I´ve got this very highly and strange error when I enter a specific sitemap. And I really cant seem to find the cause of this:
This is the error I get:
2019-04-20 14:14:50.861 [WARN ] [basic.internal.render.SwitchRenderer] - Cannot determine item type of 'stue_sov_NV'
org.eclipse.smarthome.core.items.ItemNotFoundException: Item 'stue_sov_NV' could not be found in the item registry
at org.eclipse.smarthome.core.internal.items.ItemRegistryImpl.getItem(ItemRegistryImpl.java:81) ~[?:?]
at org.eclipse.smarthome.ui.internal.items.ItemUIRegistryImpl.getItem(ItemUIRegistryImpl.java:802) ~[?:?]
at org.openhab.ui.basic.internal.render.SwitchRenderer.renderWidget(SwitchRenderer.java:84) [273:org.openhab.ui.basic:2.5.0.201903170912]
at org.openhab.ui.basic.internal.render.PageRenderer.renderWidget(PageRenderer.java:194) [273:org.openhab.ui.basic:2.5.0.201903170912]
at org.openhab.ui.basic.internal.render.PageRenderer.processChildren(PageRenderer.java:160) [273:org.openhab.ui.basic:2.5.0.201903170912]
at org.openhab.ui.basic.internal.render.PageRenderer.processPage(PageRenderer.java:124) [273:org.openhab.ui.basic:2.5.0.201903170912]
at org.openhab.ui.basic.internal.servlet.WebAppServlet.service(WebAppServlet.java:209) [273:org.openhab.ui.basic:2.5.0.201903170912]
at javax.servlet.http.HttpServlet.service(HttpServlet.java:790) [31:javax.servlet-api:3.1.0]
at org.eclipse.jetty.servlet.ServletHolder.handle(ServletHolder.java:865) [91:org.eclipse.jetty.servlet:9.4.12.v20180830]
at org.eclipse.jetty.servlet.ServletHandler.doHandle(ServletHandler.java:535) [91:org.eclipse.jetty.servlet:9.4.12.v20180830]
at org.ops4j.pax.web.service.jetty.internal.HttpServiceServletHandler.doHandle(HttpServiceServletHandler.java:71) [194:org.ops4j.pax.web.pax-web-jetty:7.2.5]
at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:146) [90:org.eclipse.jetty.server:9.4.12.v20180830]
at org.eclipse.jetty.security.SecurityHandler.handle(SecurityHandler.java:548) [88:org.eclipse.jetty.security:9.4.12.v20180830]
at org.eclipse.jetty.server.handler.HandlerWrapper.handle(HandlerWrapper.java:132) [90:org.eclipse.jetty.server:9.4.12.v20180830]
at org.eclipse.jetty.server.handler.ScopedHandler.nextHandle(ScopedHandler.java:257) [90:org.eclipse.jetty.server:9.4.12.v20180830]
at org.eclipse.jetty.server.session.SessionHandler.doHandle(SessionHandler.java:1595) [90:org.eclipse.jetty.server:9.4.12.v20180830]
at org.eclipse.jetty.server.handler.ScopedHandler.nextHandle(ScopedHandler.java:255) [90:org.eclipse.jetty.server:9.4.12.v20180830]
at org.eclipse.jetty.server.handler.ContextHandler.doHandle(ContextHandler.java:1340) [90:org.eclipse.jetty.server:9.4.12.v20180830]
at org.ops4j.pax.web.service.jetty.internal.HttpServiceContext.doHandle(HttpServiceContext.java:293) [194:org.ops4j.pax.web.pax-web-jetty:7.2.5]
at org.eclipse.jetty.server.handler.ScopedHandler.nextScope(ScopedHandler.java:203) [90:org.eclipse.jetty.server:9.4.12.v20180830]
at org.eclipse.jetty.servlet.ServletHandler.doScope(ServletHandler.java:473) [91:org.eclipse.jetty.servlet:9.4.12.v20180830]
at org.eclipse.jetty.server.session.SessionHandler.doScope(SessionHandler.java:1564) [90:org.eclipse.jetty.server:9.4.12.v20180830]
at org.eclipse.jetty.server.handler.ScopedHandler.nextScope(ScopedHandler.java:201) [90:org.eclipse.jetty.server:9.4.12.v20180830]
at org.eclipse.jetty.server.handler.ContextHandler.doScope(ContextHandler.java:1242) [90:org.eclipse.jetty.server:9.4.12.v20180830]
at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:144) [90:org.eclipse.jetty.server:9.4.12.v20180830]
at org.ops4j.pax.web.service.jetty.internal.JettyServerHandlerCollection.handle(JettyServerHandlerCollection.java:80) [194:org.ops4j.pax.web.pax-web-jetty:7.2.5]
at org.eclipse.jetty.server.Server.handle(Server.java:503) [90:org.eclipse.jetty.server:9.4.12.v20180830]
at org.eclipse.jetty.server.HttpChannel.handle(HttpChannel.java:364) [90:org.eclipse.jetty.server:9.4.12.v20180830]
at org.eclipse.jetty.server.HttpConnection.onFillable(HttpConnection.java:260) [90:org.eclipse.jetty.server:9.4.12.v20180830]
at org.eclipse.jetty.io.AbstractConnection$ReadCallback.succeeded(AbstractConnection.java:305) [81:org.eclipse.jetty.io:9.4.12.v20180830]
at org.eclipse.jetty.io.FillInterest.fillable(FillInterest.java:103) [81:org.eclipse.jetty.io:9.4.12.v20180830]
at org.eclipse.jetty.io.ChannelEndPoint$2.run(ChannelEndPoint.java:118) [81:org.eclipse.jetty.io:9.4.12.v20180830]
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.runTask(EatWhatYouKill.java:333) [93:org.eclipse.jetty.util:9.4.12.v20180830]
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.doProduce(EatWhatYouKill.java:310) [93:org.eclipse.jetty.util:9.4.12.v20180830]
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.tryProduce(EatWhatYouKill.java:168) [93:org.eclipse.jetty.util:9.4.12.v20180830]
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.run(EatWhatYouKill.java:126) [93:org.eclipse.jetty.util:9.4.12.v20180830]
at org.eclipse.jetty.util.thread.ReservedThreadExecutor$ReservedThread.run(ReservedThreadExecutor.java:366) [93:org.eclipse.jetty.util:9.4.12.v20180830]
at org.eclipse.jetty.util.thread.QueuedThreadPool.runJob(QueuedThreadPool.java:765) [93:org.eclipse.jetty.util:9.4.12.v20180830]
at org.eclipse.jetty.util.thread.QueuedThreadPool$2.run(QueuedThreadPool.java:683) [93:org.eclipse.jetty.util:9.4.12.v20180830]
2019-04-20 14:14:50.877 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item 'stue_sov_NV' for widget org.eclipse.smarthome.model.sitemap.Switch
2019-04-20 14:14:50.879 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item for widget org.eclipse.smarthome.model.sitemap.Switch
2019-04-20 14:14:50.883 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item 'stue_sov_NV' for widget org.eclipse.smarthome.model.sitemap.Switch
2019-04-20 14:14:50.885 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item 'stue_sov_NV' for widget org.eclipse.smarthome.model.sitemap.Switch
2019-04-20 14:14:50.887 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item 'stue_sov_NV' for widget org.eclipse.smarthome.model.sitemap.Switch
The very strange thing is… The item stue_sov_NV is NOT a part of the sitemap.
This is the sitemap which trigger the error:
sitemap stuen label="Stuen"
Frame label="Lys" {
Switch item=stue_sov_OEV
Switch item=stue_sov_OEH
Text item=HueStue icon="light"{
Switch item=gHueStue
Text item=none
Slider item=HueStue label="Fælles Dimmer [%s]"
Colorpicker item=HueStue label="Fælles farve valg [%s]"
Switch item=Huebloom_HB label="Bloom højre bag [%s]"
Switch item=Huebloom_HF label="Bloom højre front [%s]"
Switch item=Huebloom_VF label="Bloom venstre front [%s]"
Switch item=Huependel_col label="Pendel [%s]"
Slider item=Huebloom_HB label="Bloom højre bag [%s]"
Slider item=Huebloom_HF label="Bloom højre front [%s]"
Slider item=Huebloom_VF label="Bloom venstre front [%s]"
Slider item=Huependel_col label="Pendel [%s]"
Colorpicker item=Huebloom_HB label="Bloom højre bag" icon="colorwheel"
Colorpicker item=Huebloom_HF label="Bloom højre front" icon="colorwheel"
Colorpicker item=Huebloom_VF label="Bloom venstre front" icon="colorwheel"
Colorpicker item=Huependel_col label="Hjørnelampe" icon="colorwheel"
Default item=Huependel_dim
Text item=none
Text item=Huebloom_HBAlert
Text item=Huebloom_HFAlert
Text item=Huebloom_VFAlert
Text item=Huependel_Alert
Frame label="Varme" {
Text item=stue_Temperature {
Text item=stue_Temperature label="Temperatur Stuen"
Setpoint item=stue_Tempsetpunkt minValue=18 maxValue=25 step=0.5 label="Juster varmen"
Text item=telestat3_stue label="Telestat"
Text item=stueVentilMotion
Text item=stueSensorFejl
Frame label="Bevægelse" {
Text item=stue_pir
Default item=stue_pir_stamp
Frame label="Netamo" {
Text item=NetamoIndendoersTemperature {
Text item=NetamoIndendoersHumidity
Text item=NetamoIndendoersCo2 valuecolor=[<800="green",<1000="orange",<1400="red",>1399="maroon"]
Text item=NetamoIndendoersPressure
Text item=NetamoIndendoersNoise
Text item=NetamoIndendoersHeatIndex
Text item=NetamoIndendoersMinTemp
Text item=NetamoIndendoersDateMinTemp
Text item=NetamoIndendoersMaxTemp
Text item=NetamoIndendoersDateMaxTemp
Text item=NetamoIndendoersLastStatusStore
Text item=NetamoUdendoersLastMessage
Text item=NetamoUdendoersTempTrend
Frame label="Ovenlys vinduer" {
Switch item=VeluxStueAlleVent mappings=[ON=Kip]
Switch item=VeluxStueAlle50 mappings=[ON=Kip]
Switch item=VeluxStueAlle75 mappings=[ON=Kip]
Switch item=VeluxStueAlle100 mappings=[ON=Kip]
Frame label="Statistik" {
Image refresh=60000 url="http://10.4.28.3:3000/render/d-solo/cyY4Qoggk/stue-temperatur?refresh=30s&orgId=1&panelId=2&from=now-12h&to=now&width=1000&height=500"
But it gets even more strange. According to the above sitemap, I use some labels. But for some reason I cant explain, these labes are NOTquite the same which is showen in Basic UI. After the Netamo label, things seems to go wrong… In the label (picture below) “kontakter”, this is where the item used to be, which probably is the cause of all this. But it looks like the whole sitemap simply didn´t get updated after previous saving.
At first thought, I would have said this is a cache issue. But a coupple of weeks ago I flushed the cache and tmp, (after rebuilding some of my items including the one in question). But the error is still there.
I´m running openhabian and openhab 2.5M1.
Does anyone have any suggestion for this behaviour?
EDIT…
It seem like, after another flushing the cache and tmp as well as restarting my Rpi, this error is now gone…
NOT SOLVED!!
