Hello everybody,
I choose simple or standard ui at the very first time start up when openhab2 first boot on my Pi 3.
Now I want check the REST API on the UI(someone talking about these ,and I am curious with them).
But I can’t see the API anywhere, so I guess I am using the wrong UI now.
And there are topics talking about modifing the addons.cfg file, I tried ,and not work for me.
Is there any suggestion to solve this?
pi@raspberrypi:~ $ cat /etc/openhab2/services/addons.cfg
# The base installation package of this openHAB instance
# Note: This is only regarded at the VERY FIRST START of openHAB
# Optional. If not set, the dashboard (https://<yourserver>:8080/) will ask you to choose a package.
# Valid options:
# - minimal : Installation only with dashboard, but no UIs or other addons
# - simple : Setup for using openHAB purely through UIs - you need to expect MANY constraints in functionality!
# - standard : Default setup for normal users, best for textual setup
# - expert : Setup for expert users, especially for people migrating from openHAB 1.x
# - demo : A demo setup which includes UIs, a few bindings, config files etc.
# See http://docs.openhab.org/configuration/packages.html for a detailed explanation of these packages.
#package = standard
# Access Remote Add-on Repository
# Defines whether the remote openHAB add-on repository should be used for browsing and installing add-ons.
# This not only makes latest snapshots of add-ons available, it is also required for the installation of
# any legacy 1.x add-on. (default is true)
#remote = true
# Include legacy 1.x bindings. If set to true, it also allows the installation of 1.x bindings for which there is
# already a 2.x version available (requires remote repo access, see above). (default is false)
#legacy = true
# A comma-separated list of bindings to install (e.g. "sonos,knx,zwave")
#binding =
# A comma-separated list of UIs to install (e.g. "basic,paper")
#ui =
# A comma-separated list of persistence services to install (e.g. "rrd4j,jpa")
#persistence =
# A comma-separated list of actions to install (e.g. "mail,pushover")
#action =
# A comma-separated list of transformation services to install (e.g. "map,jsonpath")
#transformation =
# A comma-separated list of voice services to install (e.g. "marytts,freetts")
#voice =
# A comma-separated list of miscellaneous services to install (e.g. "myopenhab")
#misc =
I have the minimal package and can see the REST Api.
Try changing your addons.cfg from
#package = standard
to
package = expert (don’t forget to uncomment the line: remove the # in front of that line)
If that does not help: try installing the RestDocs through Misc Tab (although I don’t think that has something to do with the API … but one never knows …)
I´m a very new member and I know that the topic is old.
Got my RasPi yesterday and installed openhabian succesfully. I also got some bindingd working!
My /etc/openhab2/services/addons.cfg is the same as above.
Now I also wanted to change my addons.cfg from minimal. I´ve read the documentation, but I don´t know how and where.
Which command do I have to use or how can I open an “explorer”?
THX
I want to - that‘s right
But I don‘T know how and in the linked Thread is no explanation doesn´t help me.
I really need it step-by-step:
Where and how do I find and change the addons.cfg ?
@Miroo
To be honest, the comments above are relatively precise instructions on how to proceed with your problem:
1. Clean install [You should use this]
Stop OH (sudo service openhab2 stop) via Putty
Delete the contents of the userdata folder (\\openhabianpi\openHAB-share\openhab2-userdata) and your conf folder (\\openhabianpi\openHAB-share\openhab2-conf)
Start OH (sudo service openhab2 start)
2. Change package in addons.cfg [for more experienced users]
In the assumption that you are on windows:
Connect to openhabian-share via samba \\openhabianpi\openHAB-conf\services\
Open theaddons.cfg with your favourite text editor
Change the line #package = standard to package = expert
Is there a specific reason why you want to change that? As mentioned in the linked article from hr3, there are some “downsides” for not experienced users with the second solution.
This turned out to be a mistake for me. Note the $OPENHAB_USERDATA variable points to /var/lib/openhab or something important and removing it entirely destroyed my setup.
Reinstall OS now to clear it all up and start again!
