I have a trouble defining a when statement in rule for the switch item light. I have a button named tipka and when the button is pressed:
If the light is on when the button is pressed the light must be turned off.
and if the light is off when the button is pressed the light must be turned on.
Here is the rule:
rule "light"
item tipka changed from OPEN to CLOSED
if (luc.state != ON) {
luc.sendCommand(ON)
logInfo("ON")}
if (luc.state == ON) {
luc.sendCommand(OFF)
logInfo("OFF")}
and here is the error in the log:
'home.rules' has errors, therefore ignoring it: [27,2]: no viable alternative at input 'item'
