Hi all,
I am running Openhab on a NAS in a docker environment which is running fine. Nearly all of my items / things are MQTT based. As persistence I use a MySQL database on the same NAS.
This week I prepared the migration from 3.4.4 towards 4.0.x. As advised I added ‘unit’ (UoM) to all items, made a backup of my database and configfiles and even configured a new dockercontainer to which I copied all of the config files (to be able, in case of issues, to rollback easily).
As hoped: the migration went rather smooth. Though not all unit definitions were migrated (didn’t bother to sort out why, the amount was not that large and maybe I missed some of the items since I have nearly 700 of them). Anyway: I found that I made some definitions that weren’t that smart (defining an energy item and then correct that by the state definition since it should be power. Sometimes migrations are a good thing to fix this kind of ‘design issues’).
What’s the issue? When starting openhab, I see in the logs:
2023-08-22 14:11:44.029 [INFO ] [org.openhab.core.Activator ] - Starting openHAB 4.0.2 (build Release Build)
2023-08-22 14:11:47.668 [INFO ] [.core.internal.i18n.I18nProviderImpl] - Time zone set to 'Europe/Amsterdam'.
2023-08-22 14:11:47.742 [INFO ] [.core.internal.i18n.I18nProviderImpl] - Location set to '50.7752278403539,6.0179704427719125'.
2023-08-22 14:11:47.746 [INFO ] [.core.internal.i18n.I18nProviderImpl] - Locale set to 'nl_NL'.
2023-08-22 14:12:03.832 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'jdbc.persist'
2023-08-22 14:12:24.837 [ERROR] [s.internal.SemanticsMetadataProvider] - bundle org.openhab.core.semantics:4.0.2 (210)[org.openhab.core.semantics.internal.SemanticsMetadataProvider(238)] : The activate method has thrown an exception
java.lang.StackOverflowError: null
at java.lang.IllegalArgumentException.<init>(IllegalArgumentException.java:40) ~[?:?]
at java.util.regex.PatternSyntaxException.<init>(PatternSyntaxException.java:58) ~[?:?]
at java.util.regex.Pattern.error(Pattern.java:2028) ~[?:?]
at java.util.regex.Pattern.<init>(Pattern.java:1432) ~[?:?]
at java.util.regex.Pattern.compile(Pattern.java:1069) ~[?:?]
at java.util.regex.Pattern.matches(Pattern.java:1174) ~[?:?]
at java.lang.String.matches(String.java:2840) ~[?:?]
at org.openhab.core.common.AbstractUID.validateSegment(AbstractUID.java:100) ~[?:?]
at org.openhab.core.common.AbstractUID.<init>(AbstractUID.java:76) ~[?:?]
at org.openhab.core.common.AbstractUID.<init>(AbstractUID.java:59) ~[?:?]
at org.openhab.core.items.MetadataKey.<init>(MetadataKey.java:42) ~[?:?]
at org.openhab.core.semantics.internal.SemanticsMetadataProvider.processItem(SemanticsMetadataProvider.java:109) ~[?:?]
at org.openhab.core.semantics.internal.SemanticsMetadataProvider.processItem(SemanticsMetadataProvider.java:131) ~[?:?]
2023-08-22 14:12:24.970 [ERROR] [Events.Framework ] - FrameworkEvent ERROR
java.lang.NullPointerException: Cannot invoke "org.openhab.core.common.registry.Provider.getAll()" because "provider" is null
at org.openhab.core.common.registry.AbstractRegistry.addProvider(AbstractRegistry.java:420) ~[?:?]
at org.openhab.core.common.registry.AbstractRegistry$ProviderTracker.addingService(AbstractRegistry.java:149) ~[?:?]
at org.openhab.core.common.registry.AbstractRegistry$ProviderTracker.addingService(AbstractRegistry.java:1) ~[?:?]
at org.osgi.util.tracker.ServiceTracker$Tracked.customizerAdding(ServiceTracker.java:943) ~[osgi.core-8.0.0.jar:?]
at org.osgi.util.tracker.ServiceTracker$Tracked.customizerAdding(ServiceTracker.java:871) ~[osgi.core-8.0.0.jar:?]
at org.osgi.util.tracker.AbstractTracked.trackAdding(AbstractTracked.java:256) ~[osgi.core-8.0.0.jar:?]
at org.osgi.util.tracker.AbstractTracked.track(AbstractTracked.java:229) ~[osgi.core-8.0.0.jar:?]
at org.osgi.util.tracker.ServiceTracker$Tracked.serviceChanged(ServiceTracker.java:903) ~[osgi.core-8.0.0.jar:?]
at org.eclipse.osgi.internal.serviceregistry.FilteredServiceListener.serviceChanged(FilteredServiceListener.java:123) ~[org.eclipse.osgi-3.18.0.jar:?]
at org.eclipse.osgi.internal.framework.BundleContextImpl.dispatchEvent(BundleContextImpl.java:961) ~[org.eclipse.osgi-3.18.0.jar:?]
at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:234) ~[org.eclipse.osgi-3.18.0.jar:?]
at org.eclipse.osgi.framework.eventmgr.ListenerQueue.dispatchEventSynchronous(ListenerQueue.java:151) ~[org.eclipse.osgi-3.18.0.jar:?]
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.publishServiceEventPrivileged(ServiceRegistry.java:937) ~[org.eclipse.osgi-3.18.0.jar:?]
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.publishServiceEvent(ServiceRegistry.java:874) ~[org.eclipse.osgi-3.18.0.jar:?]
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistrationImpl.register(ServiceRegistrationImpl.java:141) ~[org.eclipse.osgi-3.18.0.jar:?]
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.registerService(ServiceRegistry.java:262) ~[org.eclipse.osgi-3.18.0.jar:?]
at org.eclipse.osgi.internal.framework.BundleContextImpl.registerService(BundleContextImpl.java:500) ~[org.eclipse.osgi-3.18.0.jar:?]
at org.apache.felix.scr.impl.manager.AbstractComponentManager$3.register(AbstractComponentManager.java:929) ~[?:?]
at org.apache.felix.scr.impl.manager.AbstractComponentManager$3.register(AbstractComponentManager.java:915) ~[?:?]
at org.apache.felix.scr.impl.manager.RegistrationManager.changeRegistration(RegistrationManager.java:133) ~[?:?]
at org.apache.felix.scr.impl.manager.AbstractComponentManager.registerService(AbstractComponentManager.java:984) ~[?:?]
at org.apache.felix.scr.impl.manager.AbstractComponentManager.activateInternal(AbstractComponentManager.java:752) ~[?:?]
at org.apache.felix.scr.impl.manager.DependencyManager$SingleStaticCustomizer.addedService(DependencyManager.java:1274) ~[?:?]
at org.apache.felix.scr.impl.manager.DependencyManager$SingleStaticCustomizer.addedService(DependencyManager.java:1225) ~[?:?]
at org.apache.felix.scr.impl.manager.ServiceTracker$Tracked.customizerAdded(ServiceTracker.java:1232) ~[?:?]
at org.apache.felix.scr.impl.manager.ServiceTracker$Tracked.customizerAdded(ServiceTracker.java:1152) ~[?:?]
at org.apache.felix.scr.impl.manager.ServiceTracker$AbstractTracked.trackAdding(ServiceTracker.java:959) ~[?:?]
at org.apache.felix.scr.impl.manager.ServiceTracker$AbstractTracked.track(ServiceTracker.java:895) ~[?:?]
at org.apache.felix.scr.impl.manager.ServiceTracker$Tracked.serviceChanged(ServiceTracker.java:1184) ~[?:?]
at org.apache.felix.scr.impl.BundleComponentActivator$ListenerInfo.serviceChanged(BundleComponentActivator.java:116) ~[?:?]
at org.apache.felix.scr.impl.manager.AbstractComponentManager.enableInternal(AbstractComponentManager.java:674) ~[?:?]
at org.apache.felix.scr.impl.manager.AbstractComponentManager.enable(AbstractComponentManager.java:437) ~[?:?]
at org.apache.felix.scr.impl.manager.ConfigurableComponentHolder.enableComponents(ConfigurableComponentHolder.java:671) ~[?:?]
at org.apache.felix.scr.impl.BundleComponentActivator.initialEnable(BundleComponentActivator.java:310) ~[?:?]
at org.apache.felix.scr.impl.Activator.loadComponents(Activator.java:593) ~[?:?]
at org.apache.felix.scr.impl.Activator.access$200(Activator.java:74) ~[?:?]
at org.apache.felix.scr.impl.Activator$ScrExtension.start(Activator.java:460) ~[?:?]
at org.apache.felix.scr.impl.AbstractExtender.createExtension(AbstractExtender.java:196) ~[?:?]
at org.apache.felix.scr.impl.AbstractExtender.modifiedBundle(AbstractExtender.java:169) ~[?:?]
at org.apache.felix.scr.impl.AbstractExtender.modifiedBundle(AbstractExtender.java:49) ~[?:?]
at org.osgi.util.tracker.BundleTracker$Tracked.customizerModified(BundleTracker.java:488) ~[osgi.core-8.0.0.jar:?]
at org.osgi.util.tracker.BundleTracker$Tracked.customizerModified(BundleTracker.java:420) ~[osgi.core-8.0.0.jar:?]
at org.osgi.util.tracker.AbstractTracked.track(AbstractTracked.java:232) ~[osgi.core-8.0.0.jar:?]
at org.osgi.util.tracker.BundleTracker$Tracked.bundleChanged(BundleTracker.java:450) ~[osgi.core-8.0.0.jar:?]
at org.eclipse.osgi.internal.framework.BundleContextImpl.dispatchEvent(BundleContextImpl.java:949) ~[org.eclipse.osgi-3.18.0.jar:?]
at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEventPrivileged(EquinoxEventPublisher.java:229) ~[org.eclipse.osgi-3.18.0.jar:?]
at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEvent(EquinoxEventPublisher.java:138) ~[org.eclipse.osgi-3.18.0.jar:?]
at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEvent(EquinoxEventPublisher.java:130) ~[org.eclipse.osgi-3.18.0.jar:?]
at org.eclipse.osgi.internal.framework.EquinoxContainerAdaptor.publishModuleEvent(EquinoxContainerAdaptor.java:217) ~[org.eclipse.osgi-3.18.0.jar:?]
at org.eclipse.osgi.container.Module.publishEvent(Module.java:499) ~[org.eclipse.osgi-3.18.0.jar:?]
at org.eclipse.osgi.container.Module.start(Module.java:486) ~[org.eclipse.osgi-3.18.0.jar:?]
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel$2.run(ModuleContainer.java:1847) ~[org.eclipse.osgi-3.18.0.jar:?]
at org.eclipse.osgi.internal.framework.EquinoxContainerAdaptor$1$1.execute(EquinoxContainerAdaptor.java:136) ~[org.eclipse.osgi-3.18.0.jar:?]
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.incStartLevel(ModuleContainer.java:1840) ~[org.eclipse.osgi-3.18.0.jar:?]
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.incStartLevel(ModuleContainer.java:1783) ~[org.eclipse.osgi-3.18.0.jar:?]
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.doContainerStartLevel(ModuleContainer.java:1745) ~[org.eclipse.osgi-3.18.0.jar:?]
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.dispatchEvent(ModuleContainer.java:1667) ~[org.eclipse.osgi-3.18.0.jar:?]
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.dispatchEvent(ModuleContainer.java:1) ~[org.eclipse.osgi-3.18.0.jar:?]
at org.eclipse.osgi.framework.eventmgr.EventManager$EventThread.run(EventManager.java:345) ~[org.eclipse.osgi-3.18.0.jar:?]
2023-08-22 14:12:25.923 [ERROR] [s.internal.SemanticsMetadataProvider] - bundle org.openhab.core.semantics:4.0.2 (210)[org.openhab.core.semantics.internal.SemanticsMetadataProvider(238)] : The activate method has thrown an exception
I have no clue what is going on. I am used to get some errors while restarting since not all bindings start quick enough, but these errors I have not seen on 3.4.4 (or before). However: I didn’t restart 3.4.4 after adding the units (UoM) and migrating to 4.0.2.
Just to mention: the ‘…’ in the logs are repeating lines I removed.
Could anyone help me how to tackle these? On the other hand: everything is working as expected and there seems to be no issue.
Thanks, best regards,
HWL
