I observed the following:
Starting Habpanel on a new Android device (using the server based configuration as on my other devices).
Although the device has the correct local Time zone set, HABPanel does still show an incorrect time (I think UTC). All other devices do show the correct time in Hablar.
This problem was solved by restarting the device.
I observed the same too. Luckily thanks to this post, I rebooted my Android 6.0 device and now the time of my Habpanel works as it should. Thank you
