
2020-01-28 13:30:28.856 [me.event.InboxRemovedEvent] - Discovery Result with UID ânetwork:pingdevice:192_168_0_11â has been removed.
2020-01-28 13:30:28.863 [me.event.InboxRemovedEvent] - Discovery Result with UID ânetwork:pingdevice:192_168_0_12â has been removed.
2020-01-28 13:30:28.868 [me.event.InboxRemovedEvent] - Discovery Result with UID ânetwork:pingdevice:192_168_0_34â has been removed.
2020-01-28 13:30:28.874 [me.event.InboxRemovedEvent] - Discovery Result with UID ânetwork:pingdevice:192_168_0_31â has been removed.
2020-01-28 13:30:28.885 [me.event.InboxRemovedEvent] - Discovery Result with UID ânetwork:pingdevice:192_168_0_10â has been removed.
2020-01-28 13:30:28.890 [me.event.InboxRemovedEvent] - Discovery Result with UID ânetwork:pingdevice:192_168_0_32â has been removed.
2020-01-28 13:30:28.896 [me.event.InboxRemovedEvent] - Discovery Result with UID ânetwork:pingdevice:192_168_0_254â has been removed.
2020-01-28 13:30:28.905 [me.event.InboxRemovedEvent] - Discovery Result with UID ânetwork:servicedevice:192_168_0_42_80â has been removed.
2020-01-28 13:30:28.911 [me.event.InboxRemovedEvent] - Discovery Result with UID ânetwork:pingdevice:192_168_0_26â has been removed.
2020-01-28 13:30:28.915 [me.event.InboxRemovedEvent] - Discovery Result with UID ânetwork:pingdevice:192_168_0_24â has been removed.
2020-01-28 13:30:28.919 [me.event.InboxRemovedEvent] - Discovery Result with UID ânetwork:pingdevice:192_168_0_25â has been removed.
2020-01-28 13:30:28.923 [me.event.InboxRemovedEvent] - Discovery Result with UID ânetwork:pingdevice:192_168_0_28â has been removed.
2020-01-28 13:30:28.927 [me.event.InboxRemovedEvent] - Discovery Result with UID ânetwork:pingdevice:192_168_0_22â has been removed.
2020-01-28 13:30:28.929 [me.event.InboxRemovedEvent] - Discovery Result with UID ânetwork:pingdevice:192_168_0_44â has been removed.
2020-01-28 13:30:28.931 [me.event.InboxRemovedEvent] - Discovery Result with UID ânetwork:pingdevice:192_168_0_23â has been removed.
2020-01-28 13:30:28.933 [me.event.InboxRemovedEvent] - Discovery Result with UID ânetwork:servicedevice:192_168_0_14_80â has been removed.
2020-01-28 13:30:28.935 [me.event.InboxRemovedEvent] - Discovery Result with UID ânetwork:pingdevice:192_168_0_42â has been removed.
2020-01-28 13:30:28.937 [me.event.InboxRemovedEvent] - Discovery Result with UID ânetwork:pingdevice:192_168_0_1â has been removed.
2020-01-28 13:30:28.948 [home.event.InboxAddedEvent] - Discovery Result with UID ânetwork:servicedevice:192_168_0_1_80â has been added.
2020-01-28 13:30:28.962 [home.event.InboxAddedEvent] - Discovery Result with UID ânetwork:pingdevice:192_168_0_1â has been added.
2020-01-28 13:30:29.570 [home.event.InboxAddedEvent] - Discovery Result with UID ânetwork:pingdevice:192_168_0_10â has been added.
2020-01-28 13:30:29.593 [home.event.InboxAddedEvent] - Discovery Result with UID ânetwork:pingdevice:192_168_0_11â has been added.
2020-01-28 13:30:29.605 [home.event.InboxAddedEvent] - Discovery Result with UID ânetwork:servicedevice:192_168_0_14_80â has been added.
2020-01-28 13:30:29.609 [home.event.InboxAddedEvent] - Discovery Result with UID ânetwork:pingdevice:192_168_0_12â has been added.
2020-01-28 13:30:29.618 [home.event.InboxAddedEvent] - Discovery Result with UID ânetwork:pingdevice:192_168_0_13â has been added.
2020-01-28 13:30:29.624 [home.event.InboxAddedEvent] - Discovery Result with UID ânetwork:pingdevice:192_168_0_14â has been added.
2020-01-28 13:30:29.673 [home.event.InboxAddedEvent] - Discovery Result with UID ânetwork:pingdevice:192_168_0_16â has been added.
2020-01-28 13:30:30.076 [home.event.InboxAddedEvent] - Discovery Result with UID ânetwork:pingdevice:192_168_0_19â has been added.
2020-01-28 13:30:30.102 [home.event.InboxAddedEvent] - Discovery Result with UID ânetwork:pingdevice:192_168_0_22â has been added.
2020-01-28 13:30:30.118 [home.event.InboxAddedEvent] - Discovery Result with UID ânetwork:pingdevice:192_168_0_23â has been added.
2020-01-28 13:30:30.241 [home.event.InboxAddedEvent] - Discovery Result with UID ânetwork:pingdevice:192_168_0_24â has been added.
2020-01-28 13:30:30.362 [home.event.InboxAddedEvent] - Discovery Result with UID ânetwork:pingdevice:192_168_0_25â has been added.
2020-01-28 13:30:30.570 [home.event.InboxAddedEvent] - Discovery Result with UID ânetwork:pingdevice:192_168_0_28â has been added.
2020-01-28 13:30:30.574 [home.event.InboxAddedEvent] - Discovery Result with UID ânetwork:pingdevice:192_168_0_26â has been added.
2020-01-28 13:30:30.692 [home.event.InboxAddedEvent] - Discovery Result with UID ânetwork:pingdevice:192_168_0_30â has been added.
2020-01-28 13:30:30.707 [home.event.InboxAddedEvent] - Discovery Result with UID ânetwork:pingdevice:192_168_0_31â has been added.
2020-01-28 13:30:30.751 [home.event.InboxAddedEvent] - Discovery Result with UID ânetwork:pingdevice:192_168_0_32â has been added.
2020-01-28 13:30:30.894 [home.event.InboxAddedEvent] - Discovery Result with UID ânetwork:pingdevice:192_168_0_34â has been added.
2020-01-28 13:30:31.201 [home.event.InboxAddedEvent] - Discovery Result with UID ânetwork:pingdevice:192_168_0_35â has been added.
2020-01-28 13:30:31.417 [home.event.InboxAddedEvent] - Discovery Result with UID ânetwork:servicedevice:192_168_0_42_80â has been added.
2020-01-28 13:30:31.444 [home.event.InboxAddedEvent] - Discovery Result with UID ânetwork:pingdevice:192_168_0_42â has been added.
2020-01-28 13:30:31.739 [home.event.InboxAddedEvent] - Discovery Result with UID ânetwork:pingdevice:192_168_0_44â has been added.
2020-01-28 13:30:47.492 [home.event.InboxAddedEvent] - Discovery Result with UID ânetwork:pingdevice:192_168_0_254â has been added.
2020-01-28 13:31:11.054 [vent.ItemStateChangedEvent] - network_pingdevice_192_168_0_17_online changed from OFF to ON
2020-01-28 13:31:11.066 [vent.ItemStateChangedEvent] - network_pingdevice_192_168_0_17_latency changed from UNDEF to 82.0 ms
2020-01-28 13:31:11.362 [vent.ItemStateChangedEvent] - network_pingdevice_192_168_0_17_lastseen changed from 2020-01-28T13:25:50.528-0800 to 2020-01-28T13:31:11.348-0800
2020-01-28 13:32:12.022 [vent.ItemStateChangedEvent] - network_pingdevice_192_168_0_17_latency changed from 82.0 ms to 653.0 ms
2020-01-28 13:32:12.705 [vent.ItemStateChangedEvent] - network_pingdevice_192_168_0_17_lastseen changed from 2020-01-28T13:31:11.348-0800 to 2020-01-28T13:32:12.688-0800
2020-01-28 13:33:12.735 [vent.ItemStateChangedEvent] - network_pingdevice_192_168_0_17_latency changed from 653.0 ms to 25.0 ms
2020-01-28 13:33:13.025 [vent.ItemStateChangedEvent] - network_pingdevice_192_168_0_17_lastseen changed from 2020-01-28T13:32:12.688-0800 to 2020-01-28T13:33:13.008-0800
2020-01-28 13:34:13.198 [vent.ItemStateChangedEvent] - network_pingdevice_192_168_0_17_latency changed from 25.0 ms to 166.0 ms
2020-01-28 13:34:13.443 [vent.ItemStateChangedEvent] - network_pingdevice_192_168_0_17_lastseen changed from 2020-01-28T13:33:13.008-0800 to 2020-01-28T13:34:13.428-0800
2020-01-28 13:34:19.867 [hingStatusInfoChangedEvent] - ânetwork:pingdevice:e2172ac2â changed from UNINITIALIZED to INITIALIZING
2020-01-28 13:34:19.912 [hingStatusInfoChangedEvent] - ânetwork:pingdevice:e2172ac2â changed from INITIALIZING to ONLINE
2020-01-28 13:34:19.933 [me.event.ThingUpdatedEvent] - Thing ânetwork:pingdevice:e2172ac2â has been updated.
2020-01-28 13:34:19.944 [.ItemChannelLinkAddedEvent] - Link ânetwork_pingdevice_e2172ac2_online-network:pingdevice:e2172ac2:onlineâ has been added.
2020-01-28 13:34:19.954 [.ItemChannelLinkAddedEvent] - Link ânetwork_pingdevice_e2172ac2_latency-network:pingdevice:e2172ac2:latencyâ has been added.
2020-01-28 13:34:19.961 [.ItemChannelLinkAddedEvent] - Link ânetwork_pingdevice_e2172ac2_lastseen-network:pingdevice:e2172ac2:lastseenâ has been added.
2020-01-28 13:34:19.976 [vent.ItemStateChangedEvent] - network_pingdevice_e2172ac2_lastseen changed from NULL to UNDEF
2020-01-28 13:34:20.301 [vent.ItemStateChangedEvent] - network_pingdevice_e2172ac2_online changed from NULL to ON
2020-01-28 13:34:20.309 [vent.ItemStateChangedEvent] - network_pingdevice_e2172ac2_latency changed from NULL to 377.0 ms
2020-01-28 13:34:20.423 [vent.ItemStateChangedEvent] - network_pingdevice_e2172ac2_lastseen changed from UNDEF to 2020-01-28T13:34:20.417-0800
2020-01-28 13:35:13.807 [vent.ItemStateChangedEvent] - network_pingdevice_192_168_0_17_latency changed from 166.0 ms to 357.0 ms
2020-01-28 13:35:13.849 [vent.ItemStateChangedEvent] - network_pingdevice_192_168_0_17_latency changed from 357.0 ms to 350.0 ms
2020-01-28 13:35:13.853 [vent.ItemStateChangedEvent] - network_pingdevice_192_168_0_17_lastseen changed from 2020-01-28T13:34:13.428-0800 to 2020-01-28T13:35:13.838-0800
2020-01-28 13:35:20.625 [vent.ItemStateChangedEvent] - network_pingdevice_e2172ac2_latency changed from 377.0 ms to 191.0 ms
2020-01-28 13:35:20.812 [vent.ItemStateChangedEvent] - network_pingdevice_e2172ac2_lastseen changed from 2020-01-28T13:34:20.417-0800 to 2020-01-28T13:35:20.798-0800
2020-01-28 13:36:18.952 [vent.ItemStateChangedEvent] - network_pingdevice_192_168_0_17_online changed from ON to OFF
2020-01-28 13:36:18.957 [vent.ItemStateChangedEvent] - network_pingdevice_192_168_0_17_latency changed from 350.0 ms to UNDEF
2020-01-28 13:36:25.911 [vent.ItemStateChangedEvent] - network_pingdevice_e2172ac2_online changed from ON to OFF
2020-01-28 13:36:25.914 [vent.ItemStateChangedEvent] - network_pingdevice_e2172ac2_latency changed from 191.0 ms to UNDEF
2020-01-28 13:36:26.046 [ome.event.ItemCommandEvent] - Item âPresence_Mobile_Daveâ received command OFF
2020-01-28 13:36:26.056 [vent.ItemStateChangedEvent] - Presence_Mobile_Dave changed from ON to OFF
2020-01-28 13:36:26.232 [ome.event.ItemCommandEvent] - Item âWallplug_OF_WindowWallâ received command OFF
2020-01-28 13:36:26.240 [nt.ItemStatePredictedEvent] - Wallplug_OF_WindowWall predicted to become OFF
2020-01-28 13:36:26.270 [vent.ItemStateChangedEvent] - Wallplug_OF_WindowWall changed from ON to OFF
2020-01-28 13:36:26.272 [vent.ItemStateChangedEvent] - zwave_serial_zstick_a3b690b0_serial_ack changed from 208 to 209
2020-01-28 13:36:26.274 [vent.ItemStateChangedEvent] - zwave_serial_zstick_a3b690b0_serial_sof changed from 440 to 441
2020-01-28 13:36:26.287 [vent.ItemStateChangedEvent] - zwave_serial_zstick_a3b690b0_serial_sof changed from 441 to 442
2020-01-28 13:36:27.768 [vent.ItemStateChangedEvent] - zwave_serial_zstick_a3b690b0_serial_ack changed from 209 to 210
2020-01-28 13:36:27.780 [vent.ItemStateChangedEvent] - zwave_serial_zstick_a3b690b0_serial_sof changed from 442 to 443
2020-01-28 13:36:27.791 [vent.ItemStateChangedEvent] - zwave_serial_zstick_a3b690b0_serial_sof changed from 443 to 444
2020-01-28 13:36:27.801 [vent.ItemStateChangedEvent] - zwave_serial_zstick_a3b690b0_serial_sof changed from 444 to 445
2020-01-28 13:36:27.812 [vent.ItemStateChangedEvent] - zwave_device_a3b690b0_node7_switch_binary changed from ON to OFF
2020-01-28 13:36:28.603 [ome.event.ItemCommandEvent] - Item âPresence_Mobile_Daveâ received command ON
2020-01-28 13:36:28.612 [vent.ItemStateChangedEvent] - Presence_Mobile_Dave changed from OFF to ON
2020-01-28 13:36:28.615 [ome.event.ItemCommandEvent] - Item âWallplug_OF_WindowWallâ received command ON
2020-01-28 13:36:28.632 [nt.ItemStatePredictedEvent] - Wallplug_OF_WindowWall predicted to become ON
2020-01-28 13:36:28.655 [vent.ItemStateChangedEvent] - Wallplug_OF_WindowWall changed from OFF to ON
2020-01-28 13:36:28.661 [vent.ItemStateChangedEvent] - zwave_serial_zstick_a3b690b0_serial_ack changed from 210 to 211
2020-01-28 13:36:28.669 [vent.ItemStateChangedEvent] - zwave_serial_zstick_a3b690b0_serial_sof changed from 445 to 446
2020-01-28 13:36:28.683 [vent.ItemStateChangedEvent] - zwave_serial_zstick_a3b690b0_serial_sof changed from 446 to 447
2020-01-28 13:36:30.166 [vent.ItemStateChangedEvent] - zwave_serial_zstick_a3b690b0_serial_ack changed from 211 to 212
2020-01-28 13:36:30.174 [vent.ItemStateChangedEvent] - zwave_serial_zstick_a3b690b0_serial_sof changed from 447 to 448
2020-01-28 13:36:30.188 [vent.ItemStateChangedEvent] - zwave_serial_zstick_a3b690b0_serial_sof changed from 448 to 449
2020-01-28 13:36:30.203 [vent.ItemStateChangedEvent] - zwave_serial_zstick_a3b690b0_serial_sof changed from 449 to 450
2020-01-28 13:36:30.207 [vent.ItemStateChangedEvent] - zwave_device_a3b690b0_node7_switch_binary changed from OFF to ON
2020-01-28 13:39:07.684 [hingStatusInfoChangedEvent] - ânetwork:pingdevice:e2172ac2â changed from ONLINE to REMOVING
2020-01-28 13:39:07.691 [hingStatusInfoChangedEvent] - ânetwork:pingdevice:e2172ac2â changed from REMOVING to REMOVED
2020-01-28 13:39:07.705 [hingStatusInfoChangedEvent] - ânetwork:pingdevice:e2172ac2â changed from REMOVED to UNINITIALIZED
2020-01-28 13:39:07.740 [hingStatusInfoChangedEvent] - ânetwork:pingdevice:e2172ac2â changed from UNINITIALIZED to UNINITIALIZED (HANDLER_MISSING_ERROR)
2020-01-28 13:39:07.759 [temChannelLinkRemovedEvent] - Link ânetwork_pingdevice_e2172ac2_online => network:pingdevice:e2172ac2:onlineâ has been removed.
2020-01-28 13:39:07.763 [temChannelLinkRemovedEvent] - Link ânetwork_pingdevice_e2172ac2_latency => network:pingdevice:e2172ac2:latencyâ has been removed.
2020-01-28 13:39:07.767 [temChannelLinkRemovedEvent] - Link ânetwork_pingdevice_e2172ac2_lastseen => network:pingdevice:e2172ac2:lastseenâ has been removed.
2020-01-28 13:39:21.315 [vent.ItemStateChangedEvent] - network_pingdevice_192_168_0_17_lastseen changed from NULL to 2020-01-28T13:35:13.838-0800
2020-01-28 13:39:21.376 [me.event.ThingUpdatedEvent] - Thing ânetwork:pingdevice:192_168_0_17â has been updated.
2020-01-28 13:39:26.474 [vent.ItemStateChangedEvent] - network_pingdevice_192_168_0_17_online changed from NULL to OFF
2020-01-28 13:39:26.479 [vent.ItemStateChangedEvent] - network_pingdevice_192_168_0_17_latency changed from NULL to UNDEF
2020-01-28 13:39:26.697 [vent.ItemStateChangedEvent] - network_pingdevice_192_168_0_17_latency changed from UNDEF to -1.0 ms
2020-01-28 13:39:26.700 [temChannelLinkRemovedEvent] - Link ânetwork_pingdevice_192_168_0_17_online => network:pingdevice:192_168_0_17:onlineâ has been removed.
2020-01-28 13:39:26.708 [vent.ItemStateChangedEvent] - network_pingdevice_192_168_0_17_latency changed from -1.0 ms to UNDEF
2020-01-28 13:39:28.333 [vent.ItemStateChangedEvent] - network_pingdevice_192_168_0_17_online changed from NULL to OFF
2020-01-28 13:39:28.338 [.ItemChannelLinkAddedEvent] - Link ânetwork_pingdevice_192_168_0_17_online-network:pingdevice:192_168_0_17:onlineâ has been added.
2020-01-28 13:40:38.294 [me.event.InboxRemovedEvent] - Discovery Result with UID ânetwork:pingdevice:192_168_0_16â has been removed.
2020-01-28 13:40:38.300 [me.event.InboxRemovedEvent] - Discovery Result with UID ânetwork:pingdevice:192_168_0_13â has been removed.
2020-01-28 13:40:38.305 [me.event.InboxRemovedEvent] - Discovery Result with UID ânetwork:pingdevice:192_168_0_35â has been removed.
2020-01-28 13:40:38.310 [me.event.InboxRemovedEvent] - Discovery Result with UID ânetwork:pingdevice:192_168_0_14â has been removed.
2020-01-28 13:40:38.317 [me.event.InboxRemovedEvent] - Discovery Result with UID ânetwork:pingdevice:192_168_0_19â has been removed.
2020-01-28 13:40:38.322 [me.event.InboxRemovedEvent] - Discovery Result with UID ânetwork:pingdevice:192_168_0_30â has been removed.
2020-01-28 13:40:38.329 [me.event.InboxRemovedEvent] - Discovery Result with UID ânetwork:servicedevice:192_168_0_1_80â has been removed.
2020-01-28 13:40:38.333 [me.event.InboxRemovedEvent] - Discovery Result with UID ânetwork:pingdevice:192_168_0_11â has been removed.
2020-01-28 13:40:38.338 [me.event.InboxRemovedEvent] - Discovery Result with UID ânetwork:pingdevice:192_168_0_12â has been removed.
2020-01-28 13:40:38.342 [me.event.InboxRemovedEvent] - Discovery Result with UID ânetwork:pingdevice:192_168_0_34â has been removed.
2020-01-28 13:40:38.346 [me.event.InboxRemovedEvent] - Discovery Result with UID ânetwork:pingdevice:192_168_0_31â has been removed.
2020-01-28 13:40:38.351 [me.event.InboxRemovedEvent] - Discovery Result with UID ânetwork:pingdevice:192_168_0_10â has been removed.
2020-01-28 13:40:38.355 [me.event.InboxRemovedEvent] - Discovery Result with UID ânetwork:pingdevice:192_168_0_32â has been removed.
2020-01-28 13:40:38.365 [me.event.InboxRemovedEvent] - Discovery Result with UID ânetwork:servicedevice:192_168_0_42_80â has been removed.
2020-01-28 13:40:38.369 [me.event.InboxRemovedEvent] - Discovery Result with UID ânetwork:pingdevice:192_168_0_26â has been removed.
2020-01-28 13:40:38.375 [me.event.InboxRemovedEvent] - Discovery Result with UID ânetwork:pingdevice:192_168_0_24â has been removed.
2020-01-28 13:40:38.379 [me.event.InboxRemovedEvent] - Discovery Result with UID ânetwork:pingdevice:192_168_0_25â has been removed.
2020-01-28 13:40:38.385 [me.event.InboxRemovedEvent] - Discovery Result with UID ânetwork:pingdevice:192_168_0_28â has been removed.
2020-01-28 13:40:38.390 [me.event.InboxRemovedEvent] - Discovery Result with UID ânetwork:pingdevice:192_168_0_22â has been removed.
2020-01-28 13:40:38.393 [me.event.InboxRemovedEvent] - Discovery Result with UID ânetwork:pingdevice:192_168_0_44â has been removed.
2020-01-28 13:40:38.396 [me.event.InboxRemovedEvent] - Discovery Result with UID ânetwork:pingdevice:192_168_0_23â has been removed.
2020-01-28 13:40:38.398 [me.event.InboxRemovedEvent] - Discovery Result with UID ânetwork:servicedevice:192_168_0_14_80â has been removed.
2020-01-28 13:40:38.401 [me.event.InboxRemovedEvent] - Discovery Result with UID ânetwork:pingdevice:192_168_0_42â has been removed.
2020-01-28 13:40:38.403 [me.event.InboxRemovedEvent] - Discovery Result with UID ânetwork:pingdevice:192_168_0_1â has been removed.
2020-01-28 13:41:08.395 [me.event.InboxRemovedEvent] - Discovery Result with UID ânetwork:pingdevice:192_168_0_254â has been removed.
2020-01-28 13:41:38.736 [ome.event.ItemCommandEvent] - Item âWallplug_OF_WindowWallâ received command OFF
2020-01-28 13:41:38.752 [nt.ItemStatePredictedEvent] - Wallplug_OF_WindowWall predicted to become OFF
2020-01-28 13:41:38.787 [vent.ItemStateChangedEvent] - Wallplug_OF_WindowWall changed from ON to OFF
2020-01-28 13:41:38.793 [vent.ItemStateChangedEvent] - zwave_serial_zstick_a3b690b0_serial_ack changed from 212 to 213
2020-01-28 13:41:38.796 [vent.ItemStateChangedEvent] - zwave_serial_zstick_a3b690b0_serial_sof changed from 450 to 451
2020-01-28 13:41:38.806 [vent.ItemStateChangedEvent] - zwave_serial_zstick_a3b690b0_serial_sof changed from 451 to 452
2020-01-28 13:41:40.028 [ome.event.ItemCommandEvent] - Item âWallplug_OF_WindowWallâ received command ON
2020-01-28 13:41:40.047 [nt.ItemStatePredictedEvent] - Wallplug_OF_WindowWall predicted to become ON
2020-01-28 13:41:40.071 [vent.ItemStateChangedEvent] - Wallplug_OF_WindowWall changed from OFF to ON
2020-01-28 13:41:40.076 [vent.ItemStateChangedEvent] - zwave_serial_zstick_a3b690b0_serial_ack changed from 213 to 214
2020-01-28 13:41:40.082 [vent.ItemStateChangedEvent] - zwave_serial_zstick_a3b690b0_serial_sof changed from 452 to 453
2020-01-28 13:41:40.094 [vent.ItemStateChangedEvent] - zwave_serial_zstick_a3b690b0_serial_sof changed from 453 to 454
2020-01-28 13:41:41.577 [vent.ItemStateChangedEvent] - zwave_serial_zstick_a3b690b0_serial_ack changed from 214 to 215
2020-01-28 13:41:41.585 [vent.ItemStateChangedEvent] - zwave_serial_zstick_a3b690b0_serial_sof changed from 454 to 455
2020-01-28 13:41:41.600 [vent.ItemStateChangedEvent] - zwave_serial_zstick_a3b690b0_serial_sof changed from 455 to 456
2020-01-28 13:41:41.612 [vent.ItemStateChangedEvent] - zwave_serial_zstick_a3b690b0_serial_sof changed from 456 to 457
2020-01-28 13:42:04.037 [vent.ItemStateChangedEvent] - network_pingdevice_192_168_0_17_online changed from OFF to ON
2020-01-28 13:42:04.042 [vent.ItemStateChangedEvent] - network_pingdevice_192_168_0_17_latency changed from UNDEF to 0.0 ms
2020-01-28 13:42:41.786 [vent.ItemStateChangedEvent] - network_pingdevice_192_168_0_17_online changed from ON to OFF
2020-01-28 13:42:41.792 [vent.ItemStateChangedEvent] - network_pingdevice_192_168_0_17_latency changed from 0.0 ms to UNDEF
2020-01-28 13:42:53.049 [vent.ItemStateChangedEvent] - network_pingdevice_192_168_0_17_online changed from OFF to ON
2020-01-28 13:42:53.051 [vent.ItemStateChangedEvent] - network_pingdevice_192_168_0_17_latency changed from UNDEF to 0.0 ms
2020-01-28 13:43:08.340 [ome.event.ItemCommandEvent] - Item âzwave_device_a3b690b0_node7_switch_binaryâ received command OFF
2020-01-28 13:43:08.355 [nt.ItemStatePredictedEvent] - zwave_device_a3b690b0_node7_switch_binary predicted to become OFF
2020-01-28 13:43:08.367 [vent.ItemStateChangedEvent] - zwave_device_a3b690b0_node7_switch_binary changed from ON to OFF
2020-01-28 13:43:08.383 [vent.ItemStateChangedEvent] - zwave_serial_zstick_a3b690b0_serial_ack changed from 215 to 216
2020-01-28 13:43:08.394 [vent.ItemStateChangedEvent] - zwave_serial_zstick_a3b690b0_serial_sof changed from 457 to 458
2020-01-28 13:43:08.405 [vent.ItemStateChangedEvent] - zwave_serial_zstick_a3b690b0_serial_sof changed from 458 to 459
2020-01-28 13:43:09.885 [vent.ItemStateChangedEvent] - zwave_serial_zstick_a3b690b0_serial_ack changed from 216 to 217
2020-01-28 13:43:09.893 [vent.ItemStateChangedEvent] - zwave_serial_zstick_a3b690b0_serial_sof changed from 459 to 460
2020-01-28 13:43:09.909 [vent.ItemStateChangedEvent] - zwave_serial_zstick_a3b690b0_serial_sof changed from 460 to 461
2020-01-28 13:43:09.919 [vent.ItemStateChangedEvent] - zwave_serial_zstick_a3b690b0_serial_sof changed from 461 to 462
2020-01-28 13:43:09.933 [vent.ItemStateChangedEvent] - Wallplug_OF_WindowWall changed from ON to OFF
2020-01-28 13:43:10.140 [ome.event.ItemCommandEvent] - Item âzwave_device_a3b690b0_node7_switch_binaryâ received command ON
2020-01-28 13:43:10.158 [nt.ItemStatePredictedEvent] - zwave_device_a3b690b0_node7_switch_binary predicted to become ON
2020-01-28 13:43:10.173 [vent.ItemStateChangedEvent] - zwave_device_a3b690b0_node7_switch_binary changed from OFF to ON
2020-01-28 13:43:10.184 [vent.ItemStateChangedEvent] - zwave_serial_zstick_a3b690b0_serial_ack changed from 217 to 218
2020-01-28 13:43:10.190 [vent.ItemStateChangedEvent] - zwave_serial_zstick_a3b690b0_serial_sof changed from 462 to 463
2020-01-28 13:43:10.203 [vent.ItemStateChangedEvent] - zwave_serial_zstick_a3b690b0_serial_sof changed from 463 to 464
2020-01-28 13:43:11.687 [vent.ItemStateChangedEvent] - zwave_serial_zstick_a3b690b0_serial_ack changed from 218 to 219
2020-01-28 13:43:11.695 [vent.ItemStateChangedEvent] - zwave_serial_zstick_a3b690b0_serial_sof changed from 464 to 465
2020-01-28 13:43:11.708 [vent.ItemStateChangedEvent] - zwave_serial_zstick_a3b690b0_serial_sof changed from 465 to 466
2020-01-28 13:43:11.722 [vent.ItemStateChangedEvent] - zwave_serial_zstick_a3b690b0_serial_sof changed from 466 to 467
2020-01-28 13:43:11.728 [vent.ItemStateChangedEvent] - Wallplug_OF_WindowWall changed from OFF to ON
2020-01-28 13:43:13.073 [ome.event.ItemCommandEvent] - Item âWallplug_OF_WindowWallâ received command OFF
2020-01-28 13:43:13.090 [nt.ItemStatePredictedEvent] - Wallplug_OF_WindowWall predicted to become OFF
2020-01-28 13:43:13.122 [vent.ItemStateChangedEvent] - Wallplug_OF_WindowWall changed from ON to OFF
2020-01-28 13:43:13.127 [vent.ItemStateChangedEvent] - zwave_serial_zstick_a3b690b0_serial_ack changed from 219 to 220
2020-01-28 13:43:13.133 [vent.ItemStateChangedEvent] - zwave_serial_zstick_a3b690b0_serial_sof changed from 467 to 468
2020-01-28 13:43:13.136 [vent.ItemStateChangedEvent] - zwave_serial_zstick_a3b690b0_serial_sof changed from 468 to 469
2020-01-28 13:43:14.618 [vent.ItemStateChangedEvent] - zwave_serial_zstick_a3b690b0_serial_ack changed from 220 to 221
2020-01-28 13:43:14.625 [vent.ItemStateChangedEvent] - zwave_serial_zstick_a3b690b0_serial_sof changed from 469 to 470
2020-01-28 13:43:14.640 [vent.ItemStateChangedEvent] - zwave_serial_zstick_a3b690b0_serial_sof changed from 470 to 471
2020-01-28 13:43:14.656 [vent.ItemStateChangedEvent] - zwave_serial_zstick_a3b690b0_serial_sof changed from 471 to 472
2020-01-28 13:43:14.658 [vent.ItemStateChangedEvent] - zwave_device_a3b690b0_node7_switch_binary changed from ON to OFF
2020-01-28 13:43:14.728 [ome.event.ItemCommandEvent] - Item âWallplug_OF_WindowWallâ received command ON
2020-01-28 13:43:14.754 [nt.ItemStatePredictedEvent] - Wallplug_OF_WindowWall predicted to become ON
2020-01-28 13:43:14.782 [vent.ItemStateChangedEvent] - Wallplug_OF_WindowWall changed from OFF to ON
2020-01-28 13:43:14.792 [vent.ItemStateChangedEvent] - zwave_serial_zstick_a3b690b0_serial_ack changed from 221 to 222
2020-01-28 13:43:14.795 [vent.ItemStateChangedEvent] - zwave_serial_zstick_a3b690b0_serial_sof changed from 472 to 473
2020-01-28 13:43:14.802 [vent.ItemStateChangedEvent] - zwave_serial_zstick_a3b690b0_serial_sof changed from 473 to 474
2020-01-28 13:43:16.282 [vent.ItemStateChangedEvent] - zwave_serial_zstick_a3b690b0_serial_ack changed from 222 to 223
2020-01-28 13:43:16.288 [vent.ItemStateChangedEvent] - zwave_serial_zstick_a3b690b0_serial_sof changed from 474 to 475
2020-01-28 13:43:16.304 [vent.ItemStateChangedEvent] - zwave_serial_zstick_a3b690b0_serial_sof changed from 475 to 476
2020-01-28 13:43:16.315 [vent.ItemStateChangedEvent] - zwave_serial_zstick_a3b690b0_serial_sof changed from 476 to 477
2020-01-28 13:43:16.320 [vent.ItemStateChangedEvent] - zwave_device_a3b690b0_node7_switch_binary changed from OFF to ON
2020-01-28 13:43:42.057 [vent.ItemStateChangedEvent] - network_pingdevice_192_168_0_17_latency changed from 0.0 ms to 254.0 ms
2020-01-28 13:43:42.183 [vent.ItemStateChangedEvent] - network_pingdevice_192_168_0_17_lastseen changed from 2020-01-28T13:35:13.838-0800 to 2020-01-28T13:43:42.168-0800
2020-01-28 13:44:42.264 [vent.ItemStateChangedEvent] - network_pingdevice_192_168_0_17_latency changed from 254.0 ms to 75.0 ms
2020-01-28 13:44:43.622 [vent.ItemStateChangedEvent] - network_pingdevice_192_168_0_17_lastseen changed from 2020-01-28T13:43:42.168-0800 to 2020-01-28T13:44:43.608-0800
2020-01-28 13:45:46.993 [vent.ItemStateChangedEvent] - network_pingdevice_192_168_0_17_latency changed from 75.0 ms to 3311.0 ms
2020-01-28 13:45:46.996 [vent.ItemStateChangedEvent] - network_pingdevice_192_168_0_17_lastseen changed from 2020-01-28T13:44:43.608-0800 to 2020-01-28T13:45:46.978-0800
2020-01-28 13:46:47.094 [vent.ItemStateChangedEvent] - network_pingdevice_192_168_0_17_latency changed from 3311.0 ms to 93.0 ms
2020-01-28 13:46:47.575 [vent.ItemStateChangedEvent] - network_pingdevice_192_168_0_17_lastseen changed from 2020-01-28T13:45:46.978-0800 to 2020-01-28T13:46:47.558-0800
2020-01-28 13:47:47.615 [vent.ItemStateChangedEvent] - network_pingdevice_192_168_0_17_latency changed from 93.0 ms to 36.0 ms
2020-01-28 13:47:48.026 [vent.ItemStateChangedEvent] - network_pingdevice_192_168_0_17_lastseen changed from 2020-01-28T13:46:47.558-0800 to 2020-01-28T13:47:48.008-0800
2020-01-28 13:48:48.056 [vent.ItemStateChangedEvent] - network_pingdevice_192_168_0_17_latency changed from 36.0 ms to 23.0 ms
2020-01-28 13:48:48.442 [vent.ItemStateChangedEvent] - network_pingdevice_192_168_0_17_lastseen changed from 2020-01-28T13:47:48.008-0800 to 2020-01-28T13:48:48.428-0800
2020-01-28 13:49:48.479 [vent.ItemStateChangedEvent] - network_pingdevice_192_168_0_17_latency changed from 23.0 ms to 33.0 ms
2020-01-28 13:49:48.864 [vent.ItemStateChangedEvent] - network_pingdevice_192_168_0_17_lastseen changed from 2020-01-28T13:48:48.428-0800 to 2020-01-28T13:49:48.848-0800
2020-01-28 13:50:27.604 [home.event.InboxAddedEvent] - Discovery Result with UID ânetwork:servicedevice:192_168_0_1_80â has been added.
2020-01-28 13:50:27.623 [home.event.InboxAddedEvent] - Discovery Result with UID ânetwork:pingdevice:192_168_0_1â has been added.
2020-01-28 13:50:28.236 [home.event.InboxAddedEvent] - Discovery Result with UID ânetwork:pingdevice:192_168_0_10â has been added.
2020-01-28 13:50:28.262 [home.event.InboxAddedEvent] - Discovery Result with UID ânetwork:pingdevice:192_168_0_11â has been added.
2020-01-28 13:50:28.275 [home.event.InboxAddedEvent] - Discovery Result with UID ânetwork:pingdevice:192_168_0_12â has been added.
2020-01-28 13:50:28.293 [home.event.InboxAddedEvent] - Discovery Result with UID ânetwork:pingdevice:192_168_0_13â has been added.
2020-01-28 13:50:28.308 [home.event.InboxAddedEvent] - Discovery Result with UID ânetwork:servicedevice:192_168_0_14_80â has been added.
2020-01-28 13:50:28.316 [home.event.InboxAddedEvent] - Discovery Result with UID ânetwork:pingdevice:192_168_0_14â has been added.
2020-01-28 13:50:28.349 [home.event.InboxAddedEvent] - Discovery Result with UID ânetwork:pingdevice:192_168_0_16â has been added.
2020-01-28 13:50:28.738 [home.event.InboxAddedEvent] - Discovery Result with UID ânetwork:pingdevice:192_168_0_19â has been added.
2020-01-28 13:50:28.770 [home.event.InboxAddedEvent] - Discovery Result with UID ânetwork:pingdevice:192_168_0_22â has been added.
2020-01-28 13:50:28.781 [home.event.InboxAddedEvent] - Discovery Result with UID ânetwork:pingdevice:192_168_0_23â has been added.
2020-01-28 13:50:28.941 [home.event.InboxAddedEvent] - Discovery Result with UID ânetwork:pingdevice:192_168_0_24â has been added.
2020-01-28 13:50:29.131 [home.event.InboxAddedEvent] - Discovery Result with UID ânetwork:pingdevice:192_168_0_25â has been added.
2020-01-28 13:50:29.168 [home.event.InboxAddedEvent] - Discovery Result with UID ânetwork:pingdevice:192_168_0_26â has been added.
2020-01-28 13:50:29.226 [home.event.InboxAddedEvent] - Discovery Result with UID ânetwork:pingdevice:192_168_0_28â has been added.
2020-01-28 13:50:29.343 [home.event.InboxAddedEvent] - Discovery Result with UID ânetwork:pingdevice:192_168_0_30â has been added.
2020-01-28 13:50:29.367 [home.event.InboxAddedEvent] - Discovery Result with UID ânetwork:pingdevice:192_168_0_31â has been added.
2020-01-28 13:50:29.372 [home.event.InboxAddedEvent] - Discovery Result with UID ânetwork:pingdevice:192_168_0_32â has been added.
2020-01-28 13:50:29.606 [home.event.InboxAddedEvent] - Discovery Result with UID ânetwork:pingdevice:192_168_0_34â has been added.
2020-01-28 13:50:30.120 [home.event.InboxAddedEvent] - Discovery Result with UID ânetwork:servicedevice:192_168_0_42_80â has been added.
2020-01-28 13:50:30.142 [home.event.InboxAddedEvent] - Discovery Result with UID ânetwork:pingdevice:192_168_0_42â has been added.
2020-01-28 13:50:30.157 [home.event.InboxAddedEvent] - Discovery Result with UID ânetwork:pingdevice:192_168_0_35â has been added.
2020-01-28 13:50:30.407 [home.event.InboxAddedEvent] - Discovery Result with UID ânetwork:pingdevice:192_168_0_44â has been added.
2020-01-28 13:50:46.149 [home.event.InboxAddedEvent] - Discovery Result with UID ânetwork:pingdevice:192_168_0_254â has been added.
2020-01-28 13:50:49.054 [vent.ItemStateChangedEvent] - network_pingdevice_192_168_0_17_latency changed from 33.0 ms to 179.0 ms
2020-01-28 13:50:49.303 [vent.ItemStateChangedEvent] - network_pingdevice_192_168_0_17_lastseen changed from 2020-01-28T13:49:48.848-0800 to 2020-01-28T13:50:49.288-0800
2020-01-28 13:51:07.553 [me.event.InboxRemovedEvent] - Discovery Result with UID ânetwork:pingdevice:192_168_0_16â has been removed.
2020-01-28 13:51:07.561 [me.event.InboxRemovedEvent] - Discovery Result with UID ânetwork:pingdevice:192_168_0_13â has been removed.
2020-01-28 13:51:07.567 [me.event.InboxRemovedEvent] - Discovery Result with UID ânetwork:pingdevice:192_168_0_35â has been removed.
2020-01-28 13:51:07.574 [me.event.InboxRemovedEvent] - Discovery Result with UID ânetwork:pingdevice:192_168_0_14â has been removed.
2020-01-28 13:51:07.583 [me.event.InboxRemovedEvent] - Discovery Result with UID ânetwork:pingdevice:192_168_0_19â has been removed.
2020-01-28 13:51:07.589 [me.event.InboxRemovedEvent] - Discovery Result with UID ânetwork:pingdevice:192_168_0_30â has been removed.
2020-01-28 13:51:07.595 [me.event.InboxRemovedEvent] - Discovery Result with UID ânetwork:servicedevice:192_168_0_1_80â has been removed.
2020-01-28 13:51:07.597 [me.event.InboxRemovedEvent] - Discovery Result with UID ânetwork:pingdevice:192_168_0_11â has been removed.
2020-01-28 13:51:07.600 [me.event.InboxRemovedEvent] - Discovery Result with UID ânetwork:pingdevice:192_168_0_12â has been removed.
2020-01-28 13:51:07.602 [me.event.InboxRemovedEvent] - Discovery Result with UID ânetwork:pingdevice:192_168_0_34â has been removed.
2020-01-28 13:51:07.604 [me.event.InboxRemovedEvent] - Discovery Result with UID ânetwork:pingdevice:192_168_0_31â has been removed.
2020-01-28 13:51:07.607 [me.event.InboxRemovedEvent] - Discovery Result with UID ânetwork:pingdevice:192_168_0_10â has been removed.
2020-01-28 13:51:07.609 [me.event.InboxRemovedEvent] - Discovery Result with UID ânetwork:pingdevice:192_168_0_32â has been removed.
2020-01-28 13:51:07.611 [me.event.InboxRemovedEvent] - Discovery Result with UID ânetwork:pingdevice:192_168_0_254â has been removed.
2020-01-28 13:51:07.616 [me.event.InboxRemovedEvent] - Discovery Result with UID ânetwork:servicedevice:192_168_0_42_80â has been removed.
2020-01-28 13:51:07.618 [me.event.InboxRemovedEvent] - Discovery Result with UID ânetwork:pingdevice:192_168_0_26â has been removed.
2020-01-28 13:51:07.620 [me.event.InboxRemovedEvent] - Discovery Result with UID ânetwork:pingdevice:192_168_0_24â has been removed.
2020-01-28 13:51:07.623 [me.event.InboxRemovedEvent] - Discovery Result with UID ânetwork:pingdevice:192_168_0_25â has been removed.
2020-01-28 13:51:07.625 [me.event.InboxRemovedEvent] - Discovery Result with UID ânetwork:pingdevice:192_168_0_28â has been removed.
2020-01-28 13:51:07.627 [me.event.InboxRemovedEvent] - Discovery Result with UID ânetwork:pingdevice:192_168_0_22â has been removed.
2020-01-28 13:51:07.629 [me.event.InboxRemovedEvent] - Discovery Result with UID ânetwork:pingdevice:192_168_0_44â has been removed.
2020-01-28 13:51:07.631 [me.event.InboxRemovedEvent] - Discovery Result with UID ânetwork:pingdevice:192_168_0_23â has been removed.
2020-01-28 13:51:07.633 [me.event.InboxRemovedEvent] - Discovery Result with UID ânetwork:servicedevice:192_168_0_14_80â has been removed.
2020-01-28 13:51:07.635 [me.event.InboxRemovedEvent] - Discovery Result with UID ânetwork:pingdevice:192_168_0_42â has been removed.
2020-01-28 13:51:07.637 [me.event.InboxRemovedEvent] - Discovery Result with UID ânetwork:pingdevice:192_168_0_1â has been removed.
2020-01-28 13:51:07.650 [home.event.InboxAddedEvent] - Discovery Result with UID ânetwork:servicedevice:192_168_0_1_80â has been added.
2020-01-28 13:51:07.664 [home.event.InboxAddedEvent] - Discovery Result with UID ânetwork:pingdevice:192_168_0_1â has been added.
2020-01-28 13:51:08.274 [home.event.InboxAddedEvent] - Discovery Result with UID ânetwork:pingdevice:192_168_0_10â has been added.
2020-01-28 13:51:08.285 [home.event.InboxAddedEvent] - Discovery Result with UID ânetwork:pingdevice:192_168_0_11â has been added.
2020-01-28 13:51:08.292 [home.event.InboxAddedEvent] - Discovery Result with UID ânetwork:pingdevice:192_168_0_12â has been added.
2020-01-28 13:51:08.301 [home.event.InboxAddedEvent] - Discovery Result with UID ânetwork:servicedevice:192_168_0_14_80â has been added.
2020-01-28 13:51:08.317 [home.event.InboxAddedEvent] - Discovery Result with UID ânetwork:pingdevice:192_168_0_13â has been added.
2020-01-28 13:51:08.350 [home.event.InboxAddedEvent] - Discovery Result with UID ânetwork:pingdevice:192_168_0_14â has been added.
2020-01-28 13:51:08.389 [home.event.InboxAddedEvent] - Discovery Result with UID ânetwork:pingdevice:192_168_0_16â has been added.
2020-01-28 13:51:08.719 [home.event.InboxAddedEvent] - Discovery Result with UID ânetwork:pingdevice:192_168_0_19â has been added.
2020-01-28 13:51:08.794 [home.event.InboxAddedEvent] - Discovery Result with UID ânetwork:pingdevice:192_168_0_22â has been added.
2020-01-28 13:51:08.820 [home.event.InboxAddedEvent] - Discovery Result with UID ânetwork:pingdevice:192_168_0_23â has been added.
2020-01-28 13:51:08.958 [home.event.InboxAddedEvent] - Discovery Result with UID ânetwork:pingdevice:192_168_0_24â has been added.
2020-01-28 13:51:09.072 [home.event.InboxAddedEvent] - Discovery Result with UID ânetwork:pingdevice:192_168_0_25â has been added.
2020-01-28 13:51:09.098 [home.event.InboxAddedEvent] - Discovery Result with UID ânetwork:pingdevice:192_168_0_26â has been added.
2020-01-28 13:51:09.245 [home.event.InboxAddedEvent] - Discovery Result with UID ânetwork:pingdevice:192_168_0_28â has been added.
2020-01-28 13:51:09.364 [home.event.InboxAddedEvent] - Discovery Result with UID ânetwork:pingdevice:192_168_0_30â has been added.
2020-01-28 13:51:09.386 [home.event.InboxAddedEvent] - Discovery Result with UID ânetwork:pingdevice:192_168_0_31â has been added.
2020-01-28 13:51:09.401 [home.event.InboxAddedEvent] - Discovery Result with UID ânetwork:pingdevice:192_168_0_32â has been added.
2020-01-28 13:51:09.489 [home.event.InboxAddedEvent] - Discovery Result with UID ânetwork:pingdevice:192_168_0_34â has been added.
2020-01-28 13:51:09.998 [home.event.InboxAddedEvent] - Discovery Result with UID ânetwork:servicedevice:192_168_0_42_80â has been added.
2020-01-28 13:51:10.020 [home.event.InboxAddedEvent] - Discovery Result with UID ânetwork:pingdevice:192_168_0_42â has been added.
2020-01-28 13:51:10.410 [home.event.InboxAddedEvent] - Discovery Result with UID ânetwork:pingdevice:192_168_0_44â has been added.
2020-01-28 13:51:26.184 [home.event.InboxAddedEvent] - Discovery Result with UID ânetwork:pingdevice:192_168_0_254â has been added.
2020-01-27 15:31:31.541 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item âWallplug_OF_WindowWallâ for widget org.eclipse.smarthome.model.sitemap.sitemap.Switch
2020-01-27 15:31:31.545 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item for widget org.eclipse.smarthome.model.sitemap.sitemap.Switch
2020-01-27 15:31:31.548 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item âWallplug_OF_WindowWallâ for widget org.eclipse.smarthome.model.sitemap.sitemap.Switch
2020-01-27 15:31:31.551 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item âWallplug_OF_WindowWallâ for widget org.eclipse.smarthome.model.sitemap.sitemap.Switch
2020-01-27 15:31:31.554 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item âWallplug_OF_WindowWallâ for widget org.eclipse.smarthome.model.sitemap.sitemap.Switch
2020-01-27 15:31:36.576 [INFO ] [rest.core.internal.item.ItemResource] - Received HTTP POST request at âitems/Wallplug_OF_WindowWallâ for the unknown item âWallplug_OF_WindowWallâ.
2020-01-27 15:31:40.262 [INFO ] [rest.core.internal.item.ItemResource] - Received HTTP POST request at âitems/Wallplug_OF_WindowWallâ for the unknown item âWallplug_OF_WindowWallâ.
2020-01-27 15:34:34.269 [INFO ] [el.core.internal.ModelRepositoryImpl] - Refreshing model âdefault.sitemapâ
2020-01-27 15:34:34.299 [WARN ] [basic.internal.render.SwitchRenderer] - Cannot determine item type of âPresence_Mobile_Daveâ
org.eclipse.smarthome.core.items.ItemNotFoundException: Item âPresence_Mobile_Daveâ could not be found in the item registry
at org.eclipse.smarthome.core.internal.items.ItemRegistryImpl.getItem(ItemRegistryImpl.java:85) ~[?:?]
at org.eclipse.smarthome.ui.internal.items.ItemUIRegistryImpl.getItem(ItemUIRegistryImpl.java:837) ~[?:?]
at org.openhab.ui.basic.internal.render.SwitchRenderer.renderWidget(SwitchRenderer.java:85) [bundleFile:?]
at org.openhab.ui.basic.internal.render.PageRenderer.renderWidget(PageRenderer.java:194) [bundleFile:?]
at org.openhab.ui.basic.internal.render.PageRenderer.processChildren(PageRenderer.java:160) [bundleFile:?]
at org.openhab.ui.basic.internal.render.PageRenderer.processPage(PageRenderer.java:124) [bundleFile:?]
at org.openhab.ui.basic.internal.servlet.WebAppServlet.service(WebAppServlet.java:189) [bundleFile:?]
at javax.servlet.http.HttpServlet.service(HttpServlet.java:790) [bundleFile:3.1.0]
at org.eclipse.jetty.servlet.ServletHolder.handle(ServletHolder.java:852) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.servlet.ServletHandler.doHandle(ServletHandler.java:544) [bundleFile:9.4.20.v20190813]
at org.ops4j.pax.web.service.jetty.internal.HttpServiceServletHandler.doHandle(HttpServiceServletHandler.java:71) [bundleFile:?]
at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:143) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.security.SecurityHandler.handle(SecurityHandler.java:536) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.server.handler.HandlerWrapper.handle(HandlerWrapper.java:127) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.server.handler.ScopedHandler.nextHandle(ScopedHandler.java:235) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.server.session.SessionHandler.doHandle(SessionHandler.java:1581) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.server.handler.ScopedHandler.nextHandle(ScopedHandler.java:233) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.server.handler.ContextHandler.doHandle(ContextHandler.java:1307) [bundleFile:9.4.20.v20190813]
at org.ops4j.pax.web.service.jetty.internal.HttpServiceContext.doHandle(HttpServiceContext.java:293) [bundleFile:?]
at org.eclipse.jetty.server.handler.ScopedHandler.nextScope(ScopedHandler.java:188) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.servlet.ServletHandler.doScope(ServletHandler.java:482) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.server.session.SessionHandler.doScope(SessionHandler.java:1549) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.server.handler.ScopedHandler.nextScope(ScopedHandler.java:186) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.server.handler.ContextHandler.doScope(ContextHandler.java:1204) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:141) [bundleFile:9.4.20.v20190813]
at org.ops4j.pax.web.service.jetty.internal.JettyServerHandlerCollection.handle(JettyServerHandlerCollection.java:80) [bundleFile:?]
at org.eclipse.jetty.server.Server.handle(Server.java:494) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.server.HttpChannel.handle(HttpChannel.java:374) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.server.HttpConnection.onFillable(HttpConnection.java:268) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.io.AbstractConnection$ReadCallback.succeeded(AbstractConnection.java:311) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.io.FillInterest.fillable(FillInterest.java:103) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.io.ChannelEndPoint$2.run(ChannelEndPoint.java:117) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.runTask(EatWhatYouKill.java:336) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.doProduce(EatWhatYouKill.java:313) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.tryProduce(EatWhatYouKill.java:171) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.run(EatWhatYouKill.java:129) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.util.thread.ReservedThreadExecutor$ReservedThread.run(ReservedThreadExecutor.java:367) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.util.thread.QueuedThreadPool.runJob(QueuedThreadPool.java:782) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.util.thread.QueuedThreadPool$Runner.run(QueuedThreadPool.java:918) [bundleFile:9.4.20.v20190813]
at java.lang.Thread.run(Thread.java:748) [?:1.8.0_222]
2020-01-27 15:34:34.314 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item âPresence_Mobile_Daveâ for widget org.eclipse.smarthome.model.sitemap.sitemap.Switch
2020-01-27 15:34:34.318 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item for widget org.eclipse.smarthome.model.sitemap.sitemap.Switch
2020-01-27 15:34:34.321 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item âPresence_Mobile_Daveâ for widget org.eclipse.smarthome.model.sitemap.sitemap.Switch
2020-01-27 15:34:34.324 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item âPresence_Mobile_Daveâ for widget org.eclipse.smarthome.model.sitemap.sitemap.Switch
2020-01-27 15:34:34.328 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item âPresence_Mobile_Daveâ for widget org.eclipse.smarthome.model.sitemap.sitemap.Switch
2020-01-27 15:34:34.331 [WARN ] [basic.internal.render.SwitchRenderer] - Cannot determine item type of âWallplug_OF_WindowWallâ
org.eclipse.smarthome.core.items.ItemNotFoundException: Item âWallplug_OF_WindowWallâ could not be found in the item registry
2020-01-27 15:34:34.347 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item âWallplug_OF_WindowWallâ for widget org.eclipse.smarthome.model.sitemap.sitemap.Switch
2020-01-27 15:34:34.350 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item for widget org.eclipse.smarthome.model.sitemap.sitemap.Switch
2020-01-27 15:34:34.353 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item âWallplug_OF_WindowWallâ for widget org.eclipse.smarthome.model.sitemap.sitemap.Switch
2020-01-27 15:34:34.356 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item âWallplug_OF_WindowWallâ for widget org.eclipse.smarthome.model.sitemap.sitemap.Switch
2020-01-27 15:34:34.359 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item âWallplug_OF_WindowWallâ for widget org.eclipse.smarthome.model.sitemap.sitemap.Switch
2020-01-27 15:34:41.734 [WARN ] [basic.internal.render.SwitchRenderer] - Cannot determine item type of âPresence_Mobile_Daveâ
2020-01-27 15:34:41.761 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item âPresence_Mobile_Daveâ for widget org.eclipse.smarthome.model.sitemap.sitemap.Switch
2020-01-27 15:34:41.764 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item for widget org.eclipse.smarthome.model.sitemap.sitemap.Switch
2020-01-27 15:34:41.766 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item âPresence_Mobile_Daveâ for widget org.eclipse.smarthome.model.sitemap.sitemap.Switch
2020-01-27 15:34:41.769 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item âPresence_Mobile_Daveâ for widget org.eclipse.smarthome.model.sitemap.sitemap.Switch
2020-01-27 15:34:41.771 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item âPresence_Mobile_Daveâ for widget org.eclipse.smarthome.model.sitemap.sitemap.Switch
2020-01-27 15:34:41.773 [WARN ] [basic.internal.render.SwitchRenderer] - Cannot determine item type of âWallplug_OF_WindowWallâ
2020-01-27 15:34:41.788 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item âWallplug_OF_WindowWallâ for widget org.eclipse.smarthome.model.sitemap.sitemap.Switch
2020-01-27 15:34:41.791 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item for widget org.eclipse.smarthome.model.sitemap.sitemap.Switch
2020-01-27 15:34:41.794 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item âWallplug_OF_WindowWallâ for widget org.eclipse.smarthome.model.sitemap.sitemap.Switch
2020-01-27 15:34:41.798 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item âWallplug_OF_WindowWallâ for widget org.eclipse.smarthome.model.sitemap.sitemap.Switch
2020-01-27 15:34:41.800 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item âWallplug_OF_WindowWallâ for widget org.eclipse.smarthome.model.sitemap.sitemap.Switch
2020-01-27 18:07:48.367 [WARN ] [basic.internal.render.SwitchRenderer] - Cannot determine item type of âPresence_Mobile_Daveâ
2020-01-27 18:07:48.389 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item âPresence_Mobile_Daveâ for widget org.eclipse.smarthome.model.sitemap.sitemap.Switch
2020-01-27 18:07:48.391 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item for widget org.eclipse.smarthome.model.sitemap.sitemap.Switch
2020-01-27 18:07:48.395 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item âPresence_Mobile_Daveâ for widget org.eclipse.smarthome.model.sitemap.sitemap.Switch
2020-01-27 18:07:48.398 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item âPresence_Mobile_Daveâ for widget org.eclipse.smarthome.model.sitemap.sitemap.Switch
2020-01-27 18:07:48.401 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item âPresence_Mobile_Daveâ for widget org.eclipse.smarthome.model.sitemap.sitemap.Switch
2020-01-27 18:07:48.404 [WARN ] [basic.internal.render.SwitchRenderer] - Cannot determine item type of âWallplug_OF_WindowWallâ
2020-01-27 18:07:48.425 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item âWallplug_OF_WindowWallâ for widget org.eclipse.smarthome.model.sitemap.sitemap.Switch
2020-01-27 18:07:48.427 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item for widget org.eclipse.smarthome.model.sitemap.sitemap.Switch
2020-01-27 18:07:48.431 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item âWallplug_OF_WindowWallâ for widget org.eclipse.smarthome.model.sitemap.sitemap.Switch
2020-01-27 18:07:48.434 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item âWallplug_OF_WindowWallâ for widget org.eclipse.smarthome.model.sitemap.sitemap.Switch
2020-01-27 18:07:48.438 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item âWallplug_OF_WindowWallâ for widget org.eclipse.smarthome.model.sitemap.sitemap.Switch
2020-01-28 09:46:14.660 [WARN ] [el.core.internal.ModelRepositoryImpl] - Configuration model âdefault.itemsâ has errors, therefore ignoring it: [3,76]: mismatched character ââ expecting â"â
Just a quick scan of the logs I would turn off simple mode, remove your Things, items and comments out the rule. Stop OH, clean the cache and rediscover and link everything again then add back the rule.
To clean the cache use:
sudo systemctl stop openhab2
sudo openhab-cli clean-cache
sudo systemctl start openhab2
FYI: OH will take a few minutes to fully restart after the cache cleaning.
