im trying to get a rule to work, but switching the gpstracker region switch does only update the switch status itself but not the switches and strings i created to detect if anybody ist home.
rule "Home"
Item GPSTrackerLars_RegionTrigger received command or
Item GPSTrackerWalli_RegionTrigger received command
if (GPSTrackerLars_homeLars == OFF && GPSTrackerWalli_homeWalli == OFF)
homeState_Home.sendCommand(OFF)
else if (GPSTrackerLars_homeLars == ON || GPSTrackerWalli_homeWalli == ON)
homeState_Home.sendCommand(ON)
rule "Home Lars"
Item GPSTrackerLars_homeLars received command
if (GPSTrackerLars_homeLars == OFF)
homeState_Lars.postUpdate("Unterwegs")
else if (GPSTrackerLars_homeLars == ON)
homeState_Lars.postUpdate("Zuhause")
rule "Home Walli"
Item GPSTrackerWalli_homeWalli received command
if (GPSTrackerWalli_homeWalli == OFF)
homeState_Walli.postUpdate("Unterwegs")
else if (GPSTrackerWalli_homeWalli == ON)
homeState_Walli.postUpdate("Zuhause")
Thank you for the hint. It works, but not reliable.
The both switches for GPSTracker_NAME do update itself, but the corresponding homeState_NAME text only every 2nd or 3rd time I switch the state. So sometimes it is updated to “away” when the switch is on for “home” (the corresponding rule is not fired evertime or wrong)
The first rule still doesnt work at all, the switch doesnt turn on or off.
rule "Home"
Item GPSTrackerLars_RegionTrigger changed or
Item GPSTrackerWalli_RegionTrigger changed
if (GPSTrackerLars_homeLars.state == OFF && GPSTrackerWalli_homeWalli.state == OFF) {
homeState_Home.postUpdate(OFF)
} else if (GPSTrackerLars_homeLars == ON || GPSTrackerWalli_homeWalli == ON) {
homeState_Home.postUpdate(ON)
And the second one:
rule "Home Lars"
Item GPSTrackerLars_homeLars changed
if (GPSTrackerLars_homeLars.state == OFF) {
} else if (GPSTrackerLars_homeLars.state == ON) {
You should be able to figure out the third one by yourself
else if (GPSTrackerLars_homeLars.state == ON ||
GPSTrackerWalli_homeWalli.state == ON)
Another question: What is the difference between postUpdate and sendCommand? Especially related to a switch.
rule "Home"
Item GPSTrackerLars_homeLars changed or
Item GPSTrackerWalli_homeWalli changed
I assume that homeState_Home is a virtual item. meaning that there is no binding attached to it.
To change the state of that switch a postUpdate is enough. The code is clearer.
the sendCommand is useful with items with a binding. the command will be sent through the binding. The item will not necessarily update it’s state straight away and wait until the binding replies with the new state. (There are ways around this behaviour, look for autoupdate)
