I installed today a fresh image of Raspbian Strech to test OpenHAB2 (2.3.0-1) on a RaspberryPI 2.
I am trying to control some GPIO port so I installed the GPIO Binding (binding-gpio1 - 1.12.0).
User openhab has been added to the gpio group; I checked the openhab user can put the GPIO port off and on using the command:
sudo -u openhab gpio write 23 0 or sudo -u openhab gpio write 23 1
I created the following item in home.items:
Switch Relay1 “Relay1” { gpio=“pin:23 activelow:yes initialValue:high” }
and the following sitemap in home.sitemap;
sitemap home label=“Test GPIO”
Switch item=Relay1
From BasicUI, I can see my Relay1 switch but it does not trigger anything on the GPIO.
In the log, I don’t have any error, I see this related to the GPIO:
In openhab.log:
[DEBUG] [org.openhab.io.gpio ] - BundleEvent STARTING - org.openhab.io.gpio
[DEBUG] [org.openhab.io.gpio ] - ServiceEvent REGISTERED - {org.openhab.io.gpio.GPIO}={service.id=313, service.bun$
[DEBUG] [org.openhab.io.gpio ] - ServiceEvent REGISTERED - {org.osgi.service.cm.ManagedService}={service.pid=org.o$
[DEBUG] [org.openhab.io.gpio ] - BundleEvent STARTED - org.openhab.io.gpio
and in events.log:
[vent.ItemStateChangedEvent] - Relay1 changed from NULL to OFF
[ome.event.ItemCommandEvent] - Item ‘Relay1’ received command ON
[vent.ItemStateChangedEvent] - Relay1 changed from OFF to ON
Does someone knows what’s wrong ?
Thank you
Fabian
