I have started using HABPanel, and use the PC to modify a panel I’d like to test on the tablet in kiosk mode. However, the panel does neither reload, nor does it update when hitting the refresh button.
Is there a setting I am missing?
Or can only a finished panel be used in kiosk mode?
Or do I need to reboot the tablet every time I change something?
Any workaround (if required)?
There isn’t any change in functionality when in kiosk mode except that the title bar and sidebar disappear. You need to switch to the same panel configuration as on your PC on the tablet (outside kiosk mode) and then refreshing the page with the standard browser controls should pick up changes saved from elsewhere.
