Change the hysteresis to a Number val
As your variable and hysteresis are now all numbers you won’t need the floatValue
anymore
rule "Elutoa temperatuur"
Item ElutoaSetpoint changed or
Item ElutoaTemp changed
var Number cur_temp = ElutoaTemp.state as Number
var Number setpoint = ElutoaSetpoint.state as Number
val Number hysteresis = 0.5
if (cur_temp < (setpoint - hysteresis)) {
if (ElutoaRadikas.state != ON) {ElutoaRadikas.sendCommand(ON)}
else if(cur_temp > setpoint + hysteresis) {
if (ElutoaRadikas.state != OFF) {ElutoaRadikas.sendCommand(OFF)}
