Tobi77
(Tobias)
November 18, 2018, 8:25pm
#1
I am currently setting up my sitemap. I would like to assign own panels (like windows) per room in Basic UI that open from the main windows. These room panels should be organized using frames. Is this possible, or does only the main window allow for frames?
If this is feasible, an example would be greatly appreciated… Thanks!
yves
(YvesHanoulle)
November 18, 2018, 9:03pm
#2
I do have multiple frames inside a group for at least one room.
Most rooms only have one frame in my case.
so yes it’s possible. I do have a complained (Linkable widget should contain either only frames or none at all) about my sitemap, yet it works.
vzorglub
(Vincent Regaud)
November 18, 2018, 9:04pm
#3
No you can create frame in sub panels:
sitemap default label="Home"
Frame label="Home" {
Selection item=House_Mode mappings=["NORMAL"="NORMAL", "AWAY"="AWAY", "PARTY"="PARTY", "HOLIDAY"="HOLIDAY"]
Text item=GroundFloor {
Text item=LivingRoom {
Frame {
Switch item=LivingRoom_MediaPower
Slider item=TVLights
Text label="TV Lights" icon="switch" {
Slider item=LivingRoom_TVLightLeft_Level
Colorpicker item=LivingRoom_TVLightLeft_Colour
//Switch item=TVLightRight
Frame {
Switch item=LivingRoom_CeilingLight
Switch item=LivingRoom_WallLights
Switch item=LivingRoom_CabinetLight
Frame {
Switch item=LivingRoom_AquariumPump
Switch item=LivingRoom_WallSwitch
Frame {
Text label="Doors" icon="door" {
Text item=LivingRoom_Door {
Text item=LivingRoom_Door_Battery {
Chart item=LivingRoom_Door_Battery period=Y refresh=60000
Text item=Kitchen_Door {
Text item=Kitchen_Door_Battery {
Chart item=Kitchen_Door_Battery period=Y refresh=60000
Text label="Windows" icon="contact" {
Text item=LivingRoom_WindowLeft {
Text item=LivingRoom_WindowLeft_Battery {
Chart item=LivingRoom_WindowLeft_Battery period=Y refresh=60000
Text item=LivingRoom_WindowRight {
Text item=LivingRoom_WindowRight_Battery {
Chart item=LivingRoom_WindowRight_Battery period=Y refresh=60000
Text item=LivingRoom_WindowTopLeft {
Text item=LivingRoom_WindowTopLeft_Battery {
Chart item=LivingRoom_WindowTopLeft_Battery period=Y refresh=60000
Text item=LivingRoom_WindowTopRight {
Text item=LivingRoom_WindowTopRight_Battery {
Chart item=LivingRoom_WindowTopRight_Battery period=Y refresh=60000
Frame {
Video url="http://openhabguest:Spirou%4001@192.168.0.30:8666/videostream.cgi" encoding="mjpeg"
Text item=Kitchen {
Frame {
Switch item=Kitchen_CeilingLight
Switch item=Kitchen_WallLights
Switch item=Kitchen_CabinetLights
Frame {
Text item=Conservatory_Door valuecolor=[CLOSED="green", OPEN="red"] labelcolor=[CLOSED="green", OPEN="red"] {
Text item=Conservatory_Door_LastOpen
Text item=Conservatory_Door_LastClosed
Text item=Conservatory_Door_Battery {
Chart item=Conservatory_Door_Battery period=Y refresh=60000
Text item=Pantry_Door {
Text item=Pantry_Door_Battery {
Chart item=Pantry_Door_Battery period=Y refresh=60000
Text item=Kitchen_WindowLeft {
Text item=Kitchen_WindowLeft_Battery {
Chart item=Kitchen_WindowLeft_Battery period=Y refresh=60000
Text item=Kitchen_WindowTop {
Text item=Kitchen_WindowTop_Battery {
Chart item=Kitchen_WindowTop_Battery period=Y refresh=60000
Text item=Pantry {
Frame {
Switch item=Pantry_Light
Frame {
Text item=Conservatory {
Frame {
Text item=Fridge_Door
Text item=Fridge_Temperature
Text item=Freezer_Door
Text item=Freezer_Temperature
Frame {
Text item=Conservatory_GardenDoor valuecolor=[CLOSED="green", OPEN="red"] labelcolor=[CLOSED="green", OPEN="red"] {
Text item=Conservatory_GardenDoor_LastOpen
Text item=Conservatory_GardenDoor_LastClosed
Text item=Conservatory_GardenDoor_Battery {
Chart item=Conservatory_GardenDoor_Battery period=Y refresh=60000
Text item=Conservatory_Window1 {
Text item=Conservatory_Window1_Battery {
Chart item=Conservatory_Window1_Battery period=Y refresh=60000
Text item=Conservatory_Window2 {
Text item=Conservatory_Window2_Battery {
Chart item=Conservatory_Window2_Battery period=Y refresh=60000
Text item=Conservatory_Window3 {
Text item=Conservatory_Window3_Battery {
Chart item=Conservatory_Window3_Battery period=Y refresh=60000
Text item=Hallway {
Frame {
Switch item=Hallway_CeilingLight
Frame {
Text item=Hallway_Door valuecolor=[CLOSED="green", OPEN="red"] labelcolor=[CLOSED="green", OPEN="red"] {
Text item=Hallway_Door_LastOpen
Text item=Hallway_Door_LastClosed
Text item=Hallway_Door_Battery {
Chart item=Hallway_Door_Battery period=Y refresh=60000
Text item=House_FrontDoor valuecolor=[CLOSED="green", OPEN="red"] labelcolor=[CLOSED="green", OPEN="red"] {
Text item=House_FrontDoor_LastOpen
Text item=House_FrontDoor_LastClosed
Text item=House_FrontDoor_Battery {
Chart item=House_FrontDoor_Battery period=Y refresh=60000
Text item=Hallway_Window {
Text item=Hallway_Window_Battery {
Chart item=Hallway_Window_Battery period=Y refresh=60000
Text item=FirstFloor {
Text item=MasterBedroom {
Frame {
Switch item=MasterBedroom_CeilingLight
Frame {
//Selection item=MasterBedroom_HotBlanket mappings=[0=OFF,1=LOW,2=MEDIUM,3=HIGH]
Switch item=MasterBedroom_HotBlanket
Frame {
Text item=MasterBedroom_ThermostatAmbientTemp {
Chart item=MasterBedroom_ThermostatAmbientTemp period=D refresh=15000
Chart item=MasterBedroom_ThermostatAmbientTemp period=W refresh=15000
Chart item=MasterBedroom_ThermostatAmbientTemp period=M refresh=15000
Chart item=MasterBedroom_ThermostatAmbientTemp period=Y refresh=15000
Text item=MasterBedroom_ThermostatHumidity
Text item=MasterBedroom_RadiatorValve
Setpoint item=MasterBedroom_ThermostatTarget minValue=5 maxValue=30 step=1
Frame {
Text item=MasterBedroom_WindowTop {
Text item=MasterBedroom_WindowTop_Battery {
Chart item=MasterBedroom_WindowTop_Battery period=Y refresh=60000
Text item=MasterBedroom_WindowBottom {
Text item=MasterBedroom_WindowBottom_Battery {
Chart item=MasterBedroom_WindowBottom_Battery period=Y refresh=60000
Text item=MasterBedroom_Door {
Text item=MasterBedroom_Door_Battery {
Chart item=MasterBedroom_Door_Battery period=Y refresh=60000
Frame {
Text item=MasterBedroom_ThermostatBattery {
Chart item=MasterBedroom_ThermostatBattery period=Y refresh=60000
Text item=LargeBedroom {
Frame {
Switch item=LargeBedroom_CeilingLight
Switch item=LargeBedroom_DresserLight
Frame {
Selection item=LargeBedroom_HotBlanket mappings=[0=OFF,1=LOW,2=MEDIUM,3=HIGH,4=MAX]
Frame {
Text item=LargeBedroom_ThermostatAmbientTemp {
Chart item=LargeBedroom_ThermostatAmbientTemp period=D refresh=15000
Chart item=LargeBedroom_ThermostatAmbientTemp period=W refresh=15000
Chart item=LargeBedroom_ThermostatAmbientTemp period=M refresh=15000
Chart item=LargeBedroom_ThermostatAmbientTemp period=Y refresh=15000
Text item=LargeBedroom_ThermostatHumidity
Text item=LargeBedroom_RadiatorValve
Setpoint item=LargeBedroom_ThermostatTarget minValue=5 maxValue=30 step=1
Frame {
Text item=LargeBedroom_WindowLeft {
Text item=LargeBedroom_WindowLeft_Battery {
Chart item=LargeBedroom_WindowLeft_Battery period=Y refresh=60000
Text item=LargeBedroom_WindowRight {
Text item=LargeBedroom_WindowRight_Battery {
Chart item=LargeBedroom_WindowRight_Battery period=Y refresh=60000
Text item=LargeBedroom_Door {
Text item=LargeBedroom_Door_Battery {
Chart item=LargeBedroom_Door_Battery period=Y refresh=60000
Frame {
Text item=LargeBedroom_ThermostatBattery {
Chart item=LargeBedroom_ThermostatBattery period=Y refresh=60000
Text item=SmallBedroom {
Frame {
Switch item=SmallBedroom_CeilingLight
Frame {
Text item=SmallBedroom_ThermostatAmbientTemp {
Chart item=SmallBedroom_ThermostatAmbientTemp period=D refresh=15000
Chart item=SmallBedroom_ThermostatAmbientTemp period=W refresh=15000
Chart item=SmallBedroom_ThermostatAmbientTemp period=M refresh=15000
Chart item=SmallBedroom_ThermostatAmbientTemp period=Y refresh=15000
Text item=SmallBedroom_ThermostatHumidity label="Humidity [%.1f %%]"
Text item=SmallBedroom_ThermostatHumidity label="Humidity x 100 [%.1f]"
Text item=SmallBedroom_RadiatorValve
Setpoint item=SmallBedroom_ThermostatTarget minValue=5 maxValue=30 step=1
Frame {
Text item=SmallBedroom_Window {
Text item=SmallBedroom_Window_Battery {
Chart item=SmallBedroom_Window_Battery period=Y refresh=60000
Text item=SmallBedroom_Door {
Text item=SmallBedroom_Door_Battery {
Chart item=SmallBedroom_Door_Battery period=Y refresh=60000
Frame {
Text item=SmallBedroom_ThermostatBattery {
Chart item=SmallBedroom_ThermostatBattery period=Y refresh=60000
Text item=Landing {
Frame {
Switch item=Landing_CeilingLight
Text item=Bathroom {
Frame {
Switch item=Bathroom_Light
Frame {
Text item=Bathroom_ThermostatAmbientTemp {
Chart item=Bathroom_ThermostatAmbientTemp period=D refresh=15000
Chart item=Bathroom_ThermostatAmbientTemp period=W refresh=15000
Chart item=Bathroom_ThermostatAmbientTemp period=M refresh=15000
Chart item=Bathroom_ThermostatAmbientTemp period=Y refresh=15000
Text item=Bathroom_ThermostatHumidity
Text item=Bathroom_RadiatorValve
Setpoint item=Bathroom_ThermostatTarget minValue=5 maxValue=30 step=1
Frame {
Text item=Bathroom_Window {
Text item=Bathroom_Window_Battery {
Chart item=Bathroom_Window_Battery period=Y refresh=60000
Text item=Bathroom_Door {
Text item=Bathroom_Door_Battery {
Chart item=Bathroom_Door_Battery period=Y refresh=60000
Frame {
Text item=Bathroom_ThermostatBattery {
Chart item=Bathroom_ThermostatBattery period=Y refresh=60000
Text item=Toilet {
Frame {
Switch item=Toilet_Light
Frame {
Text item=Toilet_Window {
Text item=Toilet_Window_Battery {
Chart item=Toilet_Window_Battery period=Y refresh=60000
Text item=Toilet_Door {
Text item=Toilet_Door_Battery {
Chart item=Toilet_Door_Battery period=Y refresh=60000
Frame label="Heating" {
Text item=Heating_Mode
Text label="Nest" icon="nest" {
Text item=House_NestHVACMode
Text item=House_NestAmbientTemperature
Text item=House_NestHumidity
Text item=House_NestHeatingONOFF
Setpoint item=House_NestTargetTemperature minValue=5 maxValue=30 step=0.5
Text item=LivingRoom_RadiatorValve
Frame {
Frame {
Frame {
Chart item=MasterBedroom_Thermostat_Battery period=Y refresh=60000
Frame {
Frame {
Frame {
Frame {
Frame {
Frame {
Frame {
Frame {
Frame {
Text item=Toilet {
Frame {
Text item=Toilet_ThermostatAmbientTemp
//Text item=Bathroom_ThermostatHumidity
//Text item=Bathroom_RadiatorValve
//Setpoint item=Bathroom_ThermostatTarget minValue=5 maxValue=30 step=1
Frame {
//Frame {
// Text item=Bathroom_ThermostatBattery {
// Chart item=Bathroom_ThermostatBattery period=Y refresh=60000
Frame label="Weather" {
Text item=OutsideTemperature
Text item=AuriolTemp
Text item=OutsideHumidity
Text item=WindSpeedMph label="Windspeed m/s [%.1f m/s]"
Text item=WindDirection
Text item=WindDirection2
Text item=SunElevation
//Image item=WeatherIcon
Tobi77
(Tobias)
November 18, 2018, 9:41pm
#4
Thanks, but I have issues to see the structure. Say, I need to open a new panel “Schlafzimmmer” from the main window. That window carries two lamps (one for Tobi, one for Micha) that have a frame each to group color and brightnesse per lamp.
My code:
sitemap default label="Unsere Wohnung"
Frame label="Verbraucher"
Default item=Steckdose_Haartrockner label="Fön im Badezimmer"
Default item=Steckdose_Stehlampe label="Stehlampe im Wohnzimmer"
Frame label="Räume"
Group item=BathRoom label="Badezimmer" icon="bath"
//Group item=BedRoom label="Schlafzimmmer" icon="bedroom"
Group item=LivingRoom label="Wohnzimmer" icon="sofa"
Group item=Hallway label="Flur" icon="corridor"
Text item=Schlafzimmer label="Schlafzimmer" icon="bedroom"
Frame label="Tobi"
slider item=Night_Light_Brightness_Tobias label="Helligkeit"
slider item=Night_Light_Color_Tobias label="Farbe"
Frame label="Micha"
slider item=Night_Light_Brightness_Micha label="Helligkeit"
slider item=Night_Light_Color_Micha label="Farbe"
Thanks a lot!
vzorglub
(Vincent Regaud)
November 18, 2018, 9:46pm
#5
Yes that should work
But do you have an item called Schlafzimmer
I think not so then you do:
Text label="Schlafzimmer" icon="bedroom"
Frame label="Tobi"
Tobi77
(Tobias)
November 18, 2018, 9:48pm
#6
Unfortunately not:
I get an empty page saying
"Willkommen!
##### Verfügbare Sitemaps
Sie haben noch keine Sitemaps definiert. Hilfe zur Erstellung von Sitemaps finden Sie in der Dokumentation.
vzorglub
(Vincent Regaud)
November 18, 2018, 9:50pm
#7
Where did you save the file? And what is it called?
Tobi77
(Tobias)
November 18, 2018, 9:53pm
#8
It is default.sitemap, located in the sitemap-folder.
If I remove everything in
Frame label="Tobi"
Frame label="Micha"
I get a working BasicUI. So the error must be in that part…
vzorglub
(Vincent Regaud)
November 18, 2018, 9:56pm
#9
Post your working sitemap just as mentionned
We’ll try adding things bit by bit
Tobi77
(Tobias)
November 18, 2018, 9:57pm
#10
Works:
Frame label="Räume"
/*Text label="Schlafzimmer" icon="bedroom"
Frame label="Tobi"
Frame label="Micha"
vzorglub
(Vincent Regaud)
November 18, 2018, 9:59pm
#11
Frame label="Räume"
Do you get a Schlafzimmer
element with a bedroom icon?
pahansen
(Paul Hansen)
November 18, 2018, 10:00pm
#13
I have a vauge memory that you can’t have Group items and Frames nested in the same Frame. Try having only the Tobi and Micha frames.
Tobi77
(Tobias)
November 18, 2018, 10:02pm
#14
@pahansen
This does not work:
Frame label="Räume"
//Group item=BathRoom label="Badezimmer" icon="bath"
//Group item=LivingRoom label="Wohnzimmer" icon="sofa"
//Group item=Hallway label="Flur" icon="corridor"
Frame label="Tobi"
Frame label="Micha"
vzorglub
(Vincent Regaud)
November 18, 2018, 10:03pm
#15
Frame label="Räume"
Tobi77
(Tobias)
November 18, 2018, 10:05pm
#16
@vzorglub : Thanks. I edited the file like this, but this does not work:
Frame label="Räume"
// Frame label="Tobi"
// Frame label="Micha"
Tobi77
(Tobias)
November 18, 2018, 10:08pm
#18
That did it. OMG, that took me the whole evening.
Thanks a lot!!!
vzorglub
(Vincent Regaud)
November 18, 2018, 10:09pm
#19
isoparme
(pol-henri Dupont)
October 22, 2019, 3:59pm
#20
vzorglub:
Thanks amazing tricks ! it help me to have a clean sitemap , very useful
