In a rule i need (from a directory of *.avi and *.jpg files) to get the name of the latest jpg file.
Is anyone who can give me some hints?
-ben
-ben
Google is your friend:
For linux:
To get the Most recent file in another directory , for example in /opt/spark/ :
ls /opt/spark/ -Art | tail -n 1
To filer the jpg add a grep:
ls /opt/spark/ -Art | grep .jpg | tail -n 1
So in a rule:
var String fileName = executeCommandLine("ls /opt/spark/ -Art | grep .jpg | tail -n 1", 500) //Give 500ms to return a query
Thanks for the info, i tried to make a rule in java but this looks much easier …
I used your code but it doesn’t work, oh is complaining that directory does not exists etc while it does not.
rule:
var String PathToImage = "/backup/camera/frontdoor/" + String::format("%1$tY-%1$tm-%1$te", new java.util.Date) + "/"
//var String CurrentDate = String::format("%1$ty-%1$tm-%1$te", new java.util.Date)
logInfo ("path to file", PathToImage)
var String cmd = "ls -Art " + PathToImage + " | grep .jpg | tail -n 1"
logInfo ("cmd", cmd)
var String fileName = executeCommandLine(cmd, 1500) //Give 500ms to return a query
logInfo ("file ", fileName)
oh log:
2019-01-23 14:08:55.327 [INFO ] [.smarthome.model.script.path to file] - /backup/camera/frontdoor/2019-01-23/
2019-01-23 14:08:55.339 [INFO ] [g.eclipse.smarthome.model.script.cmd] - ls -Art /backup/camera/frontdoor/2019-01-23/ | grep .jpg | tail -n 1
2019-01-23 14:08:55.399 [INFO ] [eclipse.smarthome.model.script.file ] - ls: cannot access |: No such file or directory
ls: cannot access grep: No such file or directory
ls: cannot access .jpg: No such file or directory
ls: cannot access tail: No such file or directory
ls: cannot access 1: No such file or directory
/backup/camera/frontdoor/2019-01-23/:
total 6532
-rwxrwxrwx 1 0 0 1601766 Jan 23 07:14 07-14-11.avi
-rwxrwxrwx 1 0 0 310952 Jan 23 07:14 07-14-19.jpg
-rwxrwxrwx 1 0 0 15364 Jan 23 07:14 07-14-11.avi.thumb
-rwxrwxrwx 1 0 0 1282312 Jan 23 07:15 07-15-10.avi
-rwxrwxrwx 1 0 0 290069 Jan 23 07:15 07-15-11.jpg
-rwxrwxrwx 1 0 0 14493 Jan 23 07:15 07-15-10.avi.thumb
-rwxrwxrwx 1 0 0 2800402 Jan 23 13:13 13-13-07.avi
-rwxrwxrwx 1 0 0 311981 Jan 23 13:13 13-13-10.jpg
-rwxrwxrwx 1 0 0 43623 Jan 23 13:13 13-13-07.avi.thumb
If I run the concatened cmd “ls -Art /backup/camera/frontdoor/2019-01-23/ | grep .jpg | tail -n 1” in a shell, it returns the correct file, so the command is working!
-ben
var String cmd = "ls " + PathToImage + "-Art | grep .jpg | tail -n 1"
Changed the code but same result :
2019-01-23 15:05:15.885 [INFO ] [.smarthome.model.script.path to file] - /backup/camera/frontdoor/2019-01-23/
2019-01-23 15:05:15.893 [INFO ] [g.eclipse.smarthome.model.script.cmd] - ls /backup/camera/frontdoor/2019-01-23/ -Art | grep .jpg | tail -n 1
2019-01-23 15:05:15.952 [INFO ] [eclipse.smarthome.model.script.file ] - /backup/camera/frontdoor/2019-01-23/:
total 6532
-ben
remove the / at the end:
Same error …
result from cli:
[16:32:31] openhabian@openhabianpi:~$ ls /backup/camera/frontdoor/2019-01-23 -Art | grep .jpg | tail -n 1
Fromthe docs: Actions | openHAB
Note: The commandLine variable often has to use a special format where @@ needs to be used in place of spaces. For example the bash command touch somefile will have to be written as touch@@somefile
So change your code to:
var String cmd = "ls@@" + PathToImage + "-Art@@|@@grep@@.jpg@@|@@tail@@-n@@1"
Also adding the @ did not work, I changed my program and called a bash script from OH.
This now works fine, thanks for all your suggestions.
PS. Somehow it looked like the exec did not liked the ‘|’ command.
