- Platform information:
- Hardware: CPUArchitecture/RAM/storage RPI3
- OS: what OS is used and which version Openhabian 1.4
- openHAB version:2.2
This is my newbie question:
I’ve installed a raspbianpi 1.4 into the RPi 3 without problem. Then I’ve setup InfluxDB (1.4.2) and Grafana (4.6.3). OH2.2 pumps the sensor data into the influxdb and i can see the series in the data base. But plotting this data with grafana has not been possible since a certain moment, without changing the configuration.
For example: Accu_temp_top sensor data can be displayed without problems until 2/21 19:12, as shown in the following figure, but no value is displayed from that moment. But if the database is consulted (with the same command that grafana uses), all the data appears.
I don’t know where else I can look. Any help will be welcome!
Regards
