I created a group-item to change two bulbs in the same lamp simultaniously…
I’m getting this log entry over and over without any change to the related items
[INFO ] [hab.event.GroupItemStateChangedEvent] - Item 'gStandsBulbsColor' changed from 0,0,100 to ON through LightStands1Color
I think OH tries to change hsb or rgb values to item states, color-items can have a hsb/rgb value and an ON/OFF state as far as I know.
Does anyone know how to avoid this behavior?
Here are the Item definitions:
bulbs
Color LightEntrance1Color "HSB Color" <none> (LightEntranceColor) { channel="mqtt:topic:MosquittoMqttBroker:RGB-Bulb-01:hsbcolor" }
Color LightEntrance2Color "HSB Color" <none> (LightEntranceColor) { channel="mqtt:topic:MosquittoMqttBroker:RGB-Bulb-02:hsbcolor" }
Makes sense. To process this AND function, the aggregator must examine the update from a (Color type) member, then convert it to ON/OFF type. Then pass the result to the Group state, but convert it back to HSV.
