I’m running OH2.4 on an RPi3 and I’m trying to get the weather 1.13 to work. I installed the binding through PaperUI. Stopped OH2 and edited weather.cfg and gave these settings:
I restarted OH2, saw no errors in the console. My Items are defined like this:
Number outside_temperature "Temperature [%.2f °F]" <humidity> {weather="locationId=home, type=temperature, property=current"}
Number outside_humidity "Humidity [%d %%]" <temperature> {weather="locationId=home, type=atmosphere, property=humidity"}
And the Items have been added to my sitemap. I only want to display these values. I added couple of rules to log when updates to the items occur, but nothing is ever written to the log. I forgot to put the binding in debug mode, I’ll post whatever I see there, but if anyone has any ideas, I appreciate it.
org.osgi.service.cm.ConfigurationException: weather : Parameter 'location.<locationId1>.updateInterval' empty or in wrong format ('"10"'). Check openhab.cfg.
I don’t have an openhab.cfg, in the services directory, only weather.cfg and that is as I have already posted. I did find a file in /var/lib/openhab2/config/org/openhab/weather.cfg and it has these contents:
