[SOLVED] Graph Widget displays no data
i’m using openhab2 with mariadb and persistent config. everything works fine till yet.
Now i tried to add a graph widget with follow settings:
Type: Default
oH Item: # Livingroom_Temperature
Period: h
all Informations of Livingroom_Temperature stored in mysql db in table item0021. But Graph Widget didn’t generate a temp-line. I already checked the items-table to verify the tablename and itemname
I can’t find any errors on var/log/openhab2
Whats wrong?
I have some Updates:
i use the jdbc persistent mode in habpabnel and using n3-line-chart mode to show values. it works but i can’t showing legend on y-bar.
do i need to change persistent mode to mysql instead?
i solved this issue with leaving y-bar informations empty.
