I am trying to set up the Google Calendar scheduler, and got these instructions in the logs:
2018-12-22 18:36:14.437 [INFO ] [openhab.io.gcal.auth.GCalGoogleOAuth] - ################################################################################################
2018-12-22 18:36:14.440 [INFO ] [openhab.io.gcal.auth.GCalGoogleOAuth] - # Google-Integration: U S E R I N T E R A C T I O N R E Q U I R E D !!
2018-12-22 18:36:14.442 [INFO ] [openhab.io.gcal.auth.GCalGoogleOAuth] - # 1. Open URL 'https://www.google.com/device'
2018-12-22 18:36:14.444 [INFO ] [openhab.io.gcal.auth.GCalGoogleOAuth] - # 2. Type provided code XXX-XXX-XXX
2018-12-22 18:36:14.446 [INFO ] [openhab.io.gcal.auth.GCalGoogleOAuth] - # 3. Grant openHAB access to your Google calendar
2018-12-22 18:36:14.448 [INFO ] [openhab.io.gcal.auth.GCalGoogleOAuth] - # 4. openHAB will automatically detect the permiossions and complete the authentication process
2018-12-22 18:36:14.450 [INFO ] [openhab.io.gcal.auth.GCalGoogleOAuth] - # NOTE: You will only have 1800 mins before openHAB gives up waiting for the access!!!
2018-12-22 18:36:14.452 [INFO ] [openhab.io.gcal.auth.GCalGoogleOAuth] - ################################################################################################
Ok, but when I access the URL and start adding the code, it seems that it is expecting a XXXX—XXXX formated code. Fewer characters than what I was given by the add-on (which is version 1.13.0.M5)
Is the add-on broken? What am I doing wrong?
