[Solved] Help using NetworkAddressService
I don’t now if that’s the right category to get some help to integrate the NetworkAddressService to get the primary IP.
Preparation in the Code:
import org.eclipse.smarthome.core.net.NetworkAddressService;
Class:
private NetworkAddressService networkAddressService;
Code inside the ThingFactoryClass class (tried also others):
@Reference
protected void setNetworkAddressService(NetworkAddressService networkAddressService) {
     this.networkAddressService = networkAddressService;
protected void unsetNetworkAddressService(NetworkAddressService networkAddressService) {
     this.networkAddressService = null;
Usage:
networkAddressService.getPrimaryIpv4HostAddress()
Sounds easy, but the problem is that the setNetworkAddressService() is never called. The binding gets loaded, but I reach never the breakpoint I set on the routine.
I checked OSGI-INF/ThingFactory.xml
<?xml version="1.0" encoding="UTF-8"?>
<scr:component xmlns:scr="http://www.osgi.org/xmlns/scr/v1.2.0" activate="activate" configuration-pid="telekomtv" immediate="true" name="org.openhab.binding.telekomtv.internal.TelekomTVHandlerFactory">
   <service servicefactory="false">
      <provide interface="org.eclipse.smarthome.core.thing.binding.ThingHandlerFactory"/>
      <provide interface="org.openhab.binding.telekomtv.internal.TelekomTVHandlerFactory"/>
   </service>
   <reference bind="setNetworkAddressService" interface="org.eclipse.smarthome.core.net.NetworkAddressService" name="NetworkAddressService" unbind="unsetNetworkAddressService"/>
   <implementation class="org.openhab.binding.telekomtv.internal.TelekomTVHandlerFactory"/>
</scr:component>
so the @Reference works. Otherwise Eclipse told me that this is not a public interface.
Is it correct that I need to add a rule to the Java Build Path to get access to
I checked out ESH API Reference->NetworkAddressService documentation, but it does not contain no information how integrate the class. Need some help.
Most of the developers can be found @ Git content has moved. so you may have more chances if you open up the same question at the ESH forum also.
Of course, some are also in this forum :slight_smile:
Hi, thanks for the advise. Created a post there.
posted here: Git content has moved.
and already got the fix
