Dear all,
I am trying to set up a logging which would help me with some network problems I might have in my configuration.
I have adited org.ops4j.pax.logging.cfg as follows:
Custom Loggers
io.net.http
log4j2.logger.io.net.http.name = org.openhab.io.net.http
log4j2.logger.io.net.http.level = TRACE
log4j2.logger.io.net.http.additivity = false
log4j2.logger.io.net.http.appenderRefs = io.net.http
log4j2.logger.io.net.http.appenderRef.io.net.http.ref = io.net.http
Custom Appenders
io.net.http
log4j2.appender.io.net.http.name = io.net.http
log4j2.appender.io.net.http.type = RollingRandomAccessFile
log4j2.appender.io.net.http.fileName = /var/log/openhab2/io.net.http.log
log4j2.appender.io.net.http.filePattern = /var/log/openhab2/io.net.http.log.%i
log4j2.appender.io.net.http.immediateFlush = true
log4j2.appender.io.net.http.append = true
log4j2.appender.io.net.http.layout.type = PatternLayout
log4j2.appender.io.net.http.layout.pattern = %d{dd-MMM-yyyy HH:mm:ss.SSS} [%-5.5p] [%-50.50c] - %m%n
log4j2.appender.io.net.http.policies.type = Policies
log4j2.appender.io.net.http.policies.size.type = SizeBasedTriggeringPolicy
log4j2.appender.io.net.http.policies.size.size = 10MB
log4j2.appender.io.net.http.strategy.type = DefaultRolloverStrategy
log4j2.appender.io.net.http.strategy.max = 10
If I activate this logging config, the OH2 logging stops completely.
I tried to find some hints using the logging tag, but did without success.
Would you have any hints?
Thanks and regards,
Lars
